Old 07-17-2007, 11:25 AM   #1
Woodward
Member#: 102424
2003 Tundra
GrEy
Default Tail light wire harness compatibility
I have an '06 WRX and recently bought a pair of '04 tail lights. Will I need to buy an 04-05 tail light wire harness, or can I use my '06 harness? bc it doesn't look like the reverse light socket will fit.
TIA
Woodward is offline   Reply With Quote
Old 07-17-2007, 07:25 PM   #2
2.5jayhawk
Member#: 148238
it will fit, you will just be missing a bulb. the 06 wrx only has 4 sockets, to the 04/05's 5. they will fit, for mine i left the middle lower one out of the assembly. at night it looks pretty slick actually. see how it looks first before you buy a harness.
2.5jayhawk is offline   Reply With Quote
Old 07-23-2007, 05:12 AM   #3
Woodward
Member#: 102424
2003 Tundra
GrEy
Ya, I can do without the middle lower light, but the reverse socket doesn't match up to the hole correctly.
Old 07-23-2007, 06:51 PM   #4
JD_STI
Member#: 153912
07 STI
I just called the parts guy at my dealership, he's been around a long time. I asked him if 05 tail lights will fit in my07. He said everything is exactly the same, same harness, same amount of bulbs, you don't need to buy a harness.
I just bought 05's for my07 so I hope he is right.
I would call the dealership yourself just to make sure.
JD_STI is offline   Reply With Quote
Old 07-24-2007, 01:15 AM   #5
Woodward
Member#: 102424
2003 Tundra
GrEy
The part numbers of the wire harnesses are different for the 04-05 vs. 06-07. I bought the older wire harnesses for $20 a piece from the dealer.
Old 07-24-2007, 01:19 PM   #6
JD_STI
Member#: 153912
07 STI
Interesting, did you try and use the original one first? I guess my parts guy or your parts guy is wrong.
Old 07-25-2007, 08:49 AM   #7
Woodward
Member#: 102424
2003 Tundra
GrEy
My '06 harness won't fit. The reverse light socket doesn't fit and it only has 4 bulbs instead of 5.
Your parts guy is wrong. I've looked up the part numbers on http://subarugenuineparts.com/ and they're different.
06-07 Tail light harness: 84931FE380
04-05 Tail light harness: 84931FE240
Old 08-10-2007, 04:29 PM   #8
06STIGO13
Member#: 110526
2007 STI Ltd 306 UGM
2008 STI Nav & BBS AW
So how do we make this 05 tail light in an 06-07 WRX work? Did you guys ever get this figured out? Is it as simple as an adapter or is there rewiring involved? I'm thinking about 05 tail ever since I saw them in a car like mine!
06STIGO13 is offline   Reply With Quote
Old 08-10-2007, 05:31 PM   #9
Dynamite59487
Member#: 155455
2007 Impreza 2.5i
bump it up
Dynamite59487 is offline   Reply With Quote
Old 08-10-2007, 11:05 PM   #10
KENisFISX
Member#: 154541
2007 Impreza TR WRX
before i traded MY05 in for MY07, I did this swap. I traded my 05 tails for a set of 06s. the harness plugs are the same, but where the bulbs go into the assembly is different. even so, just swapping the harnesses and assembly(bulbs too) you'll fit it fine. oh yeah and the bulbs that fit the 04-05 are 7440s where as the 06-07 are 7430s(or whatever the next size down was) that is why they have different part #s. The point is you can use whichever harness you want so long as you put the bulbs in the correct socket.
KENisFISX is offline   Reply With Quote
Old 08-16-2007, 03:05 PM   #11
STI23
Member#: 135316
and where can you purchase a harness for the 04/05's?
STI23 is offline   Reply With Quote
Old 08-19-2007, 08:35 PM   #12
.John
Member#: 146535
07 WRX Wagon
UGM
Default Pictures?
see post #7
anyway....does any one have pictures of the differences? bulbs, harnesses, back of tail light assemblies?
.John is offline   Reply With Quote
Old 08-19-2007, 09:08 PM   #13
KevinG
Member#: 146091
14 Mazda 3
Red
i had no issues with my swap
KevinG is offline   Reply With Quote
Old 08-19-2007, 09:28 PM   #14
shoefean
Member#: 153563
90 Civic EF
Almost San Remo Red
TIA
How much did you get the o4 taillights for? I really want to get a set for mine!
PSS: If anyone wants to trade their 04/05 taillights for my 06s plus this B&M sport shifter for a 03/07 WRX i'll be your bestfriend for ever!!!
shoefean is offline   Reply With Quote
Old 08-20-2007, 10:07 AM   #15
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Correct me if I'm wrong, but when you say "harness" I believe you mean the bulb sockets with the plug that are on the taillamp and not the actual wiring harness attached to the body of the car that goes to each taillamp.
New taillamps from the factory already come with the bulb sockets, with bulbs, already installed, which would mean that for the most part the swap is a plug-and-play, but...
...since you are going between model years, you have to "rewire" them. Meaning, you have to test the wires and reconfigure the terminals into the plug end (lamp-side) so that you can have the lamps work the way you want to.
The 06-07 lamps are a 4-socket set-up and the 04-05 are a 5-lamp set-up. With the latter, you have the flexibility of setting up each of the three lower lamps the way you want to. You can make the inners your parking lamp only, as with the WRC car. The centers are [apparently] the european/non-US rear fog lamps. The outers can be set as either your brake lamps only or a combination of parking/brake lamp. You decide.
This sounds like you've purchased a set of lamps used where the seller removed the sockets and thus you end-up trying to install your sockets onto lamps from a different model year, of course.
Old 09-07-2007, 10:55 AM   #16
system60
Member#: 97604
05 LGT WGN 5spd
Is the parts number for both harness' or do i have to order 2
system60 is offline   Reply With Quote
Old 09-07-2007, 02:29 PM   #17
KENisFISX
Member#: 154541
2007 Impreza TR WRX
the difference in the 2 part #s is the bulb size they take, the 04/05 take the 7440 and the 06/07 take the 7439. Everything else is direct swap. there is no extra parts needed.
Old 09-07-2007, 05:06 PM   #18
system60
Member#: 97604
05 LGT WGN 5spd
Not what i meant, i meant do i need 1 04-05 Tail light harness: 84931FE240 or 2 since i didnt receive the harness' w/ the tail lights.
Old 09-07-2007, 05:46 PM   #19
KENisFISX
Member#: 154541
2007 Impreza TR WRX
if you have 2 lights that need it then you'd need 2....unless i'm not understanding your question. anything i've ever got from a dealer, each part # was for 1(even bolts)
WTB: Tail light wiring harness vms150 Private 'Wanted' Classifieds 2 08-21-2009 10:13 PM
2006 Tail Light Wire Harness (2) Woodward Exterior/Styling 2 09-19-2007 10:18 AM
02-03 wrx tail light wiring harness WRXsonicyellow Private 'Wanted' Classifieds 3 10-23-2006 02:29 PM
wiring harness compatibility Dangerdave Normally Aspirated Powertrain 1 06-05-2006 11:50 AM
Need a tail light wiring harness camelkicker2000 Electrical & Lighting 1 04-23-2006 10:12 PM
