Old 07-19-2007, 12:58 PM   #1
bcmaxx
Member#: 154421
Default Subaru wheel studs problems???
Just wondering if anyone out there has had any problems with wheel studs?? I have seen them snap,stretch and back-off . There seems to be a high frequency of these problems and not model specific either. I have noticed that the part number for the stud has been superceeded more that a few times (from 28055aa000 to 28055aa001 to 28055aa002 and most recently 28015aa003). Does subaru know something we don't??
bcmaxx is offline   Reply With Quote
Old 07-19-2007, 01:13 PM   #2
Crawdads
Member#: 30907
SWP GDB-G
I would say that more than likely its "user error"...I have watched many a person WAAAAY over tighten their lugnuts...the torque spec is only ~70 ft lbs.
Crawdads is offline   Reply With Quote
Old 07-19-2007, 01:19 PM   #3
bcmaxx
Member#: 154421
I can rule out user error in many of cases, three techs with calibrated torque wrenches , and we torque before and after road testing.
Old 07-19-2007, 01:32 PM   #4
Getagrip
Member#: 2045
BRZ
I've autocrossed three of my Subarus in the past, that means lots of wheel swapping. Never had a problem with studs.
Getagrip is offline   Reply With Quote
Old 07-19-2007, 01:56 PM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I've seen non-subaru shops **** up subaru studs, but not the dealers.
Old 07-19-2007, 05:40 PM   #6
Chin
Member#: 632
'12 Cayman R
'07 UGM WRX Wagon
7yrs of AutoX in the RS, 4 of them swapping wheels and I have never had a stud problem. ...never even replaced one. Swap the winter wheels back and forth on the STi as well as normal maintenence and the such; never replaced a stud in >4yrs.
Chin is offline   Reply With Quote
Old 07-19-2007, 05:55 PM   #7
silver2004impreza
Member#: 127878
2004 Impreza 2.5TS
2004 Outback sedan H6
I've been working on cars "shadetree style" for easily half my life, and have been doing it professionally for the past 5, almost 6 years, and the only times I've ever had a stud snap was when the lugnut was cross-threaded during a previous installation. That's why I always start the lugnuts by hand before I use my impact gun with a torque extension to tighten them down. I've never had a stud break that I installed a lugnut on.
silver2004impreza is offline   Reply With Quote
Old 07-19-2007, 06:01 PM   #8
Big_DeWeY
Member#: 37078
95 L
Blue-ish
i had 2 snap on me on my EARLY 02 WRX. Not sure if that counts.
Big_DeWeY is offline   Reply With Quote
Old 07-19-2007, 10:44 PM   #9
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Yes, it is a problem.
I've replaced over a dozen myself. A good friend of mine (RenMaxi on this board) has replaced over half a dozen I believe.
Many times, it is user error. But I've always been very careful with them (never overtorqued them, threaded them by hand first before impacting them, etc.).
As far as I'm concerned, Subaru's drivetrain sucks past the CV axles. Their wheel bearings suck, their wheelstuds suck.
DerFahrer is offline   Reply With Quote
Old 07-19-2007, 11:13 PM   #10
merlot
Member#: 16935
2012 Volvo S60 T5
2013 VW CC R-Line
Why would you post this in New & Rumors? Doesn't anyone read the effen forum titles anymore????????????
merlot is offline   Reply With Quote
Old 07-20-2007, 09:40 AM   #11
Big_DeWeY
Member#: 37078
95 L
Blue-ish
i think because there were new part numbers for some of these parts. thats kinda news.
Old 07-20-2007, 09:53 AM   #12
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
20 years on the track and never a stud problem because of the stud. I had user-error issues on my wife's outback. Put on steel winter wheels and used the closed end nuts intended for the alloys. They bottomed out on the ends and I kept re-torqueing them and stripped a couple. My fault. Don't use an impact gun to even get the nuts started. Also, I find that using a thread chaser occationally on both the nuts and studs keeps them in good shape (chasers are slightly different from tap/die as they don't expect to have to cut new threads....I've got both types).
jack
Old 07-20-2007, 09:55 AM   #13
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Never had to replace one on my (wrx) Rally car....
and those wheels are on and off of the car 10 times a weekend during a race
The only time I ever had to replace them (on my Legacy)
is when I did not torque the wheel down properly.
