07-16-2007, 04:41 PM | #1 |
Member#: 13680
Vehicle:2002 WRX WRB |
Stand Alone = integrated DCCD control
If anyone is interested in directly controlling their DCCD using their stand alone I may be able to help you.
I've built a new project that would allow you to create an "auto" program for your DCCD directly within your stand alone EMS's available aux PWM pulldowns. For example, you could tie TPS and load into your "DCCD map" to create a nicely integrated solution for controlling the DCCD directly with a stand alone EMS.
07-17-2007, 03:01 PM | #2 |
Member#: 94494
NWIC
Vehicle:2005 Element 92x Black |
But where would you control the DCCD? You would still have to have a control dial somewhere, right?
So what you're saying is if I want DCCD on my car, I buy the differential and you can make my Hydra control it, so all I need is the control dial? Considering the Neetronics is only a few hundred, I'm assuming this would have to be fairly cheap. None the less, I'm interested. Tell me more. |
07-17-2007, 03:08 PM | #3 |
Member#: 99289
I would assume you could find an analog input to use for the manual control, but i wounder if the logic is there in the standalone to switch maps.
07-17-2007, 06:18 PM | #4 |
Member#: 13680
I guess I wasn't clear enough...
What I was saying is that you can use the already existing aux PWM's that are available for free (in every major stand alone EMS) to create a built in DCCD controller that you can self tune. You don't need a control knob, it can be user mapped using your throttle and engine load parameters so that the EMS could automatically control the DCCD in a 2d map. You can probably load in different maps depending on different conditions, I'm not sure of the capabilities of all the different stand alone's. The interface is basically a signal conditioner in between the low amp PWM in the EMS and the high amp PWM needed for the DCCD. I have already designed and built one for someone as a test project. This is only intended for people in a very small niche, with stand alone EMS and an STi 5 or 6 speed swap that has a DCCD. And yes, the cost is really inexpensive. <$100 It is essentially the output stage from my (famous) "Spiider's Auto Mode DCCD controller" with a few mods to work properly with the Stand Alone EMS. |
07-17-2007, 06:39 PM | #5 | |
Member#: 94494
NWIC
The biggest question is, who tunes a DCCD map? <<<somebody who has a stand-a-lone who wants DCCD in the future |
07-17-2007, 09:40 PM | #6 |
Member#: 13680
I think a "base map" would be easy to figure out. It's not hard to think about the logic of how you want the DCCD to behave under certain conditions.
That's sort of how I started my inital maps/modes and tweaked them from there until I was happy with the car behavior. I spent a lot of time in my car logging with Deltadash and my accelerometer data to see where the big improvements in traction can be made. That "research" is what went in to the tarmac programs in the Auto controller. I also took in a lot of descriptive "evidence" from my customers about how they wanted the car to behave in certain situations and used that to advance the "maps". Some of that data could be used in the stand alone 2d maps to get started, I don't know who else might have some experience in the area of DCCD mapping that would want to contribute... |
07-18-2007, 01:26 PM | #7 |
Member#: 104130
Vehicle:2002 WRX blk |
could you map it to behave differently in different gears? like be More front biased in first but more rear bias in 2nd gear and up?
07-18-2007, 03:10 PM | #8 |
Member#: 135686
NESIC
There are many stand along center diff controllers out there. I think a dedicated piece of hardware is better suited to controlling the diff as opposed to the ECU.
07-18-2007, 03:44 PM | #9 | |
Member#: 13680
On the other hand the benefit to a stand alone DCCD controllers is that (with my unit anyway) you have additional g-sensors to help provide data the stand alone EMS wouldn't have access to. The big benefit of this new interface is that it would be cheap and very effective. The least expensive stand alone Auto DCCD controller happens to be my design and it costs $250. The interface I'm talking about will be <$100 shipped. |
07-18-2007, 03:47 PM | #10 |
Member#: 13680
It would all depend on what mapping is available in your stand alone EMS. If there are "per gear" parameters available I can't see why not. The problem is that you would have to have the correct STi 6 speed and the wiring done properly. I know with my JDM ver7 swap I could see only a couple different gear "states" in Deltadash. I couldn't fully see it reading from 1st to 6th. It was more like "in gear" and "out of gear".
07-19-2007, 04:01 PM | #11 |
Member#: 90110
W. Canada
Vehicle:2004 wrx wagon WRB |
I looked into this a while back and gave up. Ended up buying my controller from these guys,rocketrally.com, works great. I think they said somthing like that you will burn out the driver if you try to run the diff off of the ECU for any length of time...
