Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 12-27-2001, 04:48 PM   #1
In2Deep
Member#: 10651
2013 WRX - Silver HB
04STI(sold) 06STI(sold)
Default WRC intake system
It's no secret that the Subaru WRC car uses the production models intercooler location as an air intake. I was just wondering if anyone was in the process of developing a system like it for the masses whom choose to go with front mounted intercooler set-ups. It would seem as if this particular system would work vastly better than CAI set-ups that draw air fron the fender-well.
Any thoughts?
In2Deep is offline   Reply With Quote
Old 12-27-2001, 04:59 PM   #2
wrx182
Member#: 9531
2002 WRX Sport Wagon
i thought the wrc had the front-mount intercooler and the sti oil cooler was up under the hood scoop....guess i was incorrect on that one.
an air intake system from the hoodscoop would be cool, although, i think it would be rather difficul to pull off - the wrc has the entire engine turned around in the car, just for reasons like this, and the reduced amount of piping for a front mount intercooler.....but the 2.5rs could easily do it, even the short ram intakes sit right behind the hood scoop.
wrx182 is offline   Reply With Quote
Old 12-27-2001, 05:00 PM   #3
jimb
Member#: 9923
2005 Legacy GT
RIP MBP WRX
Looks like a different intake manifold, not the entire engine turned around...
-jb
jimb is offline   Reply With Quote
Old 12-27-2001, 05:20 PM   #4
JenisonWRX
Member#: 6049
02 WRX & 99 RS
if you think water is an issue now...wait until that comes...
granted subaru has already delt with this...how...I have no idea...
but water shooting in your hoodscoop at 70 mph is going to have some effect. At least you only have to be concerned right now about puddles...
would need some bizzare filtering done...
JenisonWRX is offline   Reply With Quote
Old 12-27-2001, 05:31 PM   #5
trboCIVIC&WRX
Member#: 6426
jimb is correct, it is just the intake manifold that is "flipped"...
I dont think that it would be too hard to make a set up that takes the air from the scoop, it just depends on where exactly all of the FMIC pipes end up...
you just would have to figure out a way to filter out rain water, so the engine doesnt ingest it...
but, anything is possible. how much money you got?
(actually tho, this wouldnt be that expensive.)
trboCIVIC&WRX is offline   Reply With Quote
Old 12-27-2001, 05:39 PM   #6
p7r4e7y
Member#: 4261
2000 2.5 RSTI
www.ModernImage.net
aem bypass valve for the water issue. i imagine there wont be as much a mass of water water going in at one time, than there was in that nsx fish tank test from scc.
p7r4e7y is offline   Reply With Quote
Old 12-28-2001, 12:23 AM   #7
JimmyOOOOO
Member#: 12647
2011 STi
Obsidian Black Swirl
AEM bypas valve doesnt do JACk to stop puddle amounts of water... only full immersion... thats why it's a piece of crap
JimmyOOOOO is offline   Reply With Quote
Old 12-28-2001, 12:53 AM   #8
WRChris
Member#: 13418
blur
actually if your intake was only subjected to a large splash, or puddle amount as you say, then no water would make it up the intake tract, as there wouldnt be enough suction to pull it up. the only reason any water ever makes it up there is that when the filter is fully submerged the vacuum of the motor IS strong enough to pull that weight of water up the intake because there is no air with it.
WRChris is offline   Reply With Quote
Old 12-28-2001, 07:08 AM   #9
Shik
Member#: 132
2006 GT Ltd 5spd sdn
'15 WRX 6spd CWP, '02 WRX
As far as the WRC intake is concerned, it would be a bit difficult to replicate for the simple reason that the WRC Impreza's turbo is mounted laying on it's side, thus, the inlet is pointing straight up into the intake, not similar to ours which points to the front of the car.
Also, where's the MAF sensor going to go with such little room to work with. More trouble then it's worth.
Shik is offline   Reply With Quote
Old 12-28-2001, 01:09 PM   #10
mhj
Member#: 3057
I've always wondered about the WRC setup.....doesn't the hot air coming out from the radiator and IC just get sucked into the intake?
A little water in your engine is not bad as long as you let it dry before shutting off the car. Remember, these cars already have water injection to cool off those combustion chambers. For high boost, water is your friend.
In this case, the water would have to make its way into the filter, down the IC tube , through the IC, up and through the turbo, and up into the intake before getting into the TB. Hopefully, it'd be sufficiently atomized by then.
mhj is offline   Reply With Quote
Old 01-02-2002, 06:08 AM   #11
SDaWG
Member#: 9622
2002 Subaru WRX
Platinum Silver
anybody have anymore pics of the wrc engine/ic and radiator setup. because it has confused me to what part opf the bumper the ic is in and also the intake talk has intrigued (sp?) me to look at the wrc engine a bit better.
Shawn
SDaWG is offline   Reply With Quote
Old 01-02-2002, 03:21 PM   #12
In2Deep
Member#: 10651
Shawn, those types of pics aren't easy to come by for some reason. I'd like to see more myself. This one is straight from the SWRT's website.
Old 01-02-2002, 05:57 PM   #13
aov
Member#: 7193
MY02 WRX
subie gal posted some pictures a while back from Rally GB. There were some nice close-ups of the engine bay.
I think she said the hood scoop is closed. This might be so that hot air that has passed through the IC and radiator get sucked into the air intake. Not sure. Seems like the two hoses connected to the vents in the head lights would not supply enough air, so maybe they take air from the engine bay... ??
-anders
aov is offline   Reply With Quote
Old 01-02-2002, 09:22 PM   #14
In2Deep
Member#: 10651
Anyone have a link to those pics?
FS : 04 WRX DP. UP, Air Box Intake System, Alternator Cover Steeldon Engine/Power/Exhaust 13 01-27-2011 08:21 PM
WRC inlet system.. wimprezawrx Built Motor Discussion 31 04-22-2010 11:45 PM
**WTT: APS w/K&N intake for Stock Intake system*** jdmtech1 SCIC Private Classifieds 5 06-01-2009 04:25 AM
The WRC 4WD System Pakin Motorsports 45 05-18-2004 03:56 PM
Stock 01 RS exhaust system + air intake system davidlee Private 'For Sale' Classifieds 0 09-26-2003 08:49 PM
