Alaskan Impreza Club
Old 07-19-2007, 01:53 PM   #1
edo2000
Member#: 68709
2012 WRX
red
Default wrx alignment - advice?
My son has an 02 wrx with 130k miles on it. A rear strut failed about 18 months ago, and we had Conti replace it and do an alignment, but we didn't replace the other three. The car became noticeably out of alignment(drove poorly) a few months later so we took it back in. Conti had to add a camber plate to give enough adjustment to set it up correctly. It drives well now, but just a few months after the last alignment it is wearing tires unevenly and quickly. My son says he hasn't had any major curb encounters or anything else that should have tweaked the alignment.
My question: We're planning to take it to Conti for another alignment, but should we consider changing out the other three struts first? They're not showing any symptoms of failure like the one did (a loud clunk with every compression), but they obviously have a lot of miles. I have some fairly low mileage used ones that I can install.
Sorry for the long post. Any advice would be welcome. Thanks.
edo2000 is offline   Reply With Quote
Old 07-19-2007, 01:59 PM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
I'd change the other struts, at least the other rear one.
Mavrik is offline   Reply With Quote
Old 07-19-2007, 02:58 PM   #3
Firestrike
Member#: 135785
2006 Impreza WRX LTD
Cloaking Device Gray
The symptoms may only happen when on the roads, doesn't really mean you will see leakage. Yes, you should replace both of each end of car if you are going to do any at all. If one is healthy and strong, it will not dampen the same as the older ones and will cause unstable behavior when going down the road, causing uneven wear on tires.
Firestrike is offline   Reply With Quote
Old 07-19-2007, 03:56 PM   #4
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
go aftermarket on the struts if ur gonna replace them...someone in town has a set of kybagx's for ur son's bugeye...brand new even! (it's not me...but i do have a set on mine and really like them)
SQUAD_907 is offline   Reply With Quote
Old 07-19-2007, 07:38 PM   #5
edo2000
Member#: 68709
2012 WRX
red
Thanks, guys. Good info.
Old 07-19-2007, 07:49 PM   #6
Firestrike
Member#: 135785
+1, Call Tony @ FATS. 561-4721. Tell him Justin from Sterling sent you.
'06 WRX - need advice on rear alignment... Canonshooter Brakes, Steering & Suspension 11 03-04-2006 08:17 AM
Need alignment advice silver arrow Brakes, Steering & Suspension 5 10-14-2004 10:41 PM
Alignment Advice guinsu Tire & Wheel 3 05-27-2004 08:25 PM
Alignment Advice Needed whtlegacy Brakes, Steering & Suspension 5 03-30-2004 05:41 PM
Alignment advice needed! 748eric Brakes, Steering & Suspension 3 09-04-2003 05:52 PM
