Old 07-23-2007, 08:58 PM   #1
snowcrzy
Member#: 110895
Default Car Just started for the first time after swap! But there are a few problems :(.HELP
I finally got my car started after some problems, use this thread: http://forums.nasioc.com/forums/show....php?t=1310325
as reference.
The car finally started and it sounds and runs great. The motor is idling at approx. 1250 and won't drop down. The motor is a bit shakey for that rpm but nothing crazy.
The big problem that I am having is that when I press the gas pedal down at either light throttle or full throttle there is a short delay then the rpms peak at 2250 rpm. It doesn't go higher even with the throttle to the floor. By the way the throttle system is a drive by wire, same used in an 05+sti.
My thoughts are that the tgv's are stuck in the closed positiion.
Anyone experience this or have any words of advice?
Mods please don't delete this, I really need this problem solved.
snowcrzy is offline   Reply With Quote
Old 07-23-2007, 09:23 PM   #2
mattwalters
Member#: 422
1998 Legacy 2.5GT
Rio Red
I suspect that you need to calibrate your throttle position sensor.
-Matt
mattwalters is offline   Reply With Quote
Old 07-23-2007, 09:27 PM   #3
snowcrzy
Member#: 110895
Any clue how to do that? I did a search can't find anything. I didn't mess with the tps sensor at all, what would cause the tps to be out of calibration?
Old 07-24-2007, 01:30 AM   #4
snowcrzy
Member#: 110895
Bump, anyone else?
Old 07-24-2007, 11:52 AM   #5
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
WHat error codes are in the ecu? THis is where you should be starting.
Clark
AZScoobie is offline   Reply With Quote
Old 07-24-2007, 01:24 PM   #6
snowcrzy
Member#: 110895
The only code that came up was an obd code: 1095.
thanks
Old 07-24-2007, 04:29 PM   #7
AZScoobie
Member#: 8785
netcom.com
THats a Fault in the tuble Generator valves. It says over current.
CLark
Old 07-24-2007, 05:07 PM   #8
snowcrzy
Member#: 110895
Thanks Clark,
Any Idea how to troubleshoot that?
Old 07-24-2007, 05:14 PM   #9
snowcrzy
Member#: 110895
P1095 Tumble generator valve circuit #1 (over current)
Not sure what that means...
Old 07-24-2007, 06:09 PM   #10
Evil STI
Member#: 36792
2015 Z/28 (Vader)
Gold chains & meatballs
Over current= dead short, low resistance.
Low current= open circuit, high resistance.
Hope that helps some.
Evil STI is offline   Reply With Quote
Just had the car detailed for the first time d3v0 Car Care & Detailing 3 04-16-2010 11:06 AM
Starting car with blow through for the first time SBW UTEC 15 01-15-2010 11:52 AM
Mitsubishi EVO X Group N rally car gets dirty for the first time NYCshopper Non-Subaru News & Rumors 14 10-29-2007 09:30 AM
Started my car today for the first time in 6 months. E-Wrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-16-2007 07:56 PM
I just showered for the first time in a week incorporeal Off-Topic 4 04-21-2006 01:11 PM
