Alaskan Impreza Club
Old 07-23-2007, 09:33 AM   #1
Jaylyons1
Member#: 113884
1989 Skyline GT-R
Default Rear diff leaking oil...
OK, so under the car again yesterday and I noticed some oil on my rear sway bar. Very confused, I looked around and it didnt take long to see some oil on the rear diff. its qutie a bit above the filler plug and seems to be coming from one of the bolts. I researched this topic and found that the only stuff I could find were people with their rear diff seizing up or making noise, which mine doesnt do.
My main question, is what kind of oil do you put in the rear diff? I figure I will check it and make sure its full and try to tighten that bolt. Not sure if a seal is broken or not. But If its low Ill probably just empty it out and refill it since your not supposed to mix oils.(and I have no clue what oil is in there now)
It doesnt leak while sitting still, but it did have some on the sway bar and a bit on the diff so wanted to fix this problem before it got serious.
Jaylyons1 is offline   Reply With Quote
Old 07-23-2007, 12:17 PM   #2
wuuusaa
Member#: 92894
2015 Wrx
remember c street, that might be the cause of it leaking
Last edited by wuuusaa; 07-23-2007 at 12:23 PM. Reason: i was going to delete, but ill leave it alone
Old 07-23-2007, 12:40 PM   #3
edo2000
Member#: 68709
2012 WRX
red
On a wrx, you use the same oil that you use in the transmission - 75w90 gear oil. I imagine its the same with an STI.
edo2000 is offline   Reply With Quote
Old 07-23-2007, 03:06 PM   #4
Getagrip
Member#: 2045
BRZ
STi rear diff oil is different. USE THE SUBARU STUFF. It come is a tin can and Conti has it in stock. We have not seen an aftermarket substitute. Play it safe and get the Subaru stuff.
Getagrip is offline   Reply With Quote
Old 07-23-2007, 03:14 PM   #5
Jaylyons1
Member#: 113884
1989 Skyline GT-R
I didnt ask what caused it, lol. Plus I really didnt get on it that hard. I figure if I'll have many seals, clams, hoses, and other odds and ends to replace over the life of the car anyway.
Old 07-23-2007, 09:36 PM   #6
wuuusaa
Member#: 92894
2015 Wrx
probably might just be wear and tear, that is what i was getting at.
b/c mines kind of do a little bit
Old 07-24-2007, 12:32 AM   #7
Wes_FSTGDB
Member#: 59400
2013 335XI MSport
2008 BMW 335XI Space Grey
Do you change it regularly? Should change it once after every 10,000 miles. I'll have to get it done before this winter, almost at that point. Especially if you drag race or Auto X a lot. After one season my fluid was pitch black in the rear diff.
Stuff last a long time as long as it's maintained.
-Wes
Wes_FSTGDB is offline   Reply With Quote
Old 07-24-2007, 02:39 AM   #8
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
the vent is on the top of the rear cover. sounds like it's overfilled a bit and you got er warm enough to spew some out. i see it all the time on all types of subarus.
00Maddog is offline   Reply With Quote
Old 07-25-2007, 12:59 AM   #9
Jaylyons1
Member#: 113884
1989 Skyline GT-R
Ok, cool. Ill still pick up some oil tomorrow @ subaru and change it out. Gotta order me a 02 sensor also, it turns out that was in fact the problem with the black one. Put the one from the 04 in and it is as good as new!
Old 07-25-2007, 05:20 AM   #10
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
get a pump or come borrow mine! it's a pita to get oil in the rear diff.
Old 07-25-2007, 01:40 PM   #11
Firestrike
Member#: 135785
2006 Impreza WRX LTD
Cloaking Device Gray
*chimes in*
Firestrike is offline   Reply With Quote
Rear Diff Leaking...Not at the drain :( proletariandan Transmission (AT/MT) & Driveline 15 07-31-2007 10:52 AM
Rear diff leak, pic included! Flexy Service & Maintenance 15 07-28-2005 08:51 AM
rear seal leaking oil wrxman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-20-2004 10:18 AM
Rear diff leak? celica88 Service & Maintenance 6 06-21-2004 02:47 PM
Rear Diff leaking ? Matt Technical Forum Archive 5 08-28-2000 11:22 AM
