Closed Thread
Old 07-25-2007, 10:12 AM   #1
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
Default Switching Between Synthetic and Non-Synthetic Oil
Once I have gone over to a synthetic oil, is it okay to switch back to a non-synthetic oil?
Slowsoul is offline
Old 07-25-2007, 10:34 AM   #2
Drakuun
Member#: 92774
'02 2.5 RS
Platinum Silver Metallic
I was told, that you "shouldn't" however, I've read on this site, and few others that there really isn't any danger in doing so. I think it's a myth honestly.
Drakuun is offline
Old 07-25-2007, 10:57 AM   #3
rkramer
Member#: 118209
2015 WRX Limitec
it used to be true when synth first came out. now switch all you want, your car doesn't care.
rkramer is offline
Old 07-25-2007, 11:35 AM   #4
skibumm3
Member#: 108981
2008 STI
Is switching to synthetic oil worth it? I have been thinking about doing it with the new engine. I know they say you should do it before your engine has 20,000 miles on it. So is synthetic really that much better then regular oil?
skibumm3 is offline
Old 07-25-2007, 12:25 PM   #5
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
depends on the driving conditions you go through. My car is 95% city driven, so that's really hard on the car. I use amsoil synthetic and burn about 1/2 qt between changes. Mineral oil was burning almost a full qt.
Sir-Knight is offline
Old 07-25-2007, 12:27 PM   #6
kyosho
Member#: 53079
2005 RIP 2005 WRX
236/243 CA91 Tim Bailey
better gas mileage and less need to do frequent oil changes are my reasons for sticking with synthetic.
after reading the faqs and talking with subaru, you can switch to synthetic but preferably after a few thousand miles on your car
kyosho is offline
Old 07-25-2007, 12:41 PM   #7
wrx4meinnd
Member#: 153745
2006 wrx limited
i live in the arctic, i mean in north dakota. so i have harsh conditions from 100+ temps to less then -60 degrees. so choice of oil is a key up here. i use a synthetic blend and have never had a problem. the advantage to that is a synthetic blend will mix with the condensation(water) your engine makes while going hot to cold back to hot...ect. a full synthetic will not do that. but the amount of water accumulated in the motor will not affect your car unless you hit the bitter cold that the northern areas can hit, up here oil pumps can freeze(rare but happens) and your bearings will be sprayed with water first instead of oil. so if you plan on bein damn cold then a blend is good for you.
my .02
wrx4meinnd is offline
Old 07-25-2007, 01:44 PM   #8
rkramer
Member#: 118209
2015 WRX Limitec
blends are generally considered about the worst oils to buy. Notice they don't specify the percentage of synth/regular? you might be paying substantially more for .005% synthetic oil, there is no regulation regarding it, and nobody releases #'s. You still get all the disadvantages of dino oil that synth is supposed to take care of.
also, as far as mixing with water, it doesn't matter if it is synth, blend, or straight dino. oil+water != mixing. (I'm in ND also... i run castrol synth in the wrx and snowblower/tractors, the other vehicles get straight dino. never had a problem)
rkramer is offline
Old 07-25-2007, 01:56 PM   #9
BlackPearlX
Member#: 118165
2006 WRX /
2004 Forester
As long as you dont mix them, It is okay to go back and forth...
I still use reg oil, but i might switch in the future...
I would advise you to send your oil for analysis to correctly estimate when you need to change it, instead of thinking 5k would be okay...
BlackPearlX is offline
Old 07-25-2007, 01:59 PM   #10
krzyss
Member#: 8365
2013 Ford Focus SE
It sounds like ND climate was made for synthetic oil. Or maybe it is the other way around.
To avoid water in oil you need to reach high enough temperature so it vaporizes. Then PCV valve is your friend.
Krzys
krzyss is offline
Old 07-25-2007, 02:23 PM   #11
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Methinks you are spreading incorrect information.
chimchimm5 is offline
Old 07-25-2007, 02:25 PM   #12
import111
Member#: 24447
2010 Evo GSR
GG
You can go back and fourth, mix them, it doesn't matter. Oil is oil. They are not going to combine and blow up or anything, lol. I have mixed lots of different oils without any problems at all.
import111 is offline
Old 07-25-2007, 03:38 PM   #13
CynicX
Member#: 48199
06 WRX
Yeah it doesnt matter. As long as its the correct viscosity you'll be fine. Oil just lubricates the motor.
CynicX is offline
Old 07-25-2007, 03:39 PM   #14
skibumm3
Member#: 108981
2008 STI
Will I be ok to change my car to synthetic, engine has 14k on it now?
skibumm3 is offline
Old 07-25-2007, 06:37 PM   #15
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
In my case, my WRX has 84k on the motor. The owners manual has a note from the original owner stating that he switched over to synthetic oil as soon as the car was done breaking in, so it has pretty much always had synthetic oil in it. I have a few reasons that I would like to try a dino oil for the next oil change interval, which is coming up here shortly, and I had heard a few different opinions as far as mixing synthetic fluids is concearned, so I thought I would post to find out what people here had to say.
Thanks for the input.
Slowsoul is offline
Old 07-25-2007, 07:21 PM   #16
skydes
Member#: 141347
2005 WRX
Do a google search or even better, call Subaru tech support and ask them yourself. Record the conversation and either post a transcript back here or post a link to the conversation.
skydes is offline
Old 07-25-2007, 08:21 PM   #17
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There is an Oil FAQ in the Maintenance forum.
Mulder is offline
Closed Thread
Synthetic or non synthetic 4 new WRX wrx05awd Newbies & FAQs 24 03-12-2010 12:34 PM
Telling the difference between INVERTED and NON-INVERTED Struts sti_schumacher Brakes, Steering & Suspension 6 02-11-2009 10:16 AM
Synthetic vs Non-Synthetic Oil For Turbo Installation Cusson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-31-2006 11:31 PM
Mixing Synthetic and Conventional gear oils? gotsol Transmission (AT/MT) & Driveline 4 11-04-2003 08:08 AM
Difference between ABS and non ABS Brake Lines? AKGC8 Brakes, Steering & Suspension 1 12-30-2002 09:24 AM
