Old 01-02-2002, 01:29 PM   #1
outback bosco
Member#: 12075
2K OBS blue/silver
Lobotomized 86 & 87 XT
Lightbulb headlights flickering
I am having a problem with my headlights on my 2k OBS
When I use the turn signals or hit the high beam, the lights sometimes turn off. Happened while I was driving back from the mountains on a really twisty road. Good thing I had driving lights on too.
But anyone ever have this happen to them? Is the turn signal/light switch messed up?
BW
outback bosco is offline   Reply With Quote
Old 01-02-2002, 08:19 PM   #2
stikboy
Member#: 6697
2011 WRX 5-door
Look-At-Me Red
Default not a problem
my car did this at first when i got it. you probably are just accidentally rotating the light switch when you use the brights or turn signal. you just have to be careful when you do either. if you are sure that this isn't it. get your car in immediately, this is a dangerous problem.
stikboy
stikboy is offline   Reply With Quote
Old 10-18-2005, 02:05 AM   #3
Impreza_RX
Member#: 68015
2006 WRX TR
Steel Gray Metallic
I know this is a very old post, but has anyone else experienced this problem as well? I'm getting the same problem and just want to know if there are others that are having the same issue. Thanks
Impreza_RX is offline   Reply With Quote
Old 10-18-2005, 02:27 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This is usually caused by a bad combination switch.
Old 10-19-2005, 07:38 AM   #5
robsgotit
Member#: 59674
06 06/2.5i 03/1.8t
there silver
my 01 forester does that constantly, as were my 02 rs doesnt evr do it,
i think my switch is just worn, but if your car is new its probly just driver error, (no offence) its a dumb design
robsgotit is offline   Reply With Quote
Old 10-20-2005, 10:58 AM   #6
blackie
Member#: 42979
03 wrx
blizzzack stage IV
my 03 wrx does that too!! it seems like their is a bad conection in the blinker stalk switch. but other times it will be fine, so im still confused on what it can be, i can hear the relay clicking louding behind the glove box whenever its acting up. any ideas??
blackie is offline   Reply With Quote
Old 12-06-2005, 08:54 PM   #7
japakazol
Member#: 67831
2010 WRX Sedan
Spark Silver
Default Wiring issues.
Someone please answer this thread. I've looked around and can't find a fix and I am out of warranty.
japakazol is offline   Reply With Quote
Old 12-07-2005, 03:13 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
yup, 99 times out of 100 it is a faulty combination switch. They definitely aren't marvels of modern science...that's why i keep a spare around just in case.
jeremy
Headlight flicker? Subie_Sleeper68 Baja Forum 25 12-19-2010 01:37 AM
Headlights flickering when using turn signals Honest Bob Electrical & Lighting 0 04-05-2009 08:10 PM
Headlights flicker when turn signal is applied Aspenbullet Electrical & Lighting 6 07-16-2007 03:46 AM
headlights flicker with left turn signal EPskate Electrical & Lighting 1 03-26-2007 09:42 PM
My signals make my headlights flicker! squeech Electrical & Lighting 10 05-23-2005 12:23 AM
