Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 07-18-2007, 11:18 AM   #1
hampster
Member#: 15766
torq steer=something
cattlemen do after work.
Default Fuel Vapor Technologies Car = 92 mpg and 0-60 in 5 seconds
The title says it all...
Link here: Fuel Vapor Technologies
Three wheels better than 4?:
The “alé” features a unique 3-wheeled configuration: 2 in the front, and one in the rear. The front wheels drive and steer the vehicle. This design enables the car to perform at a superb level, particularly in cornering, with the car easily pulling 1.7 g’s in corners during track testing on street tires. The three-wheeled automotive platform also aid in improving fuel efficiency and aerodynamics.
Vapor system:
The car’s key innovation's are the fuel vapor system and it's light weight aerodynamic body. This fuel vapor technology (which is in the patent pending process) allows the engine to run on “fuel vapors” rather than liquid fuel. The majority of gas engines today run 14.7:1 – (14.7 parts air to 1 part gasoline). This proprietary fuel vapor system allows the “alé” to run on a ratio of over 20:1 without compromising performance. According to the textbooks, this ratio is impossible, as a standard engine would not start or run on a air/fuel ratio this low. With a 10 gallon gas tank found on most vehicles, the “alé” can travel from Vancouver BC to San Francisco CA on one tank. Over 15 hours of driving without filling up.
Performance:
Not only does the “alé” have extreme mileage capabilities, but its performance is outstanding and better than many high-end sports cars. It accelerates from 0-60 in 5 seconds, and will pull over 1.7 g’s in hard corner's on street tires. Brad Zimmerman, head tech for the company stated during testing at the Mission race track, “I drove it hard for 4 solid hours, throwing it into corners, accelerating and braking hard. The car’s performance is spectacular. After all that hard driving, we only went through $10 in gas.”
Emissions:
The “alé” runs on regular gasoline, and easily achieves the level of “super low” emissions with a 30% reduction in CO2. Even more impressive is the fact that all the data to date has been gathered without a catalytic converter.
Automotive X-Prize
FuelVapor Technologies will be entering the “alé” in the "Automotive X-Prize" competition for the most fuel efficient production vehicle http://xprize.acrobat.com/p92151066/.
The Future:
This is the first time the public have had a chance to view the “alé”. The company is currently seeking investors to take the “alé” into production.
Vehicle Specifications
Body
Hand-layed fiberglass composite
Chassis
Full tube frame with roll cage
Engine
High mileage Honda engine
Turbo Charged 1500cc
2 Stage single cam Vtec
Gasoline vapor fuel management system
180 HP
0-60 MPH in 5 seconds
1/4 mile time of 12.9 seconds
Transmission
5 speed standard, or 4 speed over drive automatic
Front Suspension
Honda CRX with fully adjustable coil over
Rear Suspension
Single sided swing arm with fully adjustable coil over
Steering
Porsche 911 rack and pinion (2.25 turns lock-to-lock)
Front Brakes
Front discs: 12.1" diameter vented and scallopped rotors, 4-piston calipers
Rear Brakes
10" disc brakes
Wheels & Tires
Aluminum 18" X 8" front and rear
Configuration
Two seat tandem. - shoulder seat belts
Dimensions
Wheelbase: 110”
Outside to outside track: 71.5"
Length: 174’’
Height: 50“
Dry Weight: 1400 lbs
Fuel Capacity: 10 gal.
Top speed: Electronically limited to 140 mph.
hampster is offline   Reply With Quote
Old 07-18-2007, 11:24 AM   #2
Jarvis
Member#: 8267
2010 MB E63
Black on Silver
mph or mpg?
Jarvis is offline   Reply With Quote
Old 07-18-2007, 11:26 AM   #3
hampster
Member#: 15766
Originally Posted by Jarvis View Post
mph or mpg?
Dammit, beat me to it...fixed!
Impressive vehicle: 92 mpg, 140 mph, 0-60 in 5 seconds, 1.7g lateral acceleration, and already street legal in Canada.
Old 07-18-2007, 12:30 PM   #4
SlideWRX
Member#: 3803
07 Mustang GT
285 is a wide tire!
Very impressive, but CO2 isn't the concern at 20:1 A/F, NOx is. NOx goes through the roof in lean burn situations, which is also why OEMS don't run there.
http://en.wikipedia.org/wiki/Lean_burn
That wiki also mentions hondas lean burn engines running at 22:1.
It's a very beautiful trike. If all the emissions are reduced, it's very cool tech.
Tom
SlideWRX is offline   Reply With Quote
Old 07-18-2007, 01:19 PM   #5
Garwin
Member#: 105621
Oh my Goddess! If this sells for around $15k, I'm all over it.
Garwin is offline   Reply With Quote
Old 07-18-2007, 01:31 PM   #6
hampster
Member#: 15766
One thing to note when re-reading the article: these performance numbers (92 mpg, 0-60 in 5 seconds, 140mph top speed) are running a conventional 14.7:1 A/F ratio (ie: without the gas vapor system). The company is looking to break the 100 mpg barrier using lean-burn technology.
Old 07-18-2007, 01:48 PM   #7
Kostamojen
Member#: 2272
2013 Subaru 599 :P
Galaxy Blue Sexy
Sign me up!
Old 07-18-2007, 03:21 PM   #8
Syph3r_
Member#: 150804
2015 STi
CWP
wow 100mpg that is insane. its about time too, with the ridiculous gas price every summer!
Syph3r_ is offline   Reply With Quote
Old 07-18-2007, 07:36 PM   #9
Hazdaz
Member#: 14611
Interesting vehicle, but I think it would have better acceptance/success if it was marketed as a motorcycle competitor rather than trying to compare it to a regular car.
The performance is very impressive, the mileage fantastic but I would be wary of how much it might cost.
Hazdaz is offline   Reply With Quote
Old 07-18-2007, 08:20 PM   #10
silverlegacy
Member#: 90877
It seems to me like they took a CRX and made a lightweight tricycle out of it. It has that front suspension and a turbo D-16. It even has the old seats in it! It is a simple concept, very lightweight car with a small motor will get good milage. The rolling resistance of only having 3 wheels helps I'm sure. Don't get me wrong here, I would love one, but it is a very simple concept that won't work in America where people don't really like very small cars.
silverlegacy is offline   Reply With Quote
Old 07-19-2007, 08:35 AM   #11
registering
Member#: 89332
2007 Miata
Beautiful car, but doubt it would sell in the US (hope I'm wrong!). Europe has more 3-wheelers. I wonder how it does in crash tests?
registering is offline   Reply With Quote
Old 07-19-2007, 01:15 PM   #12
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
I would expect it does about as well as a motorcycle in crash tests.. I wouldn't strap a kid into this. ... but I would certainly drive one.
Caliber srt-4 goes 0-60 in 5.5 seconds boostdog Non-Subaru News & Rumors 52 09-28-2007 04:25 PM
Electric car to debut July 12. 0-60 in 4 seconds. George71 Off-Topic 75 03-15-2007 08:04 PM
0-60 in 5 seconds, Confirm please? kahtep Proven Power Bragging 11 07-17-2006 02:55 PM
0-60 in 5.118 seconds-Wagon buchananracing Proven Power Bragging 11 01-01-2003 12:41 PM
WRX 0-60 in 5.8 Seconds sugar General Forum Archive 25 03-29-2001 01:15 AM
