Old 07-15-2007, 02:08 PM   #1
Damien02WRX
Member#: 107492
2002 Impreza WRX
World Rally Blue
Default Strange????
I recently flashed the XPT stage 2.5 map. This is probably coincidence but my speedometer is fluctuating like a tachometer and my gas gauge is reading improperly. This is 48 hours after the flash and car has been running great since then. I had one occurrence of a over boost condition in 4th yesterday. This morning the CEL was flickering and the car had a rough idle and a hesitation at higher speeds. Please help.
Damien02WRX is offline   Reply With Quote
Old 07-15-2007, 05:52 PM   #2
Damien02WRX
Member#: 107492
2002 Impreza WRX
World Rally Blue
Bump for some insight. Could this have anything to do with my Walbro install? I can't see how a re-flash could affect the gas gauge and speedometer???
Old 07-15-2007, 06:24 PM   #3
testes1010
Member#: 47145
2012 Gas Saver
flash back to your previous map....
what are your engine mods? injectors especially.
what is the map designed for?
sounds like you flashed the wrong year map?
did you disconnect the green connectors after reflashing?
its difficult to help people with little information...
testes1010 is offline   Reply With Quote
Old 07-15-2007, 07:11 PM   #4
Damien02WRX
Member#: 107492
2002 Impreza WRX
World Rally Blue
Flashing back to my previous map is what Braden at XPT tuning recommended.
My engine mods are everything required for the XPT stage 2.5 MAP: VF34, STI pink injectors, Catless TBE, MadDad Version 2 header w/catless velocity uppipe, GM BCS, COBB SF Intake version 2, EBAY TMIC.
The map is designed for any of the following VF series: VF30,VF34,VF39, pink injectors, GM BCS, catless TBE, catless uppipe, STI intercooler, and STI panel filter.
I hope I did not flash the wrong year map, the file says MY02 XPT Stage 2.5 91oct Final.hex
I did disconnect the green connectors after reflashing.
Old 07-17-2007, 11:51 AM   #5
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
That's a pretty descriptive topic title.
06rexwagon is offline   Reply With Quote
Old 07-17-2007, 01:20 PM   #6
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
Fuel pump install could affect your fuel gauge reading. If you accidentally bent the long rod with the float this would screw up your fuel gauge.
brettm is offline   Reply With Quote
Old 07-17-2007, 04:41 PM   #7
boostdog
Member#: 149752
07 wrx tr
rr tuned stg2 [email protected]
did you flash it back to stock? if so what happened?
boostdog is offline   Reply With Quote
Old 07-18-2007, 08:39 PM   #8
Damien02WRX
Member#: 107492
2002 Impreza WRX
World Rally Blue
I flashed it back to stock and noticed no change in anything. In fact yesterday my coolant temp gauge started dancing around. I am going to go over all the wiring I was around this weekend and check for anything unusual. The part that sucks is my car runs great and pulls hard when in the higher RPM's. When I am at 1700-2500 RPM is when I feel the hesitation, plus I have a rough idle. Does anyone know if the TGV wiring, fuel injector wiring is tied in at all with the gauge setup??
Old 07-21-2007, 01:23 PM   #9
Damien02WRX
Member#: 107492
2002 Impreza WRX
World Rally Blue
Could someone point me in the right direction. My gauge symptoms seem to have vanished, but I still have the hesitation and rough idle. On my stock map I would get a vibration from the motor around 2000 rpms, not to mention a strange miss at about 1700 rpms, hardly noticeable. I believe with the XPT map the problem is now heightened. My question is what should I be looking at for a hesitation between 1700-2500? Fuel filter, plugs, O2 sensor???
('93-'01) Help! Strange rattle from exhaust litespeed Impreza Forum 6 03-25-2016 12:33 AM
Strange Relay Chatter Type Sound, I hate it too...I have a strange sound post! sigma69pi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-06-2008 11:31 PM
Strange boost problem with a strange dealer diagnosis. Help? Computergeek24 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-09-2006 12:34 PM
Strange BOV behaviors and strange noises from turbo tr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-09-2004 07:06 AM
('93-'01) Strange thumping from driver side rear??? chrisj Impreza Forum 3 05-17-2001 06:16 PM
