Old 08-24-2009, 02:15 PM   #376
scotr
Member#: 170720
2007 WRX
Blu
scotr is offline   Reply With Quote
Old 10-26-2009, 02:39 PM   #377
sexyyrex
Member#: 128022
2011 Infiniti G37x
Sedan
I recently sold my 2006 WRX
Car made 247 whp and 345 ft-lbs of torque on 93 pump gas
Mods - V1 accessport with Al freidman protune (@ ICS) stromung shorty DP, Maddad cat delete, ERZ catback and SSAC intercooler
Car had seen 25+ track passes however, not shifting or launching at full potential. Trapped 101 in the 1/4 with most launches at 4500 slipping clutch hard and little tirespin
Car has 59,xxx miles on it when I sold it this July and was still shifting mint just fine until the kid I sold it to totalled it, bought it brand new in July of 06
Only complaint was the clutch slipped a little in cold weather at high load
sexyyrex is offline   Reply With Quote
Old 07-15-2010, 10:55 AM   #378
Mechie3
Member#: 120152
Originally Posted by Mechie3
06 WRX
Stage 2 + (stock turbo, everything allowed by ESP rules)
243 WHP
351 WTQ
Factory fluid up to 30K miles, USC after that (I know, I read about how it's not good after I put it in)
DD and lots of autocross. Launch at 3K rpms (breaks the wheels free for a brief moment with R-comps) but I don't drop the clutch, I let it slip.
No issues so far, but I'm sourcing a backup trans just in case.
Originally Posted by Mechie3 View Post
On my third motor now, still on the original trans. 52/53k miles. Had a great AX on Sunday. Torque is transmitted very quickly with the new beatrush knockoff motor mounts that I was spinning wheels coming off the apex's. Still running USC, changing it out for Subaru Extra S in the coming weeks.
Aaaaand, update. BAM! Lost third gear coming to work. Yeah, I actually did kinda laugh when I realized I hadn't blown up my (fifth) motor.
Installed new trailing arms last night with pillowballs and I noticed the shuddering/shimmy when letting off the throttle under WOT was gone and the car picked up faster.
In 3rd gear merging on the highway, switched lanes, pressed the gas....and box-o-rocks. At first I thought my trailing arm came off since I was accelerated then jerked forward and slowed. Check oil pressure...good....tracking straight....good. That's when I realized it was third gear.
Had 60 or 61k on the trans.
Mechie3 is offline   Reply With Quote
Old 07-15-2010, 11:35 AM   #379
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
Sux dood... sorry to hear that.
Originally Posted by flimflamman View Post
Just turned 27,000 and replaced tranny and rear diff with Subaru Extra-S 75W-90. Old stuff wasnt that nasty and the particle build up on the magnets were very light.
Stage 2 - 3" TBE with OSECU OTS.
I don't launch 'er hard (or shift hard) very often, but I do WOT frequently. Mainly 3rd gear for data logging (which is quite enjoyable ).
*Knocking on wood* she's holding up quite well.
At 37k now and still doing well *knocking on wood*.
DynoJet at 245hp and 322tq. I've had some hard launches from autox's recently.
Hang in there baby!
I installed a VF39 at 47k several months ago.
Currently at 55k and *knocking on wood* everything is still strong.
I replaced the tranny fluid with Extra-S at 27k and am about to replace it with Motul 300 gear oil.
I do not "plan" on any more power upgrades for quite sometime (though I wish I could... trust me.. )
Mods:
VF39
STi TMIC
AEM CAI
TurboXS turbo-back (stealthback) with standard TurboXS muffler (non RFL)
Tuned by Applied Tuning Solutions (shameless plug I know )
Dynojet SAE (corrected) 300 hp 340 tq
I've romped on it quite a bit since the upgrade, but I do not "bang" the gears. Naturally, I slip the clutch on launches (though I have smoked the clutch a couple times cuz' I suxorz). I have missed 3rd gear once (w/vf39) VERY bad, and it was at the strip (once again I sux). Man that pissed me off.
Hang in there baby!
flimflamman is offline   Reply With Quote
Old 07-15-2010, 12:16 PM   #380
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
While my car was stock for 60K and then stage 2 for 15K, I beat the ever-living hell out of my 5MT and it was still going strong when I sold it. Launches, flat-foot shifting, gear banging.
I'm still amazed I didn't break it.
Old 07-15-2010, 03:15 PM   #381
Bready
Member#: 196483
2006 Imprezza Wagoon
TEAM AWS!
in the middle of doing a tranny leak fix right now. come to find out that my center diff went bad. Does anybody know if the center diffs from previous years are the same in the 06-07 trannys?
Thanks!
Bready is offline   Reply With Quote
Old 10-11-2010, 11:33 AM   #382
buckwilly
Member#: 252012
2010 STi
2006 Subaru WRX TR manual tranny. 64K stock tranny and original clutch. All stock until Stage II (about a month at stage II)
Purchased at 52K miles in June 2010. Transmission felt fine except a occaisional grind in 5th gear which I could literally tell was going to happen as I felt resistance going into 5th, made no sense to me except previous owner resting his hand on the shifter all the time. I did replaced fluid with Scotty's cocktail and 5th grear grind went away completely after 2 days of driving. I now have 64K on the car in October and its been XPT stage II for about a month. No issues, no grinds, downshifts are smooth, 5th grear feels fine, no slipping on original clutch.
