Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 07-21-2007, 02:16 AM   #1
Clark Kent
Member Sales Rating: (30)
Member#: 75682
2004 WRX
Default FS: Butler Audio Tube Driver Blue Amp for cheap plus other audio stuff!
EDIT: FINAL PRICE REDUCTIONS! OTHERWISE I KEEP!
I have a Butler Audio Tube Driver Blue high end amp for sale. It is the TDB 475. This is a vacuum tube driven amp that is probably one of the best in the world. I purchased for $899 plus shipping. This is about 6 months old. I will sell for $499 shipped. NOW $399 SHIPPED
Any audiophile will know what this amp is, I don't need to say much more!! Hard to find used because ppl keep them!
Amp is in perfect condition, I should have wiped down before I took pics, but any marks on pics were removed by a gentle cleaning after I took them. These pics show the dust in all its glory, haha
Next up:
Blaupunkt 12" Sub, model ODw1200HP 800w peak, 460 RMS. These go on ebay for $180 plus $30ish to ship, selling mine for $110 shipped including paypal fee. NOW $80 SHIPPED!
4 gauge power wires for sub, RCAs, power blocks, etc. Everything needed to wire a sub amp, and a 4 channel amp for door speakers. Comes taped, loomed, with fuses. Don't remember what I paid, hows $50 shipped? NOW $45 SHIPPED!
CK
Here are the specs from Butler:
TDB 475
T H E R M I O N I C
Vacuum Tube Driven Mobile Power Amplifier
DESIGN
With authentic Vacuum Tube response and an open-ended design, (ZERO global negative feedback), Tube Driver BLUE overcomes one of the most universally agreed upon sonic problems plaguing virtually all current amplifier designs; harsh degenerative feedback causes a plethora of undesirable sonic products. Tube Driver BLUE eliminates global negative feedback entirely! Coupled with a totally unique output load mirroring circuit, the hand selected 6SL7GT twin triode tubes operate in a safe, near plate-saturated mode continuously. The design creates the ideal electrical environment for classic vacuum tube thermionic characteristics.
PERFORMANCE
Tube Driver BLUE amplifiers utilize natural vacuum tube thermionic emissions to automatically enhance biasing of the audiophile-quality Sanken bi-polar devices used in every model. This unique USA patented design reduces both Crossover and Total Harmonic Distortion (THD) figures to LESS than 0.15%. This achievement is almost unheard of in an open-ended, ZERO negative feedback high fidelity amplifier. Conventional open-ended/low feedback vacuum tube amplifiers often exhibit real world THD of 2% or greater and are generally limited to quite low output power. Tube Driver BLUE succeeds in operating at 10 times less THD while maintaining real power vacuum tube tonality! Now you can hear the original pure essence of vacuum tube audio with Tube Driver BLUE.
PROTECTION
All this performance must be effectively controlled. The exceptional electrical design of the Tube Driver BLUE, coupled with a MASSIVE aluminum heat exchanger and heat sink, provides protection and cooling capacity far in excess of any contemplated needs. A long life, temperature-controlled cooling fan is activated if the surface temperature exceeds 50 C, keeping heat stress well within safety levels. Additionally, DC fault protection with soft start (10-15 sec) and a fully regulated DC tube-heater supply circuit protect your Tube Driver BLUE amplifiers in every conceivable way.
General features:
• ZERO negative feedback. No global negative
degenerative feedback loop
• Open Ended Audiophile Circuitry
• Musical, warm and dynamic, rivalling "all-tube" single-ended home audiophile amplifiers
• Hand selected/matched 6SL7GT Twin Triode tubes
(One per channel)
• Fully regulated Tube Heaters with Delayed Soft Start
(10-15 second turn-on delay)
• Load Adaptive Vacuum Tube Driven output circuitry
• Massive (400% oversize) internal/external Heat Exchanger with Temperature-controlled Fan Cooling
• Tightly regulated MosFET Power Supply
• DC fault / Short Circuit Protection Circuitry
• Dual Color Diagnostic LED: Green=Normal / Red=Fault
• Gold Plated RCA, Power and Speaker Connectors
• Frosted Platinum finish
• Tube Illumination: Internal BLUE LEDs
• Patented Design
• Concept & Design: BK Butler / USA
Specifications:
• Rated Power (all channels driven):
4 x 75 Watts RMS per channel @ 4 ohms
2 x 75 Watts RMS and 1 x 200 RMS @ 4 Ohms simultaneously
2 x 200 Watts RMS Bridged (2-channel) @ 4 ohms
• 2-Ohm Stereo, 4-Ohm Mono Stable
• Freq response: 5Hz to 100kHz (+/- 1dB)
• THD: <0.19% (30kHz bandwidth)
• S/N Ratio: >105dB (A-Weighted)
• Idling Current: 3.5 Amps
• Input Sensitivity: .450v - 12v RMS
• Fuses: 2x30A ATC
• Dimensions: 10.25"W x 20.5"L x 2.4"T
• Weight: 14 Lbs.