Jamie
Old 07-20-2007, 10:20 AM   #14
Chin
Member#: 632
'12 Cayman R
'07 UGM WRX Wagon
....nor have I ever had to replace a wheel bearing...
Old 07-20-2007, 10:37 AM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Never had a problem with studs on any car with the exception of one local's EVO that got one crossthreaded.
As for wheel bearings - I'm on number 4 on the front left of the STi. I went with the very slightly beefier nissan bearing the last time, and it seems to be doing ok, but I still get a good bit of knockback. The 6Gun prototype 5x100 conversion kit I have here with the 05+ bearing should help that out once I get them on the car.
Old 07-20-2007, 12:00 PM   #16
MasterKwan
Member#: 98961
2003 WRX
I think it's significant that the people who have problems have LOTS of problems with studs and those that don't have problems don't have ANY problems. It points directly to a user issue. There doesn't seem to be a middle ground which is what you'd expect if it was an inherent problem in the design.
Old 07-20-2007, 12:07 PM   #17
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
+1
Its obvious some people here are just not doing it right
Old 07-20-2007, 05:49 PM   #18
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
of all the Subaru's we see, I have yet to see a single one.
blackfang is offline   Reply With Quote
Old 07-20-2007, 06:27 PM   #19
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Sorry just had to tease you.
BTW the other kits that have gone out are working beautifully; with the exception of the brake dust plates not fitting the 05 knuckles. I believe that they are only $30 so I am going to look into including them with the kit for the 5% of the folks out there that run them.
javid is offline   Reply With Quote
Old 07-21-2007, 12:02 AM   #20
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
Significant does not mean conclusive.
Old 07-21-2007, 10:56 AM   #21
MasterKwan
Member#: 98961
2003 WRX
You asked if there's a wheel stud problem. The vast majority of responders haven't broken a single wheel stud even though in many cases they swap wheels far more often then most people.
I think you can conclude that for the majority of people who responded, there is no issue with wheel studs.
Old 07-21-2007, 11:16 AM   #22
Rootus
Member#: 89821
2015 STI LE
In my limited experience, the studs seem strong enough. I'm an over-tightener by nature, and I'm willing to bet that I routinely apply well over 100 ft-lbs to the lug nuts . I also swap wheels all the time. I've never broken a stud, on this car or any other. If I'm not breaking them, I wonder just how much force some people are using. LOL.
Rootus is offline   Reply With Quote
Old 07-21-2007, 11:22 AM   #23
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I would like to know if the OP has been using any type of grease or anti-seize on the studs????
This increases the torque on the lugs by 20-50%
I've never snapped a lug stud on my 99'rs after countless installs... I HAVE stretched the studs AND broke out the tops of the lugs... using grease..
Old 07-21-2007, 12:49 PM   #24
MasterKwan
Member#: 98961
2003 WRX
Honda in their shop manual says specifically not to use Anti-sieze on the threads for that very reason. I typically go to 80 ft/lbs because that's the required minimum torque at most track events.
Old 07-23-2007, 01:09 PM   #25
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
anti-sieze does not increase the TORQUE on the stud.
Anti-sieze does increase the tension in the stud at a given torque.
LyveWRX is offline   Reply With Quote
FS(MD) 04 STI Springs, PIAA Bulbs, Subaru Wheel Studs! BoostInDuced Engine/Power/Exhaust 26 01-01-2011 02:15 AM
215/65/15 Studded snow tires with Subaru wheels Anhdalai NWIC Private Classifieds 6 10-25-2008 04:55 PM
Minor car problems - Wheel studs and CEL rkkwan New England Impreza Club Forum -- NESIC 6 08-18-2002 06:28 PM
stripped rear wheel stud problems eastbaysubaru Service & Maintenance 7 08-16-2002 01:52 PM
