Old 07-20-2007, 01:53 PM   #1
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
Default Using Tactrix Cable for OBD2 Scanning...
What programs do you guys use to pull/reset codes with Tactrix cables? I can datalog & reflash with ECUFlash or Enginuity, but no matter what OBD2 programs I try (Including Scantech 0.77), I cant get it to connect...
nperkins is offline   Reply With Quote
Old 07-20-2007, 03:45 PM   #2
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
ecuexplorer.
t4nk is offline   Reply With Quote
Old 07-21-2007, 11:08 PM   #3
MIKE DD
Member#: 106818
2003 Truck
you just want to see the code or you want to shut it off?
engiunity will let you do both, but i belive you have to reflash the ecu with the error code turned off if you want to get rid of it that way.
MIKE DD is offline   Reply With Quote
Old 07-21-2007, 11:20 PM   #4
t4nk
Member#: 129905
2005 WRB WRX
ECUexplorer is best for pulling tripped cel codes. and yes enginuity can disable any cel, and does require a reflash.
Old 07-22-2007, 09:32 AM   #5
Tea cups
Member#: 103136
You have to be careful using Ecuexplorer as if your particular ecu's CEL mapping isn't specifically defined by Ecuexplorer then it will show the incorrect codes. Only a true obdii scanner can be relied upon to give you the correct code in all cases. There's a freeware one that the Evo guys use that supports the tactrix cable ( somewhere on www.activematrix.com ), but I could not get it to work on my 02 wrx. Ecuedit (shareware) supposedly supports obdii but I'm not sure how well it works for Subarus.
Tea cups is offline   Reply With Quote
Old 07-25-2007, 08:54 PM   #6
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
I could never get ECUExplorer working correctly for anything...
I use Enginuity to disable CEL's, but I just want one to read & turn off CEL's... I'm tempted to buy a hand scanner... A buddy has a TINY ASS matco one that is only $70.
Old 07-25-2007, 09:45 PM   #7
Freon
Member#: 88322
2009 BMW 135i
Ecuexplorer is flaky for reading codes. I use a real, standalone code reader because I know it is just standard OBD2 and it works correctly every time.
Freon is offline   Reply With Quote
recommendations for OBD2 scan tool daprez Service & Maintenance 4 09-19-2011 03:50 AM
Pittsburgh- Will pay to use a Openport/Tactrix cable for a couple min! vexixx Mid Atlantic Impreza Club -- MAIC 0 01-20-2009 07:10 PM
cant connect using tactrix cable slvrwrx03 Commercial ECU Reflashes 9 09-25-2007 09:46 PM
Go for OBD2 scan? Ging Canada Region Forum 8 01-27-2005 07:55 PM
Looking for OBD2 scanning software for sti TurboPhoon Engine Management & Tuning 1 11-11-2003 06:06 AM
