#1 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag |
First off, I have over 50 datalogs from the street that show this turbo hitting 21psi at 3800rpm and not dropping below 19 at redline. On the dyno, it just doesn't want to spool. It's like it's not loading the car enough for it to replicate a street spool. This run was with:
2006 WRX wagon TD06-20g Prodrive BCS Ebay TMIC Cobb 3" catted TBE Deatschwerks 750cc injectors Walbro 255 APS dual vent BOV Coolingmist basic kit running 50/50 mix meth/water Not so wonderful NM 91 Octane Enginuity tune. The first pull was pathetic, but I made some good gains by the 5th. I just bought a hallman MBC and will try the dyno again next week and see how it goes. I really thought I would get more out of the setup. ![]()
#2 |
Member#: 7022
Vehicle:2013 BRZ Limited SWP |
Hmm, pump gas? Shouldn't you be a little close to 11.5:1 AFR?
#3 |
Member#: 114730
SWIC
That wbo2 isn't accurate. I talked to the dyno owner about that today again. My wb02 shows about 11.6-11.7, plus the one on the dyno is post cat. Also, I'm running meth injection.
#4 |
Member#: 84912
SCIC
Vehicle:2003 2.5L bugeye now with 6 spd 20g! |
350 hp and 380ish torque is good out of a 20g while still running a topmount.
I dont think the numbers are dissapointing. |
#5 |
Member#: 107323
Vehicle:2005 Impreza WRX 16g Crystal Gray Metallic |
I would be happy with that, even with it not loading right and still pulling 350 hp. thats alot on the street
#6 |
Member#: 114730
SWIC
It's more than enough to surprise people for sure. The car looks bone stock, and well, it's a wagon.
#7 |
Member#: 100977
Vehicle:2004 VF30 WRX 12.96@103.7mph 1.84 60' |
Good power IMO, but it looks like it spools late. I know you said it's different on the street but don't get disappointed with the numbers. You probably have yourself a mid 12second car.
#8 |
Member#: 126112
TXIC
Vehicle:93.5 Toyota Supra Red |
pretty good on a 20g with a tmic
#9 |
Member#: 9960
Vehicle:2002 Impreza WRX WRBlue Perl |
its a dynojet.. they aren't load bearing dynos like the dynodynamics and mustang dynos...
#10 |
Member#: 114730
SWIC
I'm feeling better already.
#11 |
Member#: 35076
TXIC
Vehicle:2004 507whp Wagon Silver |
You're making me debate the 20g vs the 18g I was looking at... Our wagon gears slow the spool down a little. I was hoping to see full boost at 3300-3500 max. Looks like fun =)
#12 |
Member#: 94494
NWIC
Vehicle:2005 Element 92x Black |
on 91 octane, those numbers are fantastic. Even with the TMIC.
If you were catless, I might expect a little more. |
#13 |
Member#: 92894
International
what's your idc at?
#14 |
Member#: 114730
SWIC
#15 |
Member#: 41762
International
Vehicle:04 STi CT-DE-FL rinse+repeat |
Looks pretty nice...gonna hit the track?
#16 |
Member#: 114730
SWIC
#17 |
Member#: 78074
Vehicle:2005 STi Aspen White |
my friend made 380whp on pump gas (93) fp20g , made 420whp on c16
06 wrx stock block - i think ur numbers are on par |
#18 |
Member#: 35076
TXIC
Is that the 7cm2 or 8cm2 turbo? Also which turbo, DB, Blouch, etc.?
#19 |
Member#: 97270
SCIC
#20 |
Member#: 114730
SWIC
8cm^2 Slowboy racing turbo.
I went back and made 353/399. Next, GT30R. |
#21 |
Member#: 135089
SWIC
Vehicle:07 wrx swp |
#22 |
Member#: 114730
SWIC
#23 |
Member#: 128760
RMIC
Vehicle:2012 Ruckus/WRX Red&White/Gray |
I would be pleased with that out of a 20g. What is the elevation where you live?
#24 |
Member#: 1036
Vehicle:2006 WRX Wagon Ltd. WRB |
You might get little more if you have not gasket matched your ebay intercooler. The inlets were not even close to being the proper size on the one that I have. Just use a round course sanding drum in a drill motor should not take you that long to do it. Also I have read that the exhaust manifolds on the 06 WRX really need to be ported and have a bigger connecting pipe. Other than that your set up looks awesome.
http://turninconcepts10.chainreactio...05713579b261c7 http://importimageonline.com/product...oducts_id=1859 http://forums.nasioc.com/forums/show....php?t=1283236 I also have a 06 wagon but am only at stage 2 currently. But the above items are cheap compared to the money that have already spent. Super Last edited by SuperHawk; 07-30-2007 at 08:18 PM. |
#25 |
Member#: 114730
SWIC
I did port match the ebay tmic. My elevatoin is 5300ft and it's 90-100F right now.
| Thread Tools | |
| Display Modes | |
| Possibly FS MA: '02 WRX 2.5L, TD06 20G, IPT-built 4EAT | scooterforever | NESIC Private Classifieds | 2 | 05-04-2009 05:56 PM |
| STi Stage 2 Protuned vf-39 VS td06-20g | StiPete | Factory 2.5L Turbo Powertrain | 44 | 07-09-2007 11:00 AM |
| just ordered 2 laptops with vista - should i be worried? | MrMcCrackin | Off-Topic | 31 | 06-22-2007 09:52 AM |
| Should I be disappointed? | UltimateLurker | Engine Management & Tuning | 20 | 04-18-2006 02:37 PM |
| ZILLA TD06 20G/ kong 2 | erez555 | Factory 2.0L Turbo Powertrain | 14 | 11-23-2004 12:17 PM |
