Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 01-03-2002, 12:04 AM   #1
HomerJay
Member#: 1135
2005 WRX WAGON
Question Rear diff. fluid change w/ Primitive Skid Plate
I have a primitive rear skid plate for my MY00 RS. Anyone else have this on their car and done a fluid change? Will I need to put it on and then remove it when it comes time to change oil or do the holes match up evenly?
-JOE
HomerJay is offline   Reply With Quote
Old 01-03-2002, 01:58 AM   #2
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
Dunno about the RS plate, but the WRX one has a big oblong hole that provides access to both plugs... HOWEVER, there is still space between the diff and the plate, so you will probably drain some fluid into the protector, so you might want to take it off.
If you don't care about that sorta thang, then don't worry about it
Geek Guy is offline   Reply With Quote
Old 01-03-2002, 02:44 AM   #3
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
You could always get a tube and a pump, and suck most of the fluid out the top hole, then pop the bottom open and suck the rest out. If you use that method, it might be best to drive the back up on ramps so the drain holes are at the high end. Otherwise, expect to have a puddle of gear oil in the diff protector.
CosmoTheCat is offline   Reply With Quote
Old 01-03-2002, 11:20 PM   #4
HomerJay
Member#: 1135
2005 WRX WAGON
The RS skid plate also has an oblong hole for both plugs. I was actually going to jack up the front so it will drain out better and not get all in the skid plate, then fill it up using a baster type thing. I'll tell you how it goes
Old 01-04-2002, 01:11 AM   #5
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The earlier RS plate just had two holes. The new style is much better!
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 01-09-2002, 03:43 PM   #6
fatVdub
Member#: 5296
01 2.5RS
when i did mine i took it off. i didn't wan to mess with dripping gear oil all over. if took a extra 15min. but no dripps. i also jacked the car up fromn the front to drain all i could. enjoy...matt
fatVdub is offline   Reply With Quote
Old 01-10-2002, 01:39 PM   #7
redobs
Member#: 1501
2009 WRX wagon
Dark grey
I took a piece of cardboard and used it as a deflector. I did get some on the skidplate though. Tha's what drain holes are for, right?
redobs is offline   Reply With Quote
Old 01-10-2002, 04:43 PM   #8
Geek Guy
Member#: 8151
2002 WRX Rally Car
There aren't any bottom drain holes on the WRX diff plate ;(
Old 01-13-2002, 10:26 PM   #9
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
I would suggest getting a piece of plastic or cardboard to direct the oil flow over the lip of the rear diff protector.
You will get oil in the plate, and it will go drip drip drip for awhile while driving. You can remedy this by driving like a maniac and slinging out all the gear oil that was left in the skid plate.
remarcable is offline   Reply With Quote
Getting ready for trans and rear diff fluid change, need recommendations BGPKR Transmission (AT/MT) & Driveline 8 03-11-2008 02:29 AM
rear diff fluid change Jersey Dino Service & Maintenance 20 01-17-2006 02:43 PM
Rear Diff Fluid Change at 30K in STi? jsavage Service & Maintenance 5 09-07-2005 03:08 AM
Tranny/Rear Diff fluid change atmosphere Service & Maintenance 1 08-30-2004 08:10 AM
Tranny and rear-diff fluid change experience jlyttle Transmission (AT/MT) & Driveline 19 04-29-2002 04:57 PM