Clark Kent is offline   Reply With Quote
Old 07-25-2007, 07:54 PM   #2
Clark Kent
Member#: 75682
2004 WRX
bump!!!
Old 07-31-2007, 11:07 PM   #3
Clark Kent
Member#: 75682
2004 WRX
bump!!!!!
Old 08-05-2007, 07:44 AM   #4
Clark Kent
Member#: 75682
2004 WRX
bump!!
price lowered on the amp from 599 to 499!
Old 08-05-2007, 10:48 AM   #5
MATT0404
Member Sales Rating: (13)
Member#: 85765
Where are you located? I am interested in the sub.
MATT0404 is offline   Reply With Quote
Old 08-06-2007, 08:58 AM   #6
Clark Kent
Member#: 75682
2004 WRX
PM'd you back!
Bump!
Old 08-06-2007, 09:58 AM   #7
eds2006
Member Sales Rating: (6)
Member#: 146685
Pmed You Get Back To Me When You Can.
eds2006 is offline   Reply With Quote
Old 08-06-2007, 11:59 AM   #8
Clark Kent
Member#: 75682
2004 WRX
PM'd everyone back!
As an FYI for everyone, the Butler AMP is NOT supposed to power an amp, its meant for powering your doorspeakers, as you will be AMAZED at the sound quality. While you can power a sub, you are doing this amp an injustice!
Old 08-07-2007, 11:10 AM   #9
Clark Kent
Member#: 75682
2004 WRX
bump!!!
Old 08-08-2007, 10:58 AM   #10
Clark Kent
Member#: 75682
2004 WRX
bump!
Old 08-17-2007, 05:13 PM   #11
Clark Kent
Member#: 75682
2004 WRX
bump!!!
Old 08-18-2007, 12:11 PM   #12
Clark Kent
Member#: 75682
2004 WRX
bump!!
Old 08-19-2007, 10:34 AM   #13
Clark Kent
Member#: 75682
2004 WRX
bump!!
Old 08-20-2007, 08:55 AM   #14
Clark Kent
Member#: 75682
2004 WRX
to the top!!
Old 08-21-2007, 07:56 AM   #15
Clark Kent
Member#: 75682
2004 WRX
bump!!!!
Old 08-24-2007, 09:05 AM   #16
Clark Kent
Member#: 75682
2004 WRX
bump!!!
Old 08-25-2007, 09:10 PM   #17
Clark Kent
Member#: 75682
2004 WRX
i'll sell the head unit, sub and wires for $200 shipped!
bump!
Old 08-27-2007, 02:08 PM   #18
Clark Kent
Member#: 75682
2004 WRX
to the top!!
Old 08-29-2007, 08:10 AM   #19
Clark Kent
Member#: 75682
2004 WRX
bump!!
Old 09-02-2007, 09:44 PM   #20
Clark Kent
Member#: 75682
2004 WRX
bump!!
Old 09-06-2007, 10:12 AM   #21
Clark Kent
Member#: 75682
2004 WRX
bump!!!!
Old 10-14-2007, 04:39 PM   #22
Clark Kent
Member#: 75682
2004 WRX
bump!!!
Old 11-07-2007, 11:22 AM   #23
Clark Kent
Member#: 75682
2004 WRX
bump!!!
Old 11-14-2007, 12:50 PM   #24
Clark Kent
Member#: 75682
2004 WRX
bump!!
Old 03-09-2008, 10:57 AM   #25
Clark Kent
Member#: 75682
2004 WRX
bump!! headunit sold, everything else still available!
FS: PA Butler Audio TDB 475 tube amp for cheap! Clark Kent Interior/Dressup/Audio & Security 52 07-28-2011 11:59 AM
Outfront Motors Fuel Rail+injectors for EJ20K manifold, PLUS other EJ20K Stuff bicanek Engine/Power/Exhaust 2 08-22-2010 09:55 PM
FS: Awesome JL Audio Sub, + an amp for CHEAP! TheSilverFox TXIC Private Classifieds 22 03-17-2010 05:31 PM
FS: stock td04 turbo and ebay TMIC kit with y-pipe plus other oem stuff JasonLI25T Engine/Power/Exhaust 16 03-04-2009 01:48 AM
STi UTEC for sale plus other stuff adesso Private 'For Sale' Classifieds 12 12-31-2004 11:07 AM
