Old 07-17-2007, 05:17 PM   #1
iamcgr
Member#: 141685
2002 WRX (ots stg 2)
Default Removing buildup around "subaru" lettering after debadging?
I recently debadged my trunk (2002wrb). After removing the letters I cleaned the adhisive with goobgone and then washed and waxed (multiple times). It looks great, I'm happy.
I sadly can still see the subaru on the trunk if I look up close and in the proper light. I think it could be some sort of build up around the letters, from either dirt or products the previous owner useds.
I was wondering if using a claybar on the trunk might remove whatever is there? If not any other suggestions?
Thanks for any input.
iamcgr is offline   Reply With Quote
Old 07-17-2007, 05:26 PM   #2
ampy549
Member#: 125814
2004 wrx
white
try bug/tar remover. Heat up the paint with a blow dryer for about a minute, then spray the bug/tar remover, let it set for a minute, and then wipe it off. It worked perfectly for me
ampy549 is offline   Reply With Quote
Old 07-17-2007, 06:03 PM   #3
Uncle Buck
Member#: 140062
2005 STI ATP3076r
95' Eclipse gs
or try buffing it out. since its a little bit older of a car it could just me paint fade and youll have to deal with it.
Uncle Buck is offline   Reply With Quote
Old 07-17-2007, 06:19 PM   #4
Hellbound
Member#: 53333
I did the same to my 2002 WRB WRX and had a little bit left behind. After a couple of days I just tried blow drying it and used WD-40 to clean it. It was a friends idea and I thought it was weird too, but it worked. =]
Hellbound is offline   Reply With Quote
Old 07-17-2007, 06:37 PM   #5
pete_falcone
Member#: 123330
16 ZoomZoom CeX-3
15 ZoomZoom3-Regina
+1 for bug/tar remover. And get the gel-like brown stuff, not the white stuff that comes in a spray.
pete_falcone is offline   Reply With Quote
Old 07-17-2007, 07:00 PM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
The painted surfaces around emblems are typically hard to get at and are therefore easily neglected. “De-badging” reveals this flaw and will typically result in a crisp, visible border where the emblem once was. .....to me, this sounds more like your problem.
You will need to use a mild polish to remove the ghosting effect and restore the finish around the border areas (it should also help remove traces of adhesive residue that may have been left behind). I've found that Scratch-X (from Meguiars) is a good, safe, readily available product for hand/spot treatments such as this. .....follow up with your favorite wax and the results should be to your satisfaction.
Kean is offline   Reply With Quote
Old 07-17-2007, 07:21 PM   #7
2.5jayhawk
Member#: 148238
goo gone then wax. looks good/better than new
2.5jayhawk is offline   Reply With Quote
Old 07-17-2007, 08:53 PM   #8
silverwrx666
Member#: 86514
01 rsti,86 k10,lex
LS400,is350
I used bug and tar remover and heat gun.
then I followed up with a cleaner wax.
the trunk was from a 04 that I swapped with.
silverwrx666 is offline   Reply With Quote
Old 07-17-2007, 08:58 PM   #9
SwisSlesS
Member#: 122445
2006 WRX Wagon
Steel Grey Metallic
Clay bar would probably work too.
SwisSlesS is offline   Reply With Quote
Old 07-17-2007, 11:21 PM   #10
E_Swift
Member#: 152711
I just did this a few days ago. Didn't have Bug&Tar so I can't comment on that, but WD40 did a good job of removing any remaining adhesive. From there, I tried various polishing compounds and it took a few steps down in coarseness to get out the staining around the logos on a PSM trunklid. Follow up with a few passes with finer polish compounds and a wax and you're better than new!
E_Swift is offline   Reply With Quote
Old 07-17-2007, 11:48 PM   #11
02boxer
Member#: 139853
2002 wrx....its tsxy
a buffer and some compound should do you right. If you don't know how to properly work one, and don't know someone you trust that can...talk to a body shop. Its a relatively quick job, probably something you can do under the table, off the clock. My buddy rubbed out my old car, severely water spotted and faded, and it came back looking like glass.
chris
02boxer is offline   Reply With Quote
Old 07-18-2007, 01:23 AM   #12
Kean
Member#: 25187
'08 Foz Prem TGM
.....there's no sense in automatically choosing the harshest solution for what otherwise may be a minor problem that can be solved using a less aggressive method.
anyone know who owns a 03 WRX WRBP sedan in Houston w/ the "subaru" letters removed? Big_Hitter Texas Impreza Club Forum -- TXIC 9 12-31-2002 02:38 PM
subaru letters still seen after debadging... Otaku64 Car Care & Detailing 16 07-18-2002 11:21 PM
removal of "SUBARU" letters between tail lights jacksonww Legacy Forum 6 07-11-2002 02:09 PM
Removing/Replacing the chrome "SUBARU" Letters on trunk lid. Buru Car Care & Detailing 7 05-13-2002 01:46 PM
('93-'01) POLL..what did you do with your letters after you debadged your trunk SuBaRu-ImPrEzA_RS Impreza Forum 42 04-27-2001 08:39 AM