07-19-2007, 09:57 PM | #12 |
Member#: 13680
You obviously can't run the DCCD directly off the ECU driver, it won't last more than a couple minutes, maybe less. The PWM circuits in any stand alone are only good for a couple amps. Plus they are pull downs, which won't do anything for you when it comes to directly powering your DCCD.
This is the reason I created an EMS->DCCD interface........ It does all the high speed switching and power supply side of things. |
07-19-2007, 11:05 PM | #13 |
Member#: 99289
I would think this could also be used on a UTEC 5th injector PWM output, but I'm not sure what parameters you can use.
07-19-2007, 11:42 PM | #14 | |
Member#: 90110
W. Canada
07-20-2007, 12:13 AM | #15 |
Member#: 99289
You are missing the point. This doesn't use anything from the ECU, it gets it command from a stand alone. What is involved in that is based on the complexity of the ECU, and what it is capable of.
07-20-2007, 12:34 AM | #16 |
Member#: 90110
W. Canada
Got ya, you set up the parameters in the PWM table of the EMS and it sends the signal to this amplifier which controls the centre diff.
07-27-2007, 08:47 PM | #17 |
Member#: 9960
Vehicle:2002 Impreza WRX WRBlue Perl |
sounds really interesting... shame i got the JDM 6mt without dccd or I would have been all over this one...
07-28-2007, 12:31 AM | #18 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
so..
if you ran external boost control (mbc for example) you could then use the stock boost map (via open ecu/ecutek/ap) for dccd control using the bcs output as the input source which would be pretty dam cool |
08-01-2007, 01:03 PM | #19 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
With the Hydra the sky is really the limit here. You could assign a 3D map to send a PWM signal to this controller based on any two parameters the Hydra logs. So for instance you could use RPM vs Boost, Speed vs. Boost, TPS vs Speed, etc.
Thanks, Phil www.elementtuning.com |
08-02-2007, 03:41 AM | #20 |
Member#: 152285
International
Subscribed!
This is definitely something very interesting as I'll be using Hydra on my setup when it happens, and this would give me that added incentive to go 6-speed with DCCD! |
08-02-2007, 10:11 AM | #21 |
Member#: 135588
Vehicle:2007 STI *SOLD* |
I new to the Subaru community and DCCD control.. What is it that you would want to change as you are driving?
08-07-2007, 12:59 PM | #22 |
Member#: 101691
Vehicle:97 Supra TT SOLD - 35r bug/hawkeye |
pm me info..i would like to get ahold of one of these.
08-09-2007, 08:42 PM | #23 |
Member#: 13680
It's a little pre-mature right now for me to sell any of these to people that aren't willing to experiment a bit, and work with the support guys at places like Element and Autronic.
Currently there is a NASIOC member with a GC/STi swap (with an autronic standalone) underway that is going to be the first "field tester" for this interface. Once testing is complete and I can get a report about how satisfied or not he is then I can feel more comfortable about putting these out into the field in a few more cars. We are currently working out some sort of a "basemap" if you want to call it that. It should just be a few more days to a couple weeks. I can build them right now if anyone else is ready to do some testing, I will let a couple more of these out under cost to explore this concept a bit more. I'd like someone with a Hydra to try this so I can see what they can do with this, especially after Phil's input ^^^. Exciting really, what we could do to add DCCD control to the realm of being fully integrated with the standalone. |
08-10-2007, 12:03 AM | #24 |
Member#: 101691
well i have a hydra but ive never plugged it up myself with a laptop..im not tuned yet and running on a basemap made by phil for my setup for the breakin period. im guessing the control has to be modified by self adjusting the program or is only the knob needed?
08-10-2007, 05:54 PM | #25 |
Member#: 13680
No, there is a lot more to it than just adding a knob and/or my new interface.
You would need your tuner or Phil to help you out with getting this all set up properly. |
Stand alone engine management options | jetfan8178 | Normally Aspirated Powertrain | 3 | 03-26-2002 01:19 PM |
AEM Stand Alone | Moe33 | General Community | 11 | 02-26-2002 12:06 PM |
Stand alone scan tools | LVSUBARU | Normally Aspirated with bolt-on Forced Induction Powertrain | 12 | 02-15-2002 10:31 PM |
For those looking for stand alone engine management... | DanMan | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 22 | 02-02-2002 02:30 AM |
Unichip offered as a stand alone unit? | Diz | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 07-30-2001 11:12 AM |
