Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 07-23-2007, 07:13 PM   #1
Treefolk
Member#: 153308
2005 Aspen White STI
18x9.5 +22 White CE28N
Default Quick question about swaybar
Hi, I just want to ask a stupid question really fast
I have a chance to get a set of front and rear sway bar in good price
one set is cusco 22mm front and 22-24mm rear
another set is progress 22-23mm front and 22-24mm rear
I only street and daily drive my car, I don't track or race...
which set up is better or are they the same?
should I get cusco or progress?
Thanks!
Treefolk is offline   Reply With Quote
Old 07-23-2007, 08:05 PM   #2
djsniggedy
Member#: 102157
What you lookin at
willis?
You might want to do a bit more research...but a bigger front swaybar will definately make the car feel much more planted and stable. But if you're torn between the two...I couldnt say I've heard bad things about either. Neither of those are aggressive setups, so just take whichever one you can get a good price on. Word of advice...get some aftermarket endlinks for the rear at the least.
djsniggedy is offline   Reply With Quote
Old 07-23-2007, 08:54 PM   #3
Treefolk
Member#: 153308
Since I've heard the cusco doesn't required to lube the bushing, I think that's cool
But how often do we actually have to re-lube the bushing once we have installed them?
and I think the cusco 22mm one is not adjustable, will a 22-23mm adjustable do better (since I want to set it to 23mm) or 22mm is actually enough for daily drive?
I have heard good thing about the whiteline 27mm fsb. but I really thing that's too big for my taste so I think under 23mm is good enough for me
only thinking about stay with 22 is good enough or 23 is better?...
Thanks a lot!
Old 07-23-2007, 09:10 PM   #4
djsniggedy
Member#: 102157
What you lookin at
willis?
I think the recommended is either once every 6 months or once every year. My cobb bars are 1x a year. Like I said, a larger front bar will definately increase that front end grip. It wont be too much for the street....I say go for it.
Old 07-23-2007, 09:54 PM   #5
moriswrx
Member#: 149784
2007 WRX stage ?
try this its good help
Swaybar/Endlink FAQ
http://forums.nasioc.com/forums/show....php?t=1152714
moriswrx is offline   Reply With Quote
Old 07-23-2007, 10:27 PM   #6
TK421
Member#: 146200
2009 Supermoto
Not sure on the brands but, 24mm front and 22mm rear with stock springs on a daily driver is awsome and isnt going to be TOO stiff where the wheels get light around corners and have a possible slide out ..
im running that set up (whiteline though) and i cant be any happier, i can take corners like noones business
oh and its a good idea to get some beefy front and rear end links and rear mounts..It will prevent the new sways from bending the stock stuff which isnt hard to do
TK421 is offline   Reply With Quote
Old 07-23-2007, 11:13 PM   #7
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
anyone know the diameter of stock sway bars on an 02 WRX?
rexman2002 is offline   Reply With Quote
Old 07-24-2007, 01:44 AM   #8
Davenow
Member#: 23676
20mm front and rear unless its a wagon, which has a 17mm rear.
You are going to need rear end links as well. Stockers are plastic junk that you can flex with your hands.
This applies to the 02 WRX the guy above me is asking about.
Old 07-24-2007, 02:53 PM   #9
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
thanks for the info^
I am thinking about going 22mm F&R, with Cusco sways + kartboy F&R endlinks. Would I see any difference with that setup? Right now I have stock struts with prodrive springs which are supposedly 25% stiffer than stock. Would 24 for the front/rear be too aggressive? This is my daily drive, only do occasional drag strip run(s), no auto x. Anyone has 22mm sways installed?
Old 07-24-2007, 04:26 PM   #10
Slack
Member#: 17548
I don't think 24mm would be too stiff for a daily driver. I have a whiteline 22-24 front and progress 22-24-26 rear with both set to 24 and it feels great. It is always better to start off with the lowest setting on the rear, because snap oversteer can really ruin your day.
As someone already stated, make sure you get solid endlinks to eliminate the slop and improve feel. You want to know what is going on in the rear and that will help a lot.
Mick
Slack is offline   Reply With Quote
Old 07-25-2007, 04:32 AM   #11
Treefolk
Member#: 153308
I think I will get the progress one because it's cheaper and has the extra mount
Just one more question, is front endlinks important in this case? or should I just get the rear? I have the kartboy rear but thinking about getting the front one too..
Old 07-25-2007, 08:41 AM   #12
Slack
Member#: 17548
The front is just as important, so I would get them. I have the whiteline solid front endlinks and they work great.
Mick
Old 07-25-2007, 09:03 AM   #13
karl750
Member#: 100977
2004 VF30 WRX
[email protected] 1.84 60'
I just ordered and recieved some whiteline 22mm adjustable fronts and rears. The front adjust 22 & 24mm, the rears 22, 24, 26mm. Based on research, i'm doing 24mm in the front with 22mm on the rear. Plus i've upgraded the endlinks too. If you want, PM me and i'll let you know what i think of the new setup. I may not install them until i get back from my vacation to Brasil, so it could be a month or so.
If i were you, i'd go with the adjustable combo just so you have options as to how the car will handle.
karl750 is offline   Reply With Quote
Quick Question about WL swaybars empeefivenavee Brakes, Steering & Suspension 1 09-09-2007 09:29 AM
Quick question about Perrin Endlinks and Cobb swaybar. skydes Newbies & FAQs 4 07-09-2007 05:13 PM
quick question about oil pressure...worried about my car Blindeye_03 South East Region Forum 6 09-03-2004 11:58 AM
OMG quick question about swaybars White2.5GT Legacy Forum 18 04-14-2004 07:46 AM
Help, need quick answer to quick question about ezpass munkis General Forum Archive 2 09-29-2000 03:45 PM
