Old 01-02-2002, 07:32 PM   #1
minx
Member#: 13279
1999 Impreza 2.5 RS
Silverthorn Metallic
Default Erratic Idle??
I have been experiencing some strange things lately. While idleing or driving my car will occasionally have a small dump in power. I have watched the RPM gauge and notice little or no change to the level when this 'dump' happens. I have not taken it to the dealer yet cause I wanted to see what I could come up with from ya'll. I have a MY99 2.5RS, no mods. (yet!)
My questions are:
1. What could be causing this?
2. Has anyone else experienced this?
3. I know the dealer would check it out for free under my Powertrain warranty (i think?) But would they fix it for free too?
I searched under several items here but found nothing to assist me.
Thanks!
Brandee
minx is offline   Reply With Quote
Old 01-02-2002, 08:13 PM   #2
stikboy
Member#: 6697
2011 WRX 5-door
Look-At-Me Red
Default Power loss
If it is still under warranty, have it checked out. It will be an engine problem. Second, it may be a clogged fuel injector, clogged fuel filter or a poor air filter. Dump some cleaner into your tank and check your air filter and fuel filter. Your problem should turn up there.
stikboy:monkey:
stikboy is offline   Reply With Quote
Old 01-02-2002, 08:46 PM   #3
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
My 99 RS started to idle and act a little wierd when my spark plugs were getting really worn. How many miles are on your car? If you are near 30K, the plugs might be the problem. I bought the NGK plugs specified in the owners manual and my car ran better than new! Also check the things in the previous posts. The injector cleaner and a fresh tank of gas couldn't hurt. Hope I was of some help!!
Keith99RS is offline   Reply With Quote
Old 01-02-2002, 10:23 PM   #4
minx
Member#: 13279
1999 Impreza 2.5 RS
Will do! Thanks gang.
I am outside my regular warranty, (powertrain is all I've got) so I think I'll call the dealer and see what they can do. If they act funny I'll go through the things you mentioned.
Hell, I might just take care of it by myself, I love to tinker.
B
Erratic idle @..... idle. SilverBullet2.5RS Normally Aspirated Powertrain 7 06-24-2006 03:07 AM
Erratic Idling GM02WRX Warranty Issues & SOA Problems 4 03-30-2002 01:54 AM
Erratic Idling?....? wrx182 Factory 2.0L Turbo Powertrain 3 10-15-2001 04:00 PM
91 legacy = erratic idle moyama Legacy Forum 2 08-26-2001 12:02 AM
Erratic idle when cold Peaty Normally Aspirated Powertrain 3 05-21-2001 08:41 PM
Message Board Statistics All times are GMT -4. The time now is 04:33 AM.
