Alaskan Impreza Club
Old 07-22-2007, 11:19 PM   #1
yukon1
Member#: 4730
07 Legacy Spec,B
Diamond Gray Metallic
Default Anybody have this problem
Any of you 07 owners having a problem with your trac control, abs, and cruise control. Every time i get in the car now and hit the brakes the trac light, abs light come on and i have no cruise control. Use too do it only every now and then. Any Ideas?
yukon1 is offline   Reply With Quote
Old 07-23-2007, 01:51 AM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
sounds like to me your setting a speed sensor code which uses the abs/trac light and others on your dash to communicate with you stating there is issue. Take it into Subaru and have them diagnose it.
Mavrik is offline   Reply With Quote
Old 07-23-2007, 03:58 AM   #3
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
seen low brake fluid do that! fluid sensor will shut down all mentioned. your cluster display will say err ss if a speed sensor is acting up.
00Maddog is offline   Reply With Quote
Old 07-23-2007, 02:30 PM   #4
yukon1
Member#: 4730
07 Legacy Spec,B
Well it has been too the suby dealer twice know, they said the subie tech line said it could be two things. 1st there are two floor matts, 2nd im letting out on the clutch while im starting the car. So next tuesday they are replcacing the brake switch.
Old 07-23-2007, 02:41 PM   #5
yukon1
Member#: 4730
07 Legacy Spec,B
Hey Jerry,
The fluid looks fine, about 8th of an inch from max. Only happens if you press the brake pedel down and as your letting up on it, is when the lights come on.
Old 07-23-2007, 03:37 PM   #6
JordyB
Member#: 20328
'05 Forester XT
'07 Legacy spec.B
Odd for sure, haven't seen this issue on my dad's specB but the TPMS was broken from the factory...he should be coming in soon to have that fixed.
JordyB is offline   Reply With Quote
Old 07-23-2007, 07:32 PM   #7
yukon1
Member#: 4730
07 Legacy Spec,B
This problem started about a month ago, would happen every now and then. Now it happens when every you press the brakes down and release them.
Old 07-23-2007, 08:01 PM   #8
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
clean the sensor?
SQUAD_907 is offline   Reply With Quote
Old 07-23-2007, 10:04 PM   #9
yukon1
Member#: 4730
07 Legacy Spec,B
the wheel senors???
Old 07-23-2007, 10:07 PM   #10
Mavrik
Member#: 90347
Yamaha FZ8
I'd leave the cleaning to the dealership, that way if they mess it up, you get a free sensor.
but it doesn't sound like a floor mat under the brake pedal type issue. sounds more electronic.
Old 07-24-2007, 01:47 AM   #11
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
does it have an aftermarket autostart?
sounds like an issue with the brake switch or maybe the wiring (see above question lol). once the car decides it can't trust the brake switch it shuts down the abs, trac, and cruise because all depend on the brake switch.
Old 07-25-2007, 06:11 PM   #12
yukon1
Member#: 4730
07 Legacy Spec,B
Yes it does have an after market auto start.
1st gear problems. Anybody else have this problem? Travis Graham Transmission (AT/MT) & Driveline 4 04-21-2006 06:28 PM
Anybody have this problem? dubluv17 Electrical & Lighting 4 10-04-2005 12:50 AM
Anybody have this problem? Plastik Racer Tri-State Area Forum 8 10-03-2005 08:56 PM
Anybody have this problem? beefcake6681 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-03-2002 08:08 AM
anybody have this problem? ychan Newbies & FAQs 9 04-12-2002 10:44 AM
