Old 12-31-2001, 06:28 PM   #1
Witckraft
Member#: 8466
Default ***!>? 93 sedan sway bar!
I am getting my hands on an 18mm sway bar from a 97 2.5Gt... and I looked on my sedan.. NO REAR BAR!
I could have sworn my mom's old 92 wagon had one! how can I apply a rear sway to my 93 sedan L AWD?
HELP!
if push comes to shove, I will hold it until I get the 1998 sedan in august.. but god damn!
Pete
Witckraft is offline   Reply With Quote
Old 12-31-2001, 06:55 PM   #2
subarurabbit
Member#: 4083
2011 OB 3.6R
www.teaguesauto.com sells 20 and 21 cuscos.
My '93 wagon doesn't either. Neither does my mom's 92.
90-91 did. I think it was a 13mm. Could have been 15 though.
Roger
subarurabbit is offline   Reply With Quote
Old 12-31-2001, 07:26 PM   #3
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Roger, If the bar you have is a stock bar from a 97 GT I think it's a 16mm bar, which is what I took off my 98 GT Wagon. To be certain slip open end metric wrenches of various sizes onto the bar til you get a tight fit, and that's the size.
As far as fitting to an L, did you notice any mounting points for the end-links on your L? You may in fact need some additional hardware, besides the end links to make it work.
This site has some good pics of Impreza application but you can see the way the links mount to the rear suspension. AZScooby in the links section of this Board.
http://www.scoobymods.com/mods/impreza/droplinks.php
Glenn O
nuburu2 is offline   Reply With Quote
Old 12-31-2001, 08:14 PM   #4
Witckraft
Member#: 8466
I dont have the hardware.. thats the problem! Where/what do I get it off of?
Pete
Old 12-31-2001, 09:27 PM   #5
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Sorry Pete, misread who I was replying to...DOH!
Just looked under my GT and the two bars that have the end-link brackets welded to them must be different on the L model. You are also missing the 2 sway-bar mounts ,bolted into the frame rails, that keep the bar located. This looks to be beyond a simple parts swap and you may wanna wait till you get the 98.
Glenn O
Old 12-31-2001, 09:40 PM   #6
Witckraft
Member#: 8466
DAmn iT!
I wanted to use the 93 as my rally car and my 98 as a daily!
ARGH
Old 12-31-2001, 10:07 PM   #7
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Sorry, but you could get the rods and mounts off a Gen1 Turbo(or Gen2?) and have the mounts welded or drilled and tapped into the frame rails . especially if you plan to use the car for track use! The parts can be gotten, but you'll need to measure and talk to a parts expert about what'll fit. Teagues sounds like they know what may match up. Don't get bummed, just look harder and make some calls!!
Glenn O
Old 01-01-2002, 07:52 AM   #8
Witckraft
Member#: 8466
I guess I need to call FS auto and make a deal
Pete
fs wrx Rear ebay strut bar and 20 mm sedan sway bar racekar Suspension/Brakes/Handling 8 12-17-2006 01:21 PM
How can you tell between front Wagon sway bar and Sedan sway bar rukkie Brakes, Steering & Suspension 3 08-27-2004 12:30 PM
Does 02 wgn and sedan sway bar interchange? Marty S Brakes, Steering & Suspension 6 10-21-2001 03:16 PM
Stock WRX Sedan sway bars on WRX Wagon? daniel_bergamini New England Impreza Club Forum -- NESIC 9 08-14-2001 04:22 PM
Wanted: Wrx Rear Sedan Sway Bar WagonRX Bay Area Impreza Club Forum -- BAIC 1 08-14-2001 12:09 AM
