Old 07-14-2007, 10:17 AM   #1
LUKEWMC
Member#: 119872
2004 STi
Default Whiteline steering bushing install
Hey guys. i had the good grace of being able to bring tools home from work to do my steering rack bushings for my 04 sti this weekend. Does anyone know what size sockets and such that i need as i need to make sure i bring the right tools home as i have to have this done between today and tomorrow. Tried a quick search but could'nt find the sizes. at work so search time was limited. thanks for the help!
LUKEWMC is offline   Reply With Quote
Old 07-14-2007, 11:05 AM   #2
noboost4u
Member#: 126442
My car is slower
than your car
http://wrx.grapon.com/multimedia/Bushings_wmv.wmv
All you need to know is here^^^
Thanks again Nick!
noboost4u is offline   Reply With Quote
Old 07-15-2007, 02:14 AM   #3
firedog25
Member#: 12570
2002 White WRX
'91 Turbo Miata
This is a big pain in the ass. I just did mine.
firedog25 is offline   Reply With Quote
Old 08-07-2007, 12:25 AM   #4
TRinityMtrSprts
Member#: 43720
2002 mbp WRX
97 Ford Ranger on Bags
just did this... wow what a MOTHER F*Ckin pain!!!
even with the video!!! that guy's car was way nicer to him then mine was... i swear if i didn't have my dad help shimmy the driver side steering arm, i would never have gotten that damn bushing in!
i can usually tackle these projects with no problem, but this i will never do again.
TRinityMtrSprts is offline   Reply With Quote
Old 08-07-2007, 02:32 AM   #5
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I did that install on at least three separate cars with varying miles and grit underneath. Each time, it was exactly like it was when I did it in that video.
nhluhr is offline   Reply With Quote
Old 08-07-2007, 04:19 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
jeze 46 megs .. ever hear of youtube?
Old 08-07-2007, 04:22 PM   #7
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
youtube is for bitches.
Old 08-07-2007, 04:37 PM   #8
MasterKwan
Member#: 98961
2003 WRX
Yeah it was an hour or less to do it on my 03. Worth every second though. The trick for me (didn't watch the video) was to disconnect the rack from the steering wheel shaft so, the whole rack drops down 1-2 inches. Was easy after that. I bent a couple of the hard lines slightly to make room.
Old 08-07-2007, 05:53 PM   #9
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
You REALLY do not need to do this. It's extra work, extra time, and there is plenty of room (when done correctly) without disconnecting it.
Not to mention, you stand a really good chance of getting the thing re-connected a spline or two off which means your steering wheel will be really offcenter... creating yet more work.
Old 08-07-2007, 08:05 PM   #10
MasterKwan
Member#: 98961
2003 WRX
Watched the video, Our techiques are essentially the same except I made myself alot more room by disconnecting the rack. Necessary? No. It was easier for me though.
Old 08-07-2007, 08:07 PM   #11
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
You said it took you an hour. I filmed that in under 30 minutes.
Old 08-07-2007, 09:39 PM   #12
MasterKwan
Member#: 98961
2003 WRX
True but, I include jacking up and down and all the other prep. It was an hour from start to test drive. You were faster, no doubt. How many had you done at that point. I'm doubtful it was your first.
Old 08-07-2007, 09:43 PM   #13
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
It was my 4th I did it on ramps to save the time of jacking it up.
Old 08-07-2007, 10:48 PM   #14
ejh25
Member#: 65267
Once on jacks, I found it took me about 30 minutes. This really wasn't that bad for me. Spark plugs take me longer.
ejh25 is offline   Reply With Quote
Old 09-23-2007, 05:48 PM   #15
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
has anyone else found the the passenger side bushing(for an 02 WRX) appears to be too big? I noticed the stock one had a bulge in it, and the whiteline one bulged in the same place. upon further investigation, the stock one only shows wear on the top and bottom, unlike the driver side that has wear all the way around.
