Old 07-14-2007, 01:47 AM   #1
FMJ
Member#: 138170
Default Clinging noise under the car? Something loose?
Earlier today I started my car, as I reversed outta the driveway and onto the street I put the car in D. As I started rolling forward slowly I heard from weird clinging noise coming from under the car. I pulled over and looked to see if some was dangling or loose, saw nothing. and i drove some more I continue to hear the clinging sound. as I go over bumps, and bumpy terrain I hear it more but tends to go away at a constant speed, say 35 -40mph. I had my friend jack up the car and looked to see if anything was loose, didnt see anything. So we came to the conclusion that something internally is loose.
what could be wrong with my car? i plan on calling subaru and have them go over it.
my car is a 06 WRX ltd auto w/ 10k miles, all stock, never beaten.
FMJ is offline   Reply With Quote
Old 07-14-2007, 01:56 AM   #2
scoobyj
Member#: 146147
2001 wrx330/322 vf35
mica red/
sounds like a heatsheild.
scoobyj is offline   Reply With Quote
Old 07-14-2007, 03:14 AM   #3
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
^ yeah, maybe heatshield over turbo. Mine rattles on decel. Gotta tighten that up.
z is offline   Reply With Quote
Old 07-14-2007, 03:34 AM   #4
nick04263
Member#: 68799
2004 WRX COBB STG 2+
I have a slightly similar situation. As soon as I start forward I heard a very slight "cling-cling". Sort of a metal tapping but it is gone after that. It sounds like it is coming from the left front area around the wheel. At first I thought it might be a stone in the tire or possibly a nail but nothing is there. The best you can do is isolate the area and do some manual pushing and pulling to try and reproduce the noise.
nick04263 is offline   Reply With Quote
Old 07-14-2007, 04:38 PM   #5
FMJ
Member#: 138170
whats gay is that i went to my subaru dealership, have someboyd drive my car for 20 minutes and couldnt replicate the noise. so they told me that when the noise comes on persistantly i should go back. so as i started leaving the dealership and into the freeway the noise came back. if it is the heatshield, how easy is it to tighten it?
Old 07-14-2007, 05:09 PM   #6
BlackPearlX
Member#: 118165
2006 WRX /
2004 Forester
ummm... what did you do to the car? did you installed any after market parts?
I know i had some clinging noise when i installed my sway bar and did not tighten endlinks tight enough...
BlackPearlX is offline   Reply With Quote
Old 07-14-2007, 06:02 PM   #7
djsniggedy
Member#: 102157
What you lookin at
willis?
sounds like a loose endlink ??
djsniggedy is offline   Reply With Quote
Old 07-14-2007, 10:19 PM   #8
FMJ
Member#: 138170
hmm...
my car is stock. weird, i drove the car another 70 miles after going to the subaru dealership and didnt once hear the noise yet.
Old 07-14-2007, 10:38 PM   #9
TheSilverFox
Member#: 142520
2006 STI - Protuned
308whp - SilverFox
+1 on loose heatshield or endlink... i'd check those first
--J
TheSilverFox is offline   Reply With Quote
Old 07-15-2007, 02:48 PM   #10
FMJ
Member#: 138170
cool, thanks for the help guys.
how easy should it be to tighten up these two things?
Old 07-15-2007, 08:13 PM   #11
49erRider
Member#: 143474
WR Blue
Very Grab a socket wrench and go
49erRider is offline   Reply With Quote
Old 07-16-2007, 08:20 AM   #12
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
I'd also check the spring bolts, if you've modded your exhaust. Mine are a little loose and as a result i hear some "cling"ing. Mostly at idle, or if I rev when not in gear. Makes the most noise when I do that, and the rpm's start dropping
ErasureWRX is offline   Reply With Quote
Old 07-24-2007, 06:51 PM   #13
jaysh
Member#: 133200
2013 STi Limited
if its an after market exhaust u may need longer hangers...i had the same problem but once i got longer hangers, problem was solved..
jaysh is offline   Reply With Quote
Old 07-24-2007, 09:51 PM   #14
BIggieWagon
Member#: 127766
Pads prematurely wearing out and the indicators/screamers going off?
BIggieWagon is offline   Reply With Quote
Old 07-24-2007, 10:05 PM   #15
jgarbs
Member#: 154889
I'm not sure if this applies but I heard a similar noise and my check engine light came on, so I took it to the dealership and my front Cat went out. This is on a 2006 Subaru WRX STI
jgarbs is offline   Reply With Quote
Old 07-24-2007, 10:34 PM   #16
z
Member#: 41762
04 STi
damn that's awefully quick for a cat to go bad...only one on the sti though, right?
Old 07-25-2007, 12:23 AM   #17
BlackPearlX
Member#: 118165
2006 WRX /
2004 Forester
Endlinks are very easy... you will need two 14mm wrenches. One open to hold everything in place and another to screw it in (if you have torque wrench, set it to 40, otherwise get it as tight as you can)
damn that was fast... any mods?
Old 07-25-2007, 01:07 AM   #18
Zaider
Member#: 154281
2002 V7 EJ207 Dom1.5
MBP
i get the same thing with my 02 impreza rs. Heat shield. Previous owner had it tightened up, came back after a while. Gonna see if i cant squeeze some sealant into the cracks or something. Just in a few spots to stop the sound.
Zaider is offline   Reply With Quote
Exhaust Rubbing and all kind of noises under the car (HELP!) DJS_02_WRX Newbies & FAQs 16 09-11-2009 11:03 PM
Odd noise from under the car... teddyj Transmission (AT/MT) & Driveline 3 05-12-2008 01:13 AM
Weird noise from under the car on throttle TotalNewbie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-19-2007 10:42 PM
Weird noise under the car in the front... rukkie Brakes, Steering & Suspension 10 07-23-2004 03:23 PM
Mini Squeeking noise under the Legacy Apexboy Legacy Forum 6 03-23-2000 08:30 PM