I don't launch the car as I never drop the clutch in any gear. I guess I am a habitual granny shifter and I would never hard launch this car, seems pointless to me as the car is brutely fast in 1st and 2nd anyhow just feathering the clutch. But I guess my plans to upgrade from stock turbo seems to be not worth it if I am happy with the gains on the stock turbo. I am hitting 5-7 psi in 1st, 16.4 psi in 2nd, 17.2 psi in 3rd, 17.8 psi in 4th and 18 psi in 5th and its been pretty consistent since its leaned out.
Nice thread, great info for us planning on increasing power and driving hard.
buckwilly is offline   Reply With Quote
Old 10-13-2010, 06:24 AM   #383
Makako54
Member#: 110013
2006 Impreza WRX
Default 2006 wrx
2006 wrx , TBE, Stage II tuning @ 18lbs for 30,000 miles. Now @ 63,000 miles on 2nd clutch. I've tried to baby 3rd in but my 4th grinds a little. fluid has been changed twice, and its fine
Makako54 is offline   Reply With Quote
Old 10-13-2010, 07:00 AM   #384
2nedEJ25
Member#: 161184
06 Wagon
Aspen
06 Wrx with 60k miles and original stock clutch. I've been running stage 2 since 40k and no problems yet with tranny. I did just recently put in Extra S oil and found original oil to be pretty clean and surprisingly a little bit of metal nothin major. I think as long as u don't launch and beat on it all the time you'll be fine. Oh yeah i drive in Nyc traffic all the time.
2nedEJ25 is offline   Reply With Quote
Old 10-13-2010, 07:16 AM   #385
ohxietviet
Member#: 143164
06 AW WRX
06 wrx, 61k miles and just replaced motul 300 for the second time.. almost hitting 30k with the 20g on. No issues yet but the car is hardly beat on.
ohxietviet is offline   Reply With Quote
Old 10-13-2010, 07:41 AM   #386
turbofied
Member#: 239813
06 wrx ej257 vf39 280whp+
100'000 miles going strong.
turbofied is offline   Reply With Quote
Old 10-13-2010, 09:49 PM   #387
Jperez21
Member#: 252539
04 STi
CGM
06 WRX TR stage 2, TBE, intake, Sti upper manifold, VF-39, Sti TMIC. Blew 3rd gear at 37k.
Jperez21 is offline   Reply With Quote
Old 10-13-2010, 11:45 PM   #388
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
60k miles, Cobb stage 1, several track days and rallyx, lots of commuting in traffic
I rev match 99% of the time and stick to oem rubber bushings at all tranny points.
No probs so far at all.
chimchimm5 is offline   Reply With Quote
Old 10-14-2010, 01:52 PM   #389
roccer
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
2006 wrx. 30k. TurboXS TBE + OS Stg2 tune. original clutch, etc. kartboy short shifter and shift bushings. rev match all my down shifts. never launched (tis my daily driver). only ground the gears a few times in its life.
no problems here (knock on wood)
roccer is offline   Reply With Quote
Old 10-15-2010, 03:29 PM   #390
MadProfessor
Member#: 192779
06 WRX Wagon. Just turned over 60k. SPT intake and Catback. Not tuned yet but will. Trans serviced at 30k and 60k. No issues yet. I don't beat on it though.
MadProfessor is offline   Reply With Quote
Old 10-19-2010, 10:09 PM   #391
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
06 WRX Wagon, opensource tuned at Precision Tuning, 235HP/300TQ at the wheels with K&N air intake, Madded TBE, Hallman MBC.
46K miles, tuned for the last 5K miles, changed tranny fluid at 30K and at 38K.
done a handful (2-4) clutch-dump launches that didn't really launch, just shocked the drivetrain like a mother....yeah I know, dumbass driving. This was when I first bought the car. Since then, only a handful of times, I've launched the car while slipping the clutch to minimize the drivetrain shock. This was after the tune. I've also done 2 launches in the rain to see how the AWD system works it out.
Spirited driving/"normal" driving is about 50/50. In spirited driving, I take it to about 5K to 5500 revs on WOT before shifting 1 to 2 to 3. I always slip just enough and always (at least try) rev-match when downshifting.
Trans feels good just like day 1. I just hope those few dumbass attempts at launching an AWD car didn't f' my trans up. It has been 40K miles since so everything should be good. I plan on upgrading to a VF43 and other power mods next spring and want to achieve near 300HP/350TQ at the wheels. I'm considering going to AndrewTech and do Helical 1-4 PPG gears and upgrading to ACT flywheel and clutch at the same time. I'm concerned that the trans won't hold up to the torque but my tuner said I should be fine unless I decide to go with a larger turbo, thus more torque.
kenliu84 is offline   Reply With Quote
Old 10-20-2010, 08:54 PM   #392
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
My stock clutch started slipping a few weeks ago. ODO is at 59k.