Wheeler Bement is offline   Reply With Quote
Old 09-23-2007, 09:47 PM   #16
turb04
Member#: 61386
04 PSM WRX R.I.P.
05 Snow White Camry
the install is pretty easy..driver side bushing is a pain but a lil strength and som evice grips to pull it through and its cake!@@@
turb04 is offline   Reply With Quote
Old 12-22-2007, 10:41 PM   #17
Furious George
Member#: 109742
MBP
F*^#! That driver side is a PITA. Getting the clamp loose was bad enough, but trying to get the new bushing in is the real pain. (I am still not done). I read that jacking the car rather than putting it on ramps gives extra room to put the new bushing in. Anyone tell if that is correct?
Furious George is offline   Reply With Quote
Old 12-22-2007, 11:04 PM   #18
BryanH
Member#: 993
are people still doing bushings on the newer cars?
BryanH is offline   Reply With Quote
Old 12-22-2007, 11:21 PM   #19
Daishi00
Member#: 78952
2005 WRX
CGM
Yeah, but for you it's probably not worth it yet. The rack was redesigned and that alone is a huge improvement. I did notice a difference though so it's not like a worthless mod or anything.
Daishi00 is offline   Reply With Quote
Old 12-23-2007, 02:34 PM   #20
Furious George
Member#: 109742
MBP
OK. Finally went back and got it done this AM. It was a PITA. Tips I could offer:
1. on the Driver side, I found that pulling the clamp out the left side was easier than the right, which looked like it was the better choice.
2. Grease those F'ers up. It will make a difference when you go to squeeze that new bushing up over the top on the driver side.
Impressions:
It was a short trip, but I could indeed notice a difference. Steering feels a bit more connected. I feel like my inputs now match what the car is doing. Before I always felt like I had to turn the wheel more to get the car pointed where I wanted it. Now, not so much. No noticeable increase in NVH either.
Overall: Worth it. Best Xmas gift I have gotten so far this year
Old 02-03-2013, 06:16 PM   #21
Tdaz250
Member#: 310744
02 WRX
Bringing up a real old thread but...i kinda have the same impressions as above. Went on a short drive and it feels like it made a difference. I'm more interested in how the car is going to act on the freeway though(guess i'll find that out eventually).
The video isnt working though so thats a bummer.
Tdaz250 is offline   Reply With Quote
Old 02-03-2013, 06:41 PM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d000000000000000d
the last post in this thread was 6 years ago
Old 02-03-2013, 07:05 PM   #23
Tdaz250
Member#: 310744
02 WRX
Haha. Wasnt hoping for these peoples replys i just thought i would bump an old thread rather then start a new one thats basically saying the same thing.
Old 02-12-2013, 12:35 PM   #24
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
had the whiteline bushings on my old 02 wrx.. i thought it was a noticeable improvement in steering feel immediately after the install.. but then later i added a smaller OMP steering wheel and that really made a difference..
in the end i think a smaller wheel alone will give you a stronger steering improvement..
KIMUTAKU is offline   Reply With Quote
Old 02-12-2013, 01:01 PM   #25
paulpat
Member#: 237145
02 WRX
12 FXT
From what I hear, the better option is to get an sti steering column linkage. This eliminated the worst rubber part of them all
paulpat is offline   Reply With Quote
Tips for installing whiteline steering bushings drfrink24 Transmission (AT/MT) & Driveline 2 06-19-2008 09:43 AM
Where to get Whiteline Steering Bushings installed???? captainkirk44 Mid Atlantic Impreza Club -- MAIC 22 04-16-2005 02:38 PM
Whiteline Steering Bushings - Help Needed Ingraham Brakes, Steering & Suspension 12 05-16-2004 01:48 AM
Whiteline Steering Bushings - Help Needed Ingraham South East Region Forum 3 05-14-2004 11:37 PM
Whiteline steering bushing back by popular demand ginowrx Bay Area Impreza Club Forum -- BAIC 18 05-23-2003 09:21 PM
