Old 01-02-2002, 05:27 PM   #1
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
Angry 2000 miles and Im already a quart low!
I just checked my oil, after letting the car sit overnight, and I am (at least) a quart low of oil! Could the car be burning oil already or did it probably just come underfilled from the factory? (I babied the car during break in)
Are there any long term implications of running low oil during the important break in period? (my car is at 2000 miles now)
thanks
elgorey is offline   Reply With Quote
Old 01-03-2002, 08:43 PM   #2
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Good idea to go ahead and change your oil at 2k. Just keep a close eye on it. It is possible to be a little low from the factory. Did you check your oil as soon as you took delivery? I happened to notice my tranny fluid was about a 1/2 qt. low. at 5 mi. dealer topped it off and it hasn't changed since. So it was a little low from the factory. I've heard GM thinks 1qt. loss every 1000 mi. is considered "acceptable" I wouldn't accept that though.
mr2guru is offline   Reply With Quote
Old 01-04-2002, 01:26 AM   #3
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
On my former 6 year old Legacy the dealer said 1 quart per oil change was not uncommon for a car with 100k miles. I gather RX-7s use a fair amount more than that due to the design. It all depends on the car, mileage, etc. But a new Subaru shouldn't be burning any oil.
CosmoTheCat is offline   Reply With Quote
Old 01-04-2002, 02:37 AM   #4
topcover
Member#: 8999
2002 EJ25 FXT Wagon
Platinum Silver, Stage2
Not to shed a bad light just throwing out some questions if you didn't already check them off your list. I'm sure there are a lot of other technical questions out there but these just came to mind.
1. Did you change the crush washer at the same as the filter?
2. It the crush washer on snug and the oil filter on tight (not too tight)?
3. Did you measure the oil level immediately after your oil change before you started the car or after?
If your drain plug or oil filter is losing just a few drops of oil at any given time, you may never notice the leak as it "burns" off as you drive.
Good luck, hope nothin's wrong with the car.
topcover is offline   Reply With Quote
Old 01-04-2002, 08:57 AM   #5
elgorey
Member#: 4374
06 Titan,99,94 SM
I didnt check the oil when I first bought it I thought about it, but I assumed that Subaru knows how much oil to put in their own cars I guess not.
To answer your question topcover, it has not had an oil change yet, so none of those should be issues.
Old 01-04-2002, 01:11 PM   #6
topcover
Member#: 8999
2002 EJ25 FXT Wagon
Whoops, thought you changed your oil and had this problem. I'm sure my parents would like to know that all the money they spent on my education allowed me to read really good!
I wouldn't worry unless you changed your oil and you continued to experience oil loss. At least you would have had control over your environment.
Old 01-04-2002, 03:14 PM   #7
CosmoTheCat
Member#: 3409
98 My FMIC
Oh. Duh. You're supposed to check the oil when it's warm. Go for a drive, park the car and let it sit for ten minutes or so, then check it. It'll be a bit higher most likely.
That's why it's a good idea to check it when getting gas. The time it takes you to pump the gas allows the oil to flow back down and collect in the pan. Also, most all gas stations have flat fill-up areas.
Old 01-04-2002, 03:25 PM   #8
elgorey
Member#: 4374
06 Titan,99,94 SM
oh ok. hrm....why didnt I know that?
I thought that you were supposed to let the car sit for a while to let the oil drain back into the pan because that is where the dipstick takes its readings from? I guess not
Old 01-04-2002, 04:53 PM   #9
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
make sure the oil filter isn't leaking, changed mine twice w/subaru filter, both leaked. filter was leaking at 100 miles from factory. dealer told me it was common w/aftermarket filters. I don't see a difference since subaru doen't make their own filter anyway.
Stealthbmbr is offline   Reply With Quote
Old 01-04-2002, 08:05 PM   #10
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Here is a video showing you how to check the oil level:
http://www.gmgoodwrench.com/dhtml/se...e/checkoil.mov
You get the most accurate reading if you check the oil level first thing in the morning before start up since the majority of the oil will be in the pan.
Richard
Richard L. is offline   Reply With Quote
Old 01-04-2002, 08:39 PM   #11
jayded6
Member#: 8306
2002 WRX Wagon
Hello,
I'll throw in my experiences here: I've been just over 1/2 quart low every 3,000 miles.. I was worried about this but the tech at the dealership says this is normal for our boxer engines, in fact he says every wrx he services goes through some oil. The owner's manual even says that even up to 1 quart every 1,000 miles is within specs. So, unless you see smoke, smell burning oil, or see drips in the driveway, I think you are just experiencing normal loss (probably a bit low to start with). I would check your oil every 500-1000 miles to be safe, and that way you can also estimate when you might need to add some.
I've now got 7500 miles on mine and it seems like it is going through less as time goes on.
BTW, I haven't seen too many people on here report oil loss, but the tech at my dealership says its normal (I hope he's not blowing smoke ). I guess we'll both see...
Jay
jayded6 is offline   Reply With Quote
Help save my back..Im driving 2000 miles in a bugeye vision.dynamix General Community 27 01-13-2010 11:57 PM
'03 Cobra vert, low miles and low price Kegger Private Vehicle 'For Sale' Classifieds 11 04-24-2008 11:14 AM
$2k to spend and Im already heavily modified.... jdiddy General Community 103 08-16-2006 12:10 PM
2 quarts low at 4000 miles! fastwrx Service & Maintenance 27 12-14-2005 10:08 AM