*Knock on wood* the tranny still seems solid.
Still sporting the VF39 (300/340)
I'm going with a Southbend Stage 2 clutch kit. Should be breaking it in around Thanksgiving.
Old 10-28-2010, 02:25 AM   #393
07scoobywrx
Member#: 249390
2007 impreza wrx
blue
07 wrx vf39 36k on the car i have done about 15 5500-6000 rpm clutch dumps and have had no problems i changed all my oils with royal purple dont know if its the best but works good for me i know it says not to post about a friend but hes the only person that i know that had a problem and it wasnt with the trans it was with the rear diff all the spider gears in the diff where stripped the car had about 44k on it sorry if my post sucks first time posting.
07scoobywrx is offline   Reply With Quote
Old 10-28-2010, 09:29 AM   #394
alphaomega0
Member#: 147678
07 wrx
obsidien black
Originally Posted by juanmedina View Post
I though the legacyGT gears were as strong as the 06-07 gears, with a different final drive ratio?
wrong actually , read this
http://flatironsrally.typepad.com/fa...-and-more.html
the wrx has had the same gears from 03-07 .. soa is full of **** when they said they beefed up the tranny after the 2.5L upgrade
alphaomega0 is offline   Reply With Quote
Old 10-29-2010, 06:09 PM   #395
Ragnarok_WRX
Member#: 257093
06 WRX, 49,9xx miles, 2k of it me. VF39, STi tmic w/tune, exedy stage 1, all within the last 45 days, some feather launches. Nothing bad yet, since the clutch install though, after the car warns up shifting into 4th seems to grind ever so slightly, not sure what to make if it yet.
Ragnarok_WRX is offline   Reply With Quote
Old 10-29-2010, 07:09 PM   #396
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
Synchro's are wearing out... but it'll prob be okay for a while.
Old 02-08-2011, 09:44 AM   #397
mQumQu
Member#: 190927
2006 WRX vf39ed
06 wrx, vf39 protuned
approx 290awhp
exedy stage 1 clutch (10,000 KM, duno what that is in miles)
Been having little grind from 2-3.
Clutch is somewhat slipping on wot on 3rd gear.
I am thinking on what to do to reinforce the tranny.
I will be going td06 20g 8cm2 with all supporting mods (walbo 255/kstech 73mm/850cc)
I think i should be around the 380 range when done.
So should i be getting legacy gt 1-3 gears as a lot mention
or go with sti ra gears ?
I can not seem to find the price for legacy gt 1-3 gear cost
compare to sti ra gears set or type sti gear set at
http://www.rallispec.com/prod_trans.htm
mQumQu is offline   Reply With Quote
Old 02-08-2011, 11:32 AM   #398
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
06 SADM WRX (4.111 final drive) - 43k miles:
From 11k mile to 40K stage 2
Now 3k miles made 324whp 330wtq on 18G
Tranny still holding. No grind or anything and I'm still on stock clutch.
Ferraz is offline   Reply With Quote
Old 02-08-2011, 01:40 PM   #399
alphaomega0
Member#: 147678
07 wrx
obsidien black
stage 2 after 15000 km, stage 3 making 300whp-345wtq since 25000km still going strong at 56000, oem clutch
Old 02-09-2011, 03:07 AM   #400
freshADR
Member#: 141565
2008 DGM Outback XT
SoCal Flat Four #28
Originally Posted by freshADR View Post
I had about 7500 miles running stock with an axleback and SPT intake. Now I'm running Stage I with 8k miles.
I've rarely grinded 3rd and 4th due to unsynchronized downshifting with my feet and arm .
I have the option of going stage 2, but if the tranny blows I won't be able to cover it. So I'm saving up for a PPG set, a bigger turbo, etc. so I can just drop everything in all at one time .
Man rereading this makes me realize how much more of a noob I was .
Just to follow up the car has been stage 2 for the past three years with 43K on the odometer. Occasional spirited driving but I never abused the tranny. Changed fluids with Uncle Scotty's cocktail mix and my car loves it.
freshADR is offline   Reply With Quote
WTB: 06/07 STi Driver Airbag, 06/07 impreza model Driver Seatbelt, 06/07 WRX Fenders moose00015 Private 'Wanted' Classifieds 2 07-12-2009 05:37 PM
WTB: 06/07 wrx Driver side headlight housing RallyDude87 NWIC Private Classifieds 3 03-31-2009 10:29 AM
WTB - 06/07 Wrx Driver front fender, Left headlight, and possiably front bumper. Niblaze Tri-State Area Private Classifieds 2 08-21-2008 12:09 PM
WTB : 06-07 wrx driver headlight new06 Private 'Wanted' Classifieds 1 05-22-2008 09:02 PM
Black leather 06-07 wrx driver seat. aclver1 Private 'Wanted' Classifieds 0 11-06-2007 06:31 PM
