01-03-2002, 02:36 AM | #1 |
Member#: 293
Vehicle:2001 Turbo RS Black |
My New Year Setup
So as of 1/1/02 my car has been successfully boosted.
I am now running: -Garrett T3/T4 -Top-Mount Intercooler -Greddy Type-S BOV -Tial Wastegate -Greddy Intake -EGT, Boost, Oil Press Autometer Phantom Gauges. Not too far around the corner: -Walbro Fuel Pump -RC 440 injectors -Electromotive Tec-II I also got my windows tinted at 15%. My car is totally stealth now. I wonder if I should change her name from Susy to Kit.....? Nate
01-03-2002, 11:47 AM | #2 |
Member#: 13855
Vehicle:1998 civic flamenco black pearl |
very badass setup you got going there
what kind of E.T.'s are you turning with that setup? |
01-03-2002, 11:57 AM | #3 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
glad to hear it man...now do us a favor get the fuel pump and injectors before you start detonating...don't want to see another i blew my #4 cylinder cause my fuel pressure was too high thread....good luck. I just don't want to see someone start a new year by detonation a hole
Jeremy |
01-03-2002, 03:13 PM | #4 |
Member#: 293
Since my car is a 2001 i am limited to 3 psi. Until I get the Tec-II that is.
I have the injectors and feul pump in the garage but i cant put them in until i get some fuel management...... So I need to wait until I save up enough to get the Tec-II..... Oh well I am happy at 3 psi. And I wont get any detenation if I am careful at this boost level..... Nate |
01-03-2002, 04:57 PM | #5 |
Member#: 4540
Vehicle:MY00 2.5RS Sedan Abnormally Aspirated |
Does it run okay without an RRFPR and voltage clamp? I know you mentioned running at 3psi max, but does your wastegate spring reliably limit to that, or are you getting a fuel cut occasionally? Or perhaps, since it's so newly installed, you haven't taken any WOT runs yet? (Probably a good idea until things are shaken down a bit)
Congratulations. Be safe. |
01-03-2002, 05:35 PM | #6 |
Member#: 4942
BAIC
Vehicle:01 SRP 2.5 RS-T Ludespeed Stage 3 Link'd |
where did you get the gauges? i was gonna get some greddy's but they read to like 30 psi and are in celcius (which i can live with) but i want to get gauges that match.
01-03-2002, 06:40 PM | #7 |
Member#: 11931
Vehicle:2001 2.5 RS Turbo 257/FMIC/T3-T04S |
Nate- No J&S or anything like that? Are you running with a RRFPR?
I like the sound your set up, but am wondering if you lack the effectiveness to get fuel into your cylinders. But since your only running at 3 psi, I guess its not too big of a deal. Oh, and how do you like the sound of the GReddy Type-S BOV? I was thinking of getting this for my car, but i've never heard one. Graham |
01-03-2002, 11:37 PM | #8 |
over boosted again
Moderator Member#: 1458
RMIC
Vehicle:2017 WRX Limited 15 Forester XT, 21 Ascent |
I would just get a voltage clamp and run a full 5 psi. The proECM powerchip has a voltagte clamp built in and is only $249.95, while functioning much like the IWTU torque chip II
Larry |
01-04-2002, 02:28 AM | #9 | |
Member#: 6551
Jeremy |
01-04-2002, 03:24 PM | #10 |
Member#: 293
-Gauges i got from Summit. They're Autometer Phantoms.
-Greddy Type-S sounds really good, still needs some adjustment though. Other than that I notice a big difference at 3 psi..... Nate |
Advice for my new turbo setup before protune and alky/meth setup | 04subyrex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 20 | 11-16-2007 12:38 PM |
My gallbladder made my new years resolution for me... | HamFist | Off-Topic | 23 | 01-02-2007 03:12 PM |
Atkins + Drinking = Grap On My New Year | binky | Off-Topic | 29 | 01-01-2004 04:01 AM |
Need help with my new suspension.. Setup, specs, ... (Ohlins) | Mike Moffa | Brakes, Steering & Suspension | 4 | 06-24-2001 07:52 PM |
Pics of my new Turbo setup | Kcz | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 28 | 04-12-2001 12:04 AM |
