Old 01-03-2002, 12:25 AM   #1
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Default 5zigen Twin mode clutch system
Quite interesting, and not too expensive either.
Anyone care to try?
Keiho is offline   Reply With Quote
Old 01-03-2002, 01:08 AM   #2
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
They need to modify this to work with some sort of paddle shifting system.
Very Cool....
Zahnster is offline   Reply With Quote
Old 01-03-2002, 11:43 AM   #3
nqwan
Member#: 2916
02 duburu arr exu
i wonder if the switch button can be mounted somewhere other then the shiftknob, like where the variable center diff switch would be...if so, i'd be very interested in the kit...
nqwan is offline   Reply With Quote
Old 01-03-2002, 01:18 PM   #4
mitch808
Member#: 10228
2002 Subaru WRX
Price wise it's pretty reasonable. I'd love to see someone that has this on ANY car.
mitch808 is offline   Reply With Quote
Old 01-03-2002, 01:32 PM   #5
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
I'm kinda confused on the Auto-mode.
Is this like fully auto where the new electronics will do all of the shifting for you, but if you want you can cause up/down shifts by pushing up/down on the shift lever?
Interesting....
Similar or related products?:
http://www.luk.de/english/Produkte/PSG.html
http://www.hobbycenter.co.id/twinclutch.html
Old 01-03-2002, 05:53 PM   #6
nqwan
Member#: 2916
02 duburu arr exu
Interesting....
the way i interpreted it to be is that with it off, its just like your standard manual tranny. with it on, it works just like a tiptronic/steptronic system
i wonder if it requires you to work the clutch on starts with the system on. i know the impreza wrc's system does...that would be awesome if it didnt
Old 01-03-2002, 09:06 PM   #7
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
If it doesn't handle the clutch in first gear I don't see how it can help in traffic.
Dan
Old 01-04-2002, 11:29 PM   #8
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Talking
Couple this twin clutch system with the Sequential shifter that Takira has on their web site and you'd have a cool tranny set up.
-myk
mykrrrr is offline   Reply With Quote
Old 01-05-2002, 03:04 AM   #9
elemental
Member#: 2701
'00 obs
im not sure about the first gear starting conditiosn but i think there is some intervention needed, it needs you to change the gears, just not press in the clutch... what i'm wondering is how smooth it shifts...
and how fast it eats clutches, at that?
elemental is offline   Reply With Quote
Old 01-05-2002, 08:05 PM   #10
JRC 666
Member#: 2950
i think that this is badass...but it says under engine - EJ20...so does that cause a problem with RS-Ts with EJ25s?
but i remember someone saying... "EJ engines will hook up with EJ transmissions".
JRC 666 is offline   Reply With Quote
Old 01-05-2002, 08:45 PM   #11
Section 8
Member#: 821
Turbo transmissions have different clutches than non turbo transmissions. This may cause problems.
Greg
Section 8 is offline   Reply With Quote
Old 01-06-2002, 01:18 AM   #12
JRC 666
Member#: 2950
it seems like a good price to me...if i had the money right now, i'd try it out...but i'm sure there's highrollers with a deep pocket that wanna try this out!!
WTB: 5 Zigen Twin Mode Clutch System stewgod Private 'Wanted' Classifieds 0 12-07-2006 02:23 PM
Twin mode clutch system neverendingmods Transmission (AT/MT) & Driveline 1 11-01-2002 12:47 AM
Twin mode clutch system neverendingmods Transmission (AT/MT) & Driveline 0 10-31-2002 11:35 PM
Clarifying function of 5zigen twin mode clutch Chris Stein Transmission (AT/MT) & Driveline 3 04-23-2002 11:58 PM
Anyone Tried the 5Zigen Twin Mode Clutch System yet? satrya Transmission (AT/MT) & Driveline 5 03-14-2002 09:47 PM
