Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Vendor Classifieds
Closed Thread
Old 07-13-2007, 07:43 PM   #1
P&L Motorsports Inc.
Vendor Sales Rating: (26)
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Default P&L Motorsports releases their Tial BOV kits for Impreza TMIC applications
http://www.pandlmotorsports.com/~pan...2aa2a0dd495ac3 <-- You can view this product in our online shopping cart.
At P&L we've always realized that the Subaru lineup of mass air flow based vehicles are very sensative to leaks in the induction systems.
What our maintenance programs have taught us is that 7 times out of 10 the compressor bypass valve (BOV) is the biggest source of failure, followed closely by inlet hose failures.
We always knew that Tial's products had been legendary in terms of reliability, but never had a way of packaging their BOV design in such a way that every Impreza owner could leverage them. That has changed with the release of our new BOV kit for the 2002-2007 Impreza lineup.
We start off with a custom designed and waterjet cut flange. That is precision tig-welded onto a v-band flange that the Tial high performance BOV is bolted onto. Then the entire assembly is machined to make sure the flange surface is flat and true.
*Update*
We are now offering our BOV Kits with a REUSABLE O-ring gasket built in to the flange! Instead of paying for a new gasket each time you want to take the intercooler or BOV off, you can reuse this one which is pressed into the flange. It also provides better protection against boost leaks as pressure is applied evenly around the hole to ensure a proper seal!
Our kit has been designed and tested around several of the common aftermarket intercoolers, as well as the standard OEM units.
Our kits will be competative and retail in the same area as other high quality atmospheric units such as HKS's SSQV.
All kits will include our custom flange assembly with built in o-ring gasket, v-band flange, the Tial unit, and a machined plug for your factory return line. You supply the elbow grease, and about 3 minutes later, you're done.
Contact us with any questions you may have.
-Jorge
P&L Motorsports Inc. is offline
Old 07-16-2007, 04:32 AM   #2
majnthr33
Member#: 84498
2003 Impreza WRX
W raith R eady B lue
Does it sound like a beast, really rad, cool, or woot woot?
majnthr33 is offline
Old 07-17-2007, 03:15 AM   #3
ronzogonzo
Member Sales Rating: (43)
Member#: 136671
WRX HTA GT3076R
9cm2 eWG'd It's ALIVE!!
what about the over rich conditions from bov? is the tial recirc or 100% atmosphere? will running this bov pose an overly rich situation?
ronzogonzo is offline
Old 07-17-2007, 01:35 PM   #4
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
All of the above!
For those running larger turbos and making more than 20-22psi, the stock recirculating valve will not cut it. If you want a replacement that will hold TONS of boost (we've never seen one leak), fit on your TMIC, and sound awesome.. this is for you. It's a trade off that we fully endorse.
Ty
Old 07-18-2007, 12:44 AM   #5
jawwadh
Member Sales Rating: (10)
Member#: 100594
2008 BMW M3
so its fully recirculating?
jawwadh is offline
Old 07-18-2007, 02:02 AM   #6
ronzogonzo
Member#: 136671
WRX HTA GT3076R
how much??
Old 07-18-2007, 02:31 AM   #7
MKXIII
Member Sales Rating: (20)
Member#: 130388
2007 WRX STI Limited
Urban Steel Gray Metallic
its full atmosphere
MKXIII is offline
Old 07-18-2007, 03:07 AM   #8
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Originally Posted by MKXIII View Post
its full atmosphere
Yes sir Mr. MK13!
Prices are listed on our website, or if you want to call me up at 847-678-4311. Not now though.. during normal business hours 10am-7pm.
I gotta sleep sometime!
- Ty
Old 07-20-2007, 02:46 PM   #9
downshift1
Member Sales Rating: (21)
Member#: 15607
I'm not the type
to make angry
Originally Posted by P&L Motorsports Inc. View Post
All of the above!
Ty
Ok, you didn't really answer the question. When running full atmospheric how are you dealing with the over rich condition and the driveability issues?
Dylan
downshift1 is offline
Old 07-20-2007, 03:41 PM   #10
RiftsWRX
Member Sales Rating: (2)
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Dylan
You still will suffer from it, but to a much lesser degree then other units. That more due to the spring tension used which is more progressive on the release (read: not a load whoosh). That, and proper modification of certain tables (I.E. FI boost trim) during tuning go a LONG way to making it right. But it physically can never be perfect unless the valve were used in a blow through setup with the valve setup behind the MAF. But that's a completely different application we make then the scope of this post.
HTH!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline
Old 07-22-2007, 08:31 PM   #11
GripGC8
Member Sales Rating: (24)
Member#: 110653
87 FC3S
do you sell regulat tial bov's for FMIC application?
is so..how much for the bov and i will also need an aluminum flange welded to my aluminum pipe...how much for all of the above?
GripGC8 is offline
Old 07-23-2007, 12:45 PM   #12
paul@p&L
Member Sales Rating: (4)
Member#: 101036
2006 05stix2 00RS TA
06stiAT s14silvia bigblue
The tial bov are $250 and come with your choice of SS or Alu. flanges.
We charge $85 for fab time to weld on your flange.
Thanks
Paul @ P&L
paul@p&L is offline
Old 08-21-2007, 12:57 PM   #13
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
*Update*
Ty
P&L Motorsports
sales@pandlmotorsports.com
Old 08-21-2007, 01:55 PM   #14
NITROS
Member Sales Rating: (26)
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
*Update*
Ty
P&L Motorsports
This is the first time i see this. That is pretty smart too.
You'll have others coping you in no time.
NITROS is offline
Old 08-22-2007, 01:53 PM   #15
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Maybe, but you know what they say about imitation...
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline
Closed Thread
FS: p&l/tial bov kit for tmic in WI! n2oiroc Engine/Power/Exhaust 0 05-01-2008 06:05 PM
P&L Motorsports releases their 2008 Race Series Catback! P&L Motorsports Inc. Engine/Power/Exhaust 0 11-21-2007 01:31 PM
P&L Motorsports releases their 2008 Race Series Catback! P&L Motorsports Inc. MWSOC Vendor Classifieds 0 11-21-2007 01:30 PM
P&L Motorsports releases their Tial BOV kits for Impreza TMIC applications P&L Motorsports Inc. Engine/Power/Exhaust 0 07-17-2007 02:49 PM
