Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 07-19-2007, 12:35 PM   #1
PolarisSnT
Member Sales Rating: (19)
Member#: 85905
2004 WRX
Default NY: Crucial Racing Ported and Coated Stock Exhaust Manifold
Sold.....
PolarisSnT is offline   Reply With Quote
Old 07-20-2007, 11:00 AM   #2
PolarisSnT
Member#: 85905
2004 WRX
Bump.
Forgot to add that the passenger side manifold is tapped for an EGT gauge. It is a 1/8NPT thread that I can plug if you so wish.
Old 07-20-2007, 07:17 PM   #3
Magnum626
Member Sales Rating: (40)
Member#: 62856
MBP SQC#197
Stockpiling parts...
So how did the car feel after you had it done?
Also, how much are you looking for?
Magnum626 is offline   Reply With Quote
Old 07-20-2007, 08:23 PM   #4
dire
Member Sales Rating: (12)
Member#: 86433
dibs, pm sent
dire is offline   Reply With Quote
Old 07-21-2007, 01:13 AM   #5
PolarisSnT
Member#: 85905
2004 WRX
I put these on and had a protune done at the same time. Car felt like it had faster throttle response and certainly spooled faster once above the boost threshold with the stock turbo. On my PE1820 when I had my TMIC I was making full boost by 3.7k in 3rd gear and as of now the car is putting down 340whp.
Im looking for $200 + shipping if needed which wouldnt be too bad as I found out that these will fit in a USPS flat rate box
Old 07-21-2007, 03:17 AM   #6
Magnum626
Member#: 62856
MBP SQC#197
Sounds like a great improvement. Hmm so it increased spool by about 200 would you say? Crucial PNPNC the xover pipe as well or do you have an aftermarket xover?
Old 07-21-2007, 03:11 PM   #7
PolarisSnT
Member#: 85905
2004 WRX
Yep. They did each collector and the stock cross over pipe.
Still for sale.
Old 07-21-2007, 07:54 PM   #8
Spenk
Member Sales Rating: (41)
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
I bolted a set of the Crucial manifolds onto my car along with a coated larger x-over, and the bottom-end improvement in power and spool was most impressive.
It got even better after the tune.
Spenk is offline   Reply With Quote
NY: Crucial Racing Ported and Coated Stock Exhaust Manifold PolarisSnT Engine/Power/Exhaust 7 02-26-2008 12:11 AM
Crucial Racing Ported and Coated Stock Exhaust Manifold PolarisSnT Engine/Power/Exhaust 0 07-19-2007 12:31 PM
Port and polished stock exhaust manifold info Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 115 01-31-2006 05:39 PM
port matching the stock exhaust manifold? shields102 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-28-2002 11:33 PM
Port matching the stock exhaust manifold? Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-07-2002 08:39 AM
