Old 07-20-2007, 12:46 PM   #1
snowboardr424
Member#: 129943
2008 SS FXT LTD 5MT
03 SY WRX Wagon Sold..
Default No interior lights...need some help
I've got a 99 Outback and have been messing around with the fog lights to have them come on w/ the parking lights. With some trial & error i wired them the way i wanted, buttt now my interior lights i.e. gauge cluster, a/c controls, fog, cruise and rear defroster do not light up. I checked all the fuses, they all appear to be okay. I did see the wiring harness plugged into the illumination box under the steering column which also should be good. Any ideas, comments? Thanks guys!
Kevin
snowboardr424 is offline   Reply With Quote
Old 07-20-2007, 04:59 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Check the relay and fuse panel under the hood for a blown fuse.
Old 07-20-2007, 05:17 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I'm betting your tail lights don't light up either.
You've got a short under the dash somewhere. Not sure about your year, but on mine there were two fuses. One under the dash, and one under the hood.
Old 07-21-2007, 10:37 PM   #4
snowboardr424
Member#: 129943
2008 SS FXT LTD 5MT
I wired everything back to stock, no short, no nothing. I kept blowing the 20 amp lighting fuse under the hood but i put a new in and its good. I am guessing that it's that illumination control box on the panel under the steering column, any thoughts/conformations? Thanks guys!
Old 07-22-2007, 10:58 AM   #5
Cougar4
Member#: 53443
Winestone
If the dash lights are the only thing left not working then I would say you are correct in thinking that the light control module has a problem.
need some help in DFW: brakes/tail lights no workie (cash, beer, food) haloseven Texas Impreza Club Forum -- TXIC 4 09-21-2008 07:30 PM
Help! No interior lights, no radio, no alarm, no temp sensor; NOT fuses Stray Cat Electrical & Lighting 6 07-04-2008 02:32 AM
Okay, I need some help with an interior swap ScoobyBlack Interior & Exterior Modification 5 01-07-2007 10:49 AM
LHD STi lights, need some help norseone Interior & Exterior Modification 20 12-14-2002 09:31 PM
('93-'01) Installing a Shift Light, need some help please. SUBYRS710 Impreza Forum 10 07-25-2001 03:09 PM
