Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 03-12-2001, 02:04 PM   #1
Rusty
Member#: 4769
01 RS 2.5
Post Mod Friendly dealers?
I was wondering if anyone knew if the dealerships around Ottawa are mod friendly. I'm thinking of putting in a better intake but I don't want to get black listed by the dealership. Any suggestions?
Rusty is offline   Reply With Quote
Old 03-12-2001, 05:44 PM   #2
Skeandhu
Member#: 1056
Post
I changed my intake to the "GanzFlow" style and didn't have any problems at Ogilvie.
I'm still using the stock airbox though - don't know if there would be any problem with the Weapon-R style.
Hope that helps!
Kevin.
Skeandhu is offline   Reply With Quote
Old 03-12-2001, 06:45 PM   #3
edekker
Member#: 143
1999 Impreza 2.5RS
Supercharged - and STOLEN
Post
Lachute Subaru – probably the most mod friendly Subaru dealer in all of Canada.
They will warranty most of the mods – even a MAF failure on a custom intake. http://www.lac-ss.com/hauteperformance.html
They’re not in the Ottawa area, but not that far away – well worth the 1-1/2 hour drive.
Good luck,
Ed.
edekker is offline   Reply With Quote
Old 03-13-2001, 05:44 AM   #4
Skeandhu
Member#: 1056
Thumbs up
Yup, I have to agree with Ed. Lachute is the most mod-friendly (and all-round excellent service dept!).
But hey, for a dealership running two rally cars (well, at least one this year) you can expect them to be a little sympathetic!
They're a bit of a drive away (as Ed mentioned), but well worth the trip.)
Old 03-13-2001, 06:31 PM   #5
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Post
hey Rusty,
Most dealers are mod friendly in Ottawa... I've done my struts, sway bar, solid links, rear camber bolts at Subaru Lachute...
All three dealers (Ogilvie, Westboro and Gatineau) sponsor the ottawa club and most mods are warranty friendly... such as exhaust, suspension, etc...
Westboro service manager (Aron Gabor) is a club member of the National Capital Subaru Club...
It all depends on what you do to your car...
ex... if you put 85/110w bulbs in your headlights and then you melt your wiring... you'll be responsible for the damage...
For your car, what type of intake are you planning to install?
Robin
co-founder NCSC www.ottawasubaru.com
[This message has been edited by Robin2 (edited March 13, 2001).]
Robin2 is offline   Reply With Quote
Old 03-14-2001, 08:13 AM   #6
Rusty
Member#: 4769
01 RS 2.5
Post
I was looking at installing a cold air intake running to the inside fender on the passanger side. I have been considering a "Larry's Intake" that I have seen here. My concern is where the fender gets it's air. I know there are little holes that feed into the fender from the engine bay, but if there is no intake from outside it does not seem to be effective since I would be sucking in hot air. I might as well just run an open pipe to middle of the engine bay, with the opening facing to side to reduce water intake from the hood vent or splash up. It would also be cheaper, since I would only need a K&N filter and a modified high temp plastic pipe. Any ideas?
Old 03-14-2001, 09:58 AM   #7
99TS
Member#: 846
Post
You can always put a plug in that hole. I did. Its really really cheap as well (~$6.00). If you need the part #, let me know.
99TS is offline   Reply With Quote
Old 03-15-2001, 12:36 AM   #8
Skeandhu
Member#: 1056
Exclamation
I'm currently running the "GanzFlow" intake with K&N Filter and have not encountered any difficulties (nice sound too!)
Cost wise, Final Lap in Orleans (shameless plug ) has been able to put together a GanzFlow-style intake and K&N Drop-In filter combo for <$200 CDN (for NCSC members). For comparison, I paid $170 CDN after shipping / duties / exchange for the just GanzFlow pipe and fittings!
If you're going to run with a pipe into the engine bay, you might as well stick to the same area as where all that plastic garbage is next to the passenger-side fender. Some on this board have gone so far as blocking off that area from the enine bay, then installing a scoop on the passenger-side hood vent!! (Just a thought )
edit: finger trouble
[This message has been edited by Skeandhu (edited March 14, 2001).]
('93-'01) Mod friendly dealers in Danbury CT area? Tweek!!! Impreza Forum 0 04-25-2001 08:36 PM
Mod-Friendly Dealers Youngun Tri-State Area Forum 4 03-05-2001 06:41 PM
mod friendly dealers #522 South West Impreza Club Forum -- SWIC 5 12-05-2000 10:50 AM
Mod-friendly Dealers donjuan Mid West Subaru Owners Club Forum -- MWSOC 5 11-14-2000 04:26 PM
Mod Friendly dealers in PA area Rubasu General Forum Archive 5 06-28-2000 03:36 PM
