Old 07-16-2007, 09:56 PM   #1
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
Default Pass. side oil leak, where from??::HELP::
do i need to add n e sealant to the valve cover gasket??
i cant figure out where i am leaking from, cam seals are fine, valve cover seems to be fine but i got a new one n e ways..
there is oil on my timing belt, all inside the back of my pass. side cam gears, and was flying onto the headers, which caught fire once it heated up....
Twiztidunreal is offline   Reply With Quote
Old 07-16-2007, 10:27 PM   #2
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
well i am about to go put the valve cover back on , with the newer gasket... see what happens...
Old 07-16-2007, 10:35 PM   #3
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
oil feed line?
SUBYS R US is online now   Reply With Quote
Old 07-16-2007, 10:49 PM   #4
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
that was leaking when i first started, from the banjo, but thats tighter now..
not leaking at the block
Old 07-16-2007, 11:47 PM   #5
Steve455
Member#: 128727
2005 WRX Sti
black
I had the same problem on a ej25,never could get the oil to stop leaking,and just sold it that way.I used alot of sealant and that did not help either.
Steve455 is offline   Reply With Quote
Old 07-17-2007, 12:06 AM   #6
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
yeah mines an ej25 block.. i wouldnt worry about it if it had not already caught on fire, lol
Old 07-17-2007, 12:16 AM   #7
Steve455
Member#: 128727
2005 WRX Sti
black
mine started leaking after i changed the headgaskets.i changed the cam seals again after and still it did not help.i remember every time i stoped smoke would come out of the hood,and oil on the ground.The oil was always in back of the cam gears so i know it was in that area.i also tightend the cam caps and that did no good.
Old 07-17-2007, 01:34 AM   #8
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
yep. cam seal was clean, replaced valvecover just in case, still leaking, back of cam gear(manily exhaust) covered in oil... idk, i might just take it to a shop(god help me) and see what they can do...
Old 07-17-2007, 02:32 AM   #9
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
also, my oil pressure gauge reads 7+ bars on start up and for the first few mins running, is that normal??
Old 07-17-2007, 09:38 AM   #10
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Did you replace your 0-ring in your oil pump?
JMK508 is offline   Reply With Quote
Old 07-17-2007, 12:48 PM   #11
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
yep and silicone.
Old 07-17-2007, 03:16 PM   #12
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
o well, its about to be flat bedded to the dealer, let them figure it out, ive spent my last 2 months getting this motor together, now an oil leak i cant even find, time to pass it on to someone else...
Old 07-19-2007, 02:26 AM   #13
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
cam journal on pass. side, bolt snaped off in head so oil was leaking from the cam journal
Old 07-19-2007, 09:32 AM   #14
JMK508
Member#: 115420
Its like a STI.....
Wow that not good. At least you know where it was comming from now. How much are they going to charge you to fix it?
Old 07-19-2007, 08:35 PM   #15
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
lol, you dont wanna know.. more then i spent on the short block, just for a bare head and labor.... 2200(1372 is labor(14 hrs@98/hr))
if i could of found a used set of sti heads, i would have swapped them my self, but the car has been down 2 months, they said it will be ready tomorrow, if not then by monday
Oil leak.....but from where? SurfWagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-16-2009 11:12 AM
We're stumped. Oil leak, but from where? mav1c Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 09-10-2008 11:11 PM
2.5 hybrid pass. side oil leak Twiztidunreal Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-04-2008 12:39 AM
slight oil leak...where the hell is it comming from? mpower22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 10-19-2005 04:26 PM
Does every other WRX have a turbo side oil leak? Drew888 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-09-2004 07:55 PM
