Old 07-21-2007, 02:03 PM   #1
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
Default blue smoke out of tail pipe after car sits for 48+ hours.
Noticed this twice now. If my WRX has sat for around 2 days or so there is a good bit of blue smoke that comes out of the tail pipe upon start up. It doesn't last long usually just one big puff when I first drive off, and then no more. Aside from that, I am buring about 1 quart between oil changes ( every 3000 miles)
Can anyone shed some light on this for me?
Slowsoul is offline   Reply With Quote
Old 07-21-2007, 02:14 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Turbo is probably leaking a small amount of oil into the exhaust when it is sitting. Considering how old your car is, it could be normal but I am not sure how many miles you've got.
Old 07-21-2007, 04:46 PM   #3
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
try a thicker weight oil like 10/30 or 5/40 if your burning oil.. and maybe change brands see if that helps. what are you running now?
the blue smoke thing could be the turbo or the engine. and if you have high mileage its kinda normal i guess. ive seen it happen with my old stock engine plenty of times. but i did blow my turbo so it could have been the turbo.. sometimes they work for a long time before they actually break or give you issues but will leak alittle oil or coolent for who knows how long. mine lasted months like that with weekends at the drag strip! if i drove just to get around it probably would have lasted longer
PaulRex is offline   Reply With Quote
Old 07-21-2007, 07:58 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
when your car sits fpr prolong periods, 2 days.
the oil left in the cylinder pools at the bottom.
at start up the oil is burned...
1 quart every 3k is not to bad, just keep an
eye on your dip stick..of course if you drive hard
the more you consume..my 02 would take about
1/2 quart every 3k~4k
Old 07-22-2007, 11:52 AM   #5
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
There are 84k miles on the engine. I am running 10w40 Mobil 1, I am looking for a new oil...probably end up with motul 8100.
I was pretty sure that it wasn't anything to worry about, and I was actually wrong about amount that I said it it is burning, I actually only put in a 1/2 quart every 3k...so it sounds like things are normal.
Thank you for the responses.
Old 07-22-2007, 04:40 PM   #6
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
Maybe "beginning to wear out" piston rings or valve seals.
That would result in more oil then normal entering the cilinder, and burning off when u first start the car.
An engine in perfect condition won't do this, because the oil film normally present on the cilinder walls is so thin, that when that's burning up won't lead to excessive blue smoke.
It isn't a big thing, tho.
Just keep an eye on the oil level.
Dutch Scooby lover is offline   Reply With Quote
Old 07-22-2007, 04:45 PM   #7
ImportVenom
Member#: 34204
2004 WRX
WR Blue
If you switch away from the Mobil1, you might see your oil consumption drop significantly. At least that was the case with me...
ImportVenom is offline   Reply With Quote
Old 07-22-2007, 06:34 PM   #8
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
side note..
have been using motul 5w40 or mobil 1 5/30
and that is with about 1/2 quart arfter 4k..
Old 07-22-2007, 10:32 PM   #9
rkramer
Member#: 118209
2015 WRX Limitec
was it parked level? I had that happen once when the car was parked at maybe a 10 degree lean to the passenger side for 2 days. I don't burn a drop of oil between changes, and it only happened once. but i started it up and was greeted by a fairly impressive cloud of smoke.
Old 07-23-2007, 09:13 AM   #10
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
Yeah...that happend when I changed my uppipe, but hasn't happend since then.
This is not that.
Old 07-23-2007, 09:19 AM   #11
Rexxxx
Member#: 26320
2002 WRX Wagon
WR Blue
You may want to check your coolant level if you haven't already.
It depends if this blue smoke is light or dark.
Rexxxx is offline   Reply With Quote
Old 07-23-2007, 09:26 AM   #12
mikeythejew
Member#: 141672
I've replaced many valve stem seals on vehicles with this scenario. If you know how to use a good, hand held vacuum gauge, you can pinpoint if it's that. The vacuum/boost gauge in a car is not the same.
mikeythejew is offline   Reply With Quote
Old 07-23-2007, 09:28 AM   #13
mikeythejew
Member#: 141672
Also, some guys have luck using autorx. http://www.auto-rx.com/pages/enginebuilder.htm People who've used it that frequent bob is the oil guy.com says it works.
Old 07-24-2007, 09:02 AM   #14
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
Coolant level is fine.
Are you talking about doing a leak down test?
AutoRX
Thanks, I'll check it out.
Old 07-25-2007, 03:39 AM   #15
Black-Falcon
Member#: 106318
16 Cadirrack
ATS-V
The way I remember how to stay the F away from Mobil1 is that the 1 stands for what its viscosity is after 1k miles.
I'm running Amsoil 10w30 right now, and I'm about to switch to 10w40 because of the Arizona heat, but I'm liking it so far.
Black-Falcon is online now   Reply With Quote
Old 07-25-2007, 12:21 PM   #16
Turbotegra
Member#: 1389
2007 IS350
05 VFR 800 ABS
I've had this happen to me on numerous cars and it still happens randomly with my 350z. I noticed that if I drive the car for a short amount of time (shuffle parking spots), there's a black/blue puff of smoke during start up that lasts about a second. So far, it has probably happend 5-6 times in the last 2.5 years that I've had it. There are times that the car sits for a whole 2-3 weeks and will not smoke during start up.
My impreza also does this but it seems to have gone away after I put the stock exhaust back on. It was doing with the stock motor when it was turboed and after the swap. Only did it randomly when the car sat for a few days.
I don't lose any oil between changes and I use 10w-30 Castrol GTX.
Turbotegra is offline   Reply With Quote
2002 WRX blue smoke out of exhaust Alex Germain Newbies & FAQs 57 01-29-2014 09:01 PM
Light Blue Smoke from the tail pipe topher88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-23-2009 02:06 PM
Blue Smoke out of exhaust. ed007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-27-2008 10:13 PM
Burning oil and blowing blue smoke out of exhaust stikboy9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 03-06-2007 02:39 PM
Blown Turbo and Blue Smoke out the tail pipe. rally_wannabe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-04-2003 05:31 PM
