Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 03-06-2001, 02:27 AM   #1
V6
Member#: 2703
Y2K GC8
Silver forever
Post Which spark plug is good to use?
Hi,
Just like to know which spark plug is good to use?
denso iridium plugs or just normal NGK VX platinum is good enough?
Thanks.
V6 is offline   Reply With Quote
Old 03-06-2001, 05:21 AM   #2
bender
Member#: 1839
Post
i haven't used the denso, but I heard that they are very good. If you do a search, you'll find so info on them. I am using borsh+4, and they are a lot better then the stock chumpions
bender is offline   Reply With Quote
Old 03-06-2001, 10:24 AM   #3
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Denso Iridiums are good for turbocharged applications. I doubt you will feel any power difference with them on a NA setup. Not lest your butt-dyno is cranked up to maximum sensitivity, but then again people here will probably just laugh at you and require actual dynographs.
Just go with the NGKs.
Keiho is offline   Reply With Quote
Old 03-06-2001, 10:51 PM   #4
V6
Member#: 2703
Y2K GC8
Silver forever
Post
I have a question that in Canadian Tire, is that the NGK G-Power is the same as the NGK VX?
Thanks
Old 03-06-2001, 11:14 PM   #5
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
No idea.
Old 03-06-2001, 11:22 PM   #6
V6
Member#: 2703
Y2K GC8
Silver forever
Post
Anyone knows?
Coz I see the NGK G-power (platinum spark plugs) in Canadian Tire looks 100% the same as the NGK VX (platinum spark plugs).
Old 03-07-2001, 05:40 AM   #7
bender
Member#: 1839
Post
No they are not the same. IIRC the HGK G power is either plat plated or only the tip is platinum. the vx is the top line NGK.
Which trunk lid is best to use for the 07 Limited edition spoiler?? madmax02 Interior & Exterior Modification 6 03-11-2008 07:40 AM
Which spark plugs to use? AlboWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-06-2006 10:25 AM
Which spark plug boot is in front? The Orange dot? verc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-06-2005 06:57 PM
Which spark plugs to get? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-03-2003 11:23 AM
Which spark plug is good to use? V6 Normally Aspirated Powertrain 1 03-06-2001 02:20 AM
