Old 07-23-2007, 04:54 PM   #1
boxoftj
Member#: 120944
2004 STi
Default would an 03 ecu work on an 02 model?
i have an 03 ecu from my old wrx, and my 02 has an ECUtec flashed ecu. I would rather have the Cobb AP because there seems to be more support, but i also hear that ecutec locks out other tuners. could i swap my 03 ecu to my 02 wrx, since the ecu is completely stock on the 03?
boxoftj is offline   Reply With Quote
Old 07-23-2007, 05:20 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
How long have you had your ECUTek? I just reflashed a car that was ECUTek'd 1 1/2 years ago and it wasn't locked.
Old 07-24-2007, 04:16 PM   #3
boxoftj
Member#: 120944
2004 STi
not too sure, it was flashed before i bought the car in february. could be old, i have a pretty old ECU monitor in place of the clock, too.
Old 07-30-2007, 12:40 AM   #4
REX8
Member#: 24038
You can generally put an OLDER ecu into a newer car from 02-05, but running an 03 ECU in an 02 will give you a CEL. They added an input.
You're car will run 100%, put you'll be stuck with the CEL.
Old 07-30-2007, 04:41 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
You'll be fine running a 2003 ECU in a 2002 WRX once it's married to the AP because the AP will flash the 2003 ROM with a version from the 2002 WRX when you marry it.
Jon [in CT] is offline   Reply With Quote
Old 08-21-2007, 11:38 PM   #6
boxoftj
Member#: 120944
2004 STi
what new inputs are there? i might be interested in retrofitting them on. Another question, once the AP marries itself it flashes whatever year you purchased onto it? so later, when i decide to upgrade to a ej25, could i get a base AP program for a 2.5l block, like the 07 2.5 wrx, and it would flash the base software of that one to it?
Old 08-22-2007, 07:52 PM   #7
boxoftj
Member#: 120944
2004 STi
bump.............
Old 08-22-2007, 07:56 PM   #8
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
I have been told on here you don't actually input a displacement, everything is just done in scaling of the MAF and other stuff. However, if the 2.5L WRX is 32-bit like the STi, you will not be able to flash that map on your ECU because it can only handle 16-bit. This means that you can have the car protuned without issue, but you won't be able to run a Cobb basemap. Hope that helps some.
- Chris
wrxfactor is offline   Reply With Quote
Old 08-23-2007, 12:46 PM   #9
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Oh yeah, if you stay with the 02/03 WRX ECU when you swap in the 2.5L WRX motor, you WILL NOT be able to run AVCS. You'll need a JDM STi ECU (V7 is ideal) along with a tad bit of wire pinning to run AVCS.
Old 08-25-2007, 06:21 PM   #10
LateApex31
Member#: 135686
Fuel tank pressure.
LateApex31 is offline   Reply With Quote
Old 08-27-2007, 02:36 AM   #11
Nuke209
Member#: 108089
2003 WRX
NF Performance
For my friend, I put in an 03 wrx ecu into an 02 wrx, and flashed it with an 02 wrx map and everything was fine.
Nuke209 is offline   Reply With Quote
Old 08-28-2007, 01:08 AM   #12
aceracergofast
Member#: 154473
Default ????
Do you have a ECM pin out sheet for a 2003 WRX...???????? or know were I can go down load one?????
aceracergofast is offline   Reply With Quote
Old 08-28-2007, 04:26 AM   #13
Nuke209
Member#: 108089
2003 WRX
NF Performance
I believe it's direct plug and play because
When he bought the car, the owner comes out with an 03 ecu and just swaps it out onto his 02 car and said things were fine
(at the time we did not know)
So driving later, CEL
I looked up, found that it was ok, flashed 02 map, done.
Never had a problem.
Would a stock turbo inlet from an 06 STi work on my 02 wrx ? mrrallysti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-28-2007 04:54 PM
Would a stock turbo inlet from an 06 STi work on my 02 wrx ? mrrallysti Southern California Impreza Club Forum -- SCIC 0 12-28-2007 01:36 PM
will an aem ems for an 03 wrx work on a 02 2.5rs midnight2.5rs-t Engine Management & Tuning 2 09-24-2006 01:31 PM
Does an 03 oilpan fit on an 02 Shag-e Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-14-2005 05:21 PM
Would 93 ej22 ecu work on 93 ej18? maxim Subaru Conversions 4 10-26-2004 04:20 PM
