Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 03-09-2001, 04:58 PM   #1
Scoobie Newbie
Member#: 4184
2004 WRX
World Rally Blue,Moonroof
Question Less then premium gas
What will the effects be on the new WRX if you use less then premium gas (91 octane)?
Scoobie Newbie is offline   Reply With Quote
Old 03-09-2001, 05:44 PM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Horrible performance, the chance that you screw up your motor due to detonation from lean-run. More than likely the ecu will have settings to prevent detonation due to you putting in lower octane...
Why would you want to to begin with?
Keiho is offline   Reply With Quote
Old 03-10-2001, 04:25 AM   #3
Scoobie Newbie
Member#: 4184
2004 WRX
Post
More of a what-if. Like a friend takes it out and decides to be nice and fill it up. Or the dealer puts less then premium in when the car arrives for delivery.
Old 03-10-2001, 05:32 AM   #4
WRX Fan
Member#: 4286
Post
One tank of premium would not total the car, but I would just get a map of all the Sunoco stations and keep it handy!
Don't loan your car to anyone dumb enough not to know the differnce between 89 and 94 octane! (Problem solved!)
Or if you are like me, just don't loan your car period! (You wanna drive, YOU make the payments my friend!)
I am guessing that no one sells higher Octane than Sunoco?
I think that ELF has some good racing fuel that they use at Canadian Rallies, that is 101, I wonder if the REX would like that?
WRX Fan is offline   Reply With Quote
Old 03-10-2001, 06:23 AM   #5
sti2_5rs
Member#: 1578
2000 Impreza 2.5RS
Post
In east, we have sunoco 94
In west, we have chevron 94.
sti2_5rs is offline   Reply With Quote
Old 03-10-2001, 10:04 AM   #6
Scoobie Newbie
Member#: 4184
2004 WRX
Post
Is 91% octane no good or must it be 94% always?
Old 03-11-2001, 05:27 AM   #7
WRX Fan
Member#: 4286
Post
91 Octane is the recommended one for WRX, 94 should just give you a bit better performance.
Old 03-11-2001, 04:30 PM   #8
tulit
Member#: 338
09 STi
Post
From our recent discussion regarding running a Japense spec motor on Canadian pump gas...
<pre>
Source: Petroleum Refinery Engineering
(p40) "With the advent of high-compression motors, the tendency of a fuel to
spark-knock or detonate violently has attracted much attention. Knocking is
thought to be due to autoignition of part of the charge in front of the
flame. Mild knocking has little effect on the performance of the engine,
but severe knock may result in loss of power and damage to pistons and
bearings. Certain substances such as lead tetraethyl, iron pentacarbonyl,
etc. tend to prevent knocking. All hydrocarbons have different antiknock
properties, and certain of these, such as benzol and those in cracked
gasoline, are useful in suppressing knocking. Octane number is greatly
affected by altitude. The octane number may be about three units lower for
each 1,000ft elevation at elevations near sear level (growing to 7.5 per
1,000 ft at 12,000-ft elevation). Thus, if an octane number of 67.5 is
necessary at sea level, 50 is satisfactory at 6,000-ft elevation, and at
12,000-ft elevation even 20 is satisfactory."
(p42) "
Type of Gasoline Octane number
Diisobutylene 84.3
Isoctane 100.0
Toluene 105.3
The octane number required by cars of even the same make ranges by at least
7 to 12 Research octane units. Although additional power can be developed
by the use of high-octane fuels in suitable engines, the extra power of
mileage obtained by the use of high-octane-number fuels in current vehicles
is not impressive or conclusive. Under some conditions of operation a 10
per cent increase in mileage appears to be possible by increasing the octane
number from 68 to 83, but tests on some vehicles indicated no improvement or
even a decrease in mileage. High-octane fuels do provide smoother, more
satisfactory performance. "
</pre>
tulit is offline   Reply With Quote
Old 03-11-2001, 07:03 PM   #9
markus
Member#: 438
2004 STi
White on Gold
Post
I would just like to add to Tarun's post above that the elevation changes with a turbo motor will be far less pronounced that with a N/A car. Therefore if the existing car recommends 91 ovtane at sea-level, you will still have to use something very close to that at 6000ft elevation.
markus is offline   Reply With Quote
Old 03-11-2001, 07:20 PM   #10
tulit
Member#: 338
09 STi
Post
Not exactly. Did you get my last email explaning this? My original argument made no sense (regarding the wastegate). Anyways, here it is again...
<pre>
"Anyway, pretend this happens :
You are at sea level, and say the air
pressure is 15. Say you have a motor that
runs 10 pounds of boost (which is really 10
pounds above atm levels). Now the motor
see's 25 pounds.
Now we are at 1000MSL, and say the air
pressure has dropped to 10. The turbo will
still generate our 10 pounds of boost above
atm. Now the motor only see's 20 pounds,
but we've sacrificed a bit of power. We can
bump the boost to 15 pounds, and see the
same performance as at sea level (motor now
sees 25 pounds), thus negating our altitude
increase (and our benefit of running lower
octane fuel).
[This message has been edited by tulit (edited March 11, 2001).]
Old 03-12-2001, 08:03 AM   #11
grandmasterchan
Member#: 3092
2002 WRX rally blue
www.zucru.ca
Post
Scoobie Newbie: we had a discussion among some Winnipegers about this on our forum:
http://www.escape.ca/~scirocco/Ubb/F...ML/000019.html
grandmasterchan is offline   Reply With Quote
Diesel Now Less Than Premium As Gas Prices Surge AVANTI R5 Non-Subaru News & Rumors 20 02-24-2009 12:49 PM
2 5spds broken in less then 6 months, and less the 5K miles snowman4us Transmission (AT/MT) & Driveline 12 08-28-2007 02:53 AM
Anyone with rim 18x8.0 with less then 44offset? FryRice Tire & Wheel 3 06-27-2003 05:00 PM
F/S Prodrive P1's with p6000 less then a 1000 miles on wheels and tires WRBLUEWAGON Tri-State Area Forum 1 02-25-2003 01:33 PM
less then 1" lowering springs? Legacy GTR Brakes, Steering & Suspension 4 05-01-2002 02:27 AM
