Old 07-13-2007, 11:13 AM   #1
2000GTB
Member#: 20800
2000 Legacy GT Wagon
Default TPS % on a STI swap?
I have a STI swap in my BH5 and when I checked the TPS on scanner.. at Idle it is at 14% and at full throttle, it does not pass 78.8%... anybody has experience with this or know a quick fix... Ive already done the obvious (adjusted the TPS, pedal etc.)
Also P1446, emission control CEL.. what do I have to do to fix it. If its replacing parts, where is this located..
Thanks in Advance
Kahlee
2000GTB is offline   Reply With Quote
Old 07-13-2007, 12:56 PM   #2
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
I noticed the same thing in a regular obd2 reader, but when i used ECUexplorer it read all the way up to %99.67.
You can use an openport cable with ECUflash to download your ECU's rom. Then edit it with Enginuity to turn off the CEL for p1446 and then reflash it to the ECU.
-Chav
Chav is offline   Reply With Quote
Old 07-13-2007, 01:04 PM   #3
2000GTB
Member#: 20800
thanks, alot... the cel, do you know who can do this...
Kahlee
Old 07-13-2007, 02:24 PM   #4
Chav
Member#: 3269
RSTi
You can do it with some research.
cable can be bought here.
http://www.tactrix.com/
and you can google ECUflash, and Enginuity.
As far as tuners that can do it. Anybody that tunes using the OpenECU method will be able to.
-Chav
Old 07-13-2007, 10:17 PM   #5
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
pm treefrogaz he tunes here in phoenix.
SubeSTIle is offline   Reply With Quote
Old 07-14-2007, 02:21 AM   #6
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
I've got a thread on how to get rid of the 1446 code. It does work. Although you have to interpret the wiring for your own setup.
As far as the TPS percentages.. Thats totally normal. A car @ idle will typically be between 10-15%, and full throttle is usually below 85%. The numbers you put up are absolutely on par with just about every car i've seen.
subbyspeed is offline   Reply With Quote
Old 07-15-2007, 03:56 AM   #7
2000GTB
Member#: 20800
You guys have been very helpful.... thanks and ill try to do all this on my own... but if anyone close to Jersey could do it let me know... Dont have that much spare time anymore...
Kahlee
Help with Cruise Control on an STI swap pezcore Interior & Exterior Modification 20 05-10-2010 02:17 PM
I've decided on an STI swap... Dirty D Newbies & FAQs 4 10-01-2007 07:20 PM
TGV sensor the same as TPS sensor on 04 STi?? Clark Kent Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-20-2006 10:25 PM
Which wire for TPS signal on 04 STI B136 17 or 18 roybfr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-25-2006 09:34 PM
Gauging interest on V7 STi Swap in 02WRX Pepo New England Impreza Club Forum -- NESIC 7 08-08-2005 10:40 AM
