Old 07-18-2007, 11:56 AM   #1
adofly
Member#: 107693
2006 impreza Race
car 700hp
Default racing slick tires
What are the best tires in terms of grip, for short ( 1-2 minutes) tarmac hillclimb races?
adofly is offline   Reply With Quote
Old 07-18-2007, 12:02 PM   #2
spazegun2213
Member#: 91208
the '13 Ktm Duke
if you can get a little heat in them before the start I's assume the Hoosier A series tires would be right up your ally. The A (autox) compound heats up quicker than the R, so you would probably want to start about.
Other than that, i have no idea.
spazegun2213 is offline   Reply With Quote
Old 07-18-2007, 12:05 PM   #3
adofly
Member#: 107693
2006 impreza Race
car 700hp
I already use the A6, with which I am happy, but since there is no regulation for DOT tires I thought I can find anything better that, like racing slicks.
Old 07-18-2007, 12:12 PM   #4
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
If it's dusty at all, I'd stick with the A6 or V710s. Otherwise, some R25 Hoosier or R115-R210 (depending on weight) Goodyear could be an option.
TyrannoSullyRex is offline   Reply With Quote
Old 07-18-2007, 12:15 PM   #5
adofly
Member#: 107693
2006 impreza Race
car 700hp
Sometimes it is dusty.
For what Gooyear models are you talking about?
Is any good race tire suppliers out there?
Old 07-18-2007, 12:24 PM   #6
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
Old 07-18-2007, 12:31 PM   #7
sachilles
Member#: 115107
02 wrx wagon
61 Morris Mini
Not sure where you hillclimb, but the ones around here have variable conditions.
An autocross type tire is the most appropriate.
Other slicks take too long to warm up.
You could always check out what the competition is using.
sachilles is offline   Reply With Quote
Old 07-18-2007, 01:58 PM   #8
tora
Member#: 5851
09 Forester XT
+ NA Miata
Rally tarmac tire...?
tora is offline   Reply With Quote
Old 07-18-2007, 03:15 PM   #9
leecea
Member#: 37359
2003 WRX
I believe that autoxers in Prepared and Mod classes typically use slicks. Seems like they would need a lot of grip immediately. Not sure about the dust issue though.
leecea is offline   Reply With Quote
Old 07-18-2007, 03:21 PM   #10
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
Only reason I bring up the dust is the low-grip situation at the Solo2 Nationals last year and the P and M guys wishing for DOT-R tires.
Old 07-18-2007, 03:27 PM   #11
digitalseance
Member#: 104400
169k mile race car
1-2 minute runs? Definitely go with the A6s or v710s. A6s won't last as long but will provide slightly more grip over the v710s.
Size could be a determining factor as well. the v710s don't have as many options as the A6 does.
Anything longer than about 3 or 4 minutes, I'd look into some road racing compound as mentioned in previous posts (aka R6, RA-1s, etc).
digitalseance is offline   Reply With Quote
Old 07-19-2007, 01:49 AM   #12
adofly
Member#: 107693
2006 impreza Race
car 700hp
The longest race is 2.5 minutes, the shortest 55 seconds, so there is no time to warm up unless I use heater blankets.
The competition, i.e the fastest car, uses AVONS, but they use heaters to get them up to temperature.
However abient temps are quite high, 85-90F.
I wonder any of the Yokohama, Michelin or othe Super soft slicks wouldn't do the job?
Gruppe S Hankook Full Racing Slick/DOT R-COMP Tire Sale Gruppe-S Wheels/Tires 18 09-29-2009 07:36 PM
Slick Tires In Racing STI-C-YA Motorsports 14 05-11-2004 10:45 PM
F/S Hoosier Racing Slicks M Mid Atlantic Impreza Club -- MAIC 4 11-13-2003 11:45 PM
Race Slicks Dmitri Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-22-2002 05:46 PM
17" racing slicks ??? redbaron Brakes, Steering & Suspension 4 08-26-2001 10:20 PM
