Old 07-19-2007, 11:13 PM   #1
rey_vibora
Member#: 59089
2013 WRX
Question Reflash Question???
Will disconnecting the battery for a full day remove an ECU reflash? and put me back to original?
rey_vibora is offline   Reply With Quote
Old 07-19-2007, 11:35 PM   #2
Tea cups
Member#: 103136
There's no "original". When you reflash the ecu it is permanent until you reflash again. You could pull the ecu out of the car and put it in your closet for a month and the flash would remain. This is assuming you are talking about reflash like that from Ecutek, Cobb (base map) or Ecuflash (open source).
Tea cups is offline   Reply With Quote
Old 07-20-2007, 03:48 PM   #3
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
in short words, disconnecting the battery will make the current flash on your ecu revert back to its defaults, it basicly loses all of its learning it has done.
t4nk is offline   Reply With Quote
Old 07-20-2007, 05:37 PM   #4
Foska Oats
Member#: 144081
2003 WRX
Your ecu was flashed, so your new map will be stored in your ECU. So disconnecting your battery has no effect on that.
Look at it as your home PC. When you plug out you rPC, all yoiu files are ok whna you plug it back it.
It works the same way.
Foska Oats is offline   Reply With Quote
Old 07-20-2007, 05:39 PM   #5
t4nk
Member#: 129905
2005 WRB WRX
that is possibly the best comparison ive seen so far, kudo's!
Old 07-20-2007, 07:53 PM   #6
Foska Oats
Member#: 144081
2003 WRX
Thanks bro.
Cobb reflash and dealer reflash question battosai Bay Area Impreza Club Forum -- BAIC 0 09-11-2003 11:23 PM
vishnu reflash question 02WRXman Engine Management & Tuning 2 05-21-2003 09:20 AM
ecu reflash question bruce cohen Engine Management & Tuning 2 04-10-2003 09:33 PM
Sub-Zero reflash question Chrisnonstop Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-03-2003 11:17 AM
UTEC and ECU reflash question. davidm_sh Engine Management & Tuning 4 10-18-2002 06:21 PM
