Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 07-18-2007, 12:30 PM   #1
drift king
Member#: 26493
99 Impreza RSTI
Default whats better v5 sti 2.0 motor or 04 sti 2.5 sti motor?
i have to make a decision but i dont know what to go with .... the car will be used for daily driving and autocross. may be you guys can give me some pros and cons about both.
drift king is offline   Reply With Quote
Old 07-18-2007, 12:36 PM   #2
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
2.5l...this coming from a big fan of the 2.0's.
It's ALOT newer, more information on it, more powerful, etc.
I really don't see a reason to get an older V5 sti motor if you can afford doing an '04 STi 2.5l.
Hope this helps
Soon2Bgreat is offline   Reply With Quote
Old 07-18-2007, 02:04 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I would only go with the v5 STi if it was a matter of money. ECS is selling a v5 swap right now and it's dirt cheap, as in maybe a third of the price of an Ej257 swap...
Old 07-18-2007, 02:29 PM   #4
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Less money now, but more money later. Go with the 257.
The 257 has more torque for autox. Both would put you into a mod class.
I wouldn't buy a JDM 2.0l unless it was really really clean.
linsavy is offline   Reply With Quote
Old 07-18-2007, 06:52 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
For what ECS is asking for that swap, I would buy it, and immediately rebuild it with an Ej257 bottom end. Even without AVCS, those Ej207 heads outflow our USDM heads by quite a bit and can support way more power overall...
Old 07-19-2007, 09:11 PM   #6
drift king
Member#: 26493
99 Impreza RSTI
i have a 2.5l long block. should i just buy a 2.0 heads
Old 07-20-2007, 11:02 AM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
You have an Ej257 block? As in, STi turbo block? Or are you talknig about the Ej251 block that is in your car?
Old 07-20-2007, 11:03 AM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
ps. Your heads are as good as the JDM heads were are discussing. It's starting to seem like you just need to get an STi bottom end for your turbo kit and complete your build as an RS-T and not do a swap...
Old 07-23-2007, 09:57 PM   #9
drift king
Member#: 26493
99 Impreza RSTI
i have a 04 sti longblock. i dont wanna do a nother rs-t build.
Old 07-24-2007, 12:38 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
Even if you use DOHC it will still be an RS-T unless you do the wiring conversion to run the WRX/STi ECU. But call it what you want and do what you want with it. It is your car...
I will just close by saying that I know of a couple of 400whp cars running the SOHC EJ25 heads. Hitting 400whp on EJ205 heads is hard work without spending the money for cams and/or port work. It won't be cheap to get there and won't be any more reliable than it was with the SOHC heads. All you will really have is ricer's bragging rights to say that you have some of them dohicky heads in your car. But like I said, suit yourself...
Old 07-24-2007, 02:12 PM   #11
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
lmaoo
mxpunk is offline   Reply With Quote
Old 07-24-2007, 05:02 PM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
I can't claim that as original. It belongs to one of the authors of the old "Suck Squish Bang Blow" series of articles from SCC that has recently been published as a book by Motorbooks Inc...
Old 07-24-2007, 07:28 PM   #13
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
haha..so matt...am i a ricer if i build up a ej22e block using t-leg pistons and swap the sensors from my 1.8 intake manifold to a 98 rs manifold and use those dohc heads for a turbo engine build up?
i swear my impreza looks bone stock except for wrx wheels! it even has oem wrx exhaust on it!
Old 07-25-2007, 02:25 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
No because those DOHC heads are a major leap forward for your engine and it's performance. The OP just seems like he wants to change because he thinks the other heads are better when they really aren't and there will be a lot of brain ache to making them work properly. But hey, it's his car and one of the beauties of this sort of thing is that we can personalize however suits our interests and don't need to care what anyone else thinks. Just because I call it rice doesn't really mean a thing...
Old 07-25-2007, 03:32 PM   #15
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
dude i look up to you! it does mean a thing if its called rice..haha.
Old 08-02-2007, 02:22 PM   #16
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
hey, I think you got some **** on your nose...
Arctic Assassian is offline   Reply With Quote
Old 08-02-2007, 05:17 PM   #17
drift king
Member#: 26493
99 Impreza RSTI
ha, thanks for the info.......
Old 08-03-2007, 01:37 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
You are welcome. And check back with updates of what you do. Even if it's not the build I would do, I love a good build. Just because some people put me on a pedastal doesn't mean I actually look down my nose at you. I am genuinely interested...
Old 08-07-2007, 05:45 PM   #19
Arctic Assassian
Member#: 91875
91 legacy TD04
Old 08-07-2007, 07:19 PM   #20
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
that link was by far the biggest waste of time.....
hail2theTheif is offline   Reply With Quote
Do JDM 2.0 heads bolt right up to US Sti 2.5 block? IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-06-2012 12:01 AM
04 WRX 2.0 - TurboXS Stage II Mods - Just blew the motor - Cheap magillaTheGorilla Private Vehicle 'For Sale' Classifieds 0 06-24-2009 02:12 PM
02+ WRX motor or 04+ WRX STi Motor 555subaru Private 'Wanted' Classifieds 0 02-20-2007 09:33 PM
will 2.0 water pump, belts fit 2.5 block?? Suberman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-01-2006 12:58 AM
2.0 stock headers same as 2.5? myrx Newbies & FAQs 3 06-30-2006 01:19 PM
