Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 04-28-2009, 05:50 PM   #451
BlueScooby08
Member#: 181645
2008 WRX
WR Blue
Right by cvs? That'd be me. I live over by Dunkin donuts
BlueScooby08 is offline   Reply With Quote
Old 04-28-2009, 06:04 PM   #452
prophet413
Member#: 53054
word my parents house is a few streets behind cvs
prophet413 is offline   Reply With Quote
Old 04-28-2009, 06:28 PM   #453
prophet413
Member#: 53054
i found what i want for christmas...you guys can get a pool going or something
Transition TR450 Prototype
Originally Posted by Transitionbikes.com
The TR450 is currently in prototype stages for testing. We are expecting production models to be available late 2009 in time for the 2010 season.
The TR450 is our dedicated downhill racing machine. Heavily researched and selected with direct input from pro rider Lars Sternberg, this is an aggressive geo built for speed and stability. With a careful ratio between chainstay length and head angle, the frame has a neutral feel in corners with good rider weight balance between the front and rear wheels. The TR450 gets 8.25” of travel from a 9.5” x 3” shock placed low in the front triangle. The linkage was tuned to provide a gradual change from beginning to ending leverage rate. The suspension ramps up very evenly through the travel to give the bike a supple top stroke and good bottom out control without excessive sag or mid stroke wallow. This result is a consistent progressive suspension feel that is predictable and yields a high amount of tunability.
There are large cartridge bearings at all pivot locations, with an absolute monster of a bearing used at the main pivot for durability and frame stiffness. All bearings are pressed directly against post welding machined bearing seats inside the linkages, eliminating misalignment that can occur when bearings placed at outer edges are “pinched” together. The overall suspension design was selected to keep the shock low in the frame, while still protecting the rear shock from tire roost. The pivot points have been laid out to triangulate loads and keep the rear end stiff, which helps keep the bearings turning smoothly, and your wheels tracking straight.
Custom tube shapes were developed and the downtube has a tooled reinforcement rather than a traditional weld on gusset. This thicker section reinforces the underside of the downtube/headtube junction without the stress riser created at the edge of a weld on gusset. The front triangle features double welding, which creates a thick but smooth weld and yeilds a significant increase in strength for high stress areas. The TR450 has a tapered headtube with an integrated Cane Creek size top bearing and standard 1.5” bottom intended to run a zero stack cup. The shape of the headtube better matches the toptube and downtube size and shape, and leaves plenty of clearance for fork crowns. The short headtube length gives riders lots of room for handlebar height adjustment and an aggressive low stance.
Mud shedding was a key concern in the design of the frame. Excessive pockets were avoided and many parts, like the dropouts and rear triangle yokes, are hollowed from the inside and smooth on the outside so mud won’t collect in hard to reach places. The smooth aesthetic carries over into the lines of the frame. When viewed from the side, the linkage stays hidden from view right up to the sag point. This is a clean frame, any way you look at it. In the End, the TR450 was designed to be a bike that could be ridden hard and put away wet while being a dependable top level race bike you can trust race after race.
FRAME FEATURES:
210mm (8.25") Rear Wheel Travel
Fox DHX RC4 Coil 9.5" x 3" stroke
6000 Series Heat Treated Aluminum
Sizes: Small, Medium, Large
Current Production Run Colors: TBD
Decals: TBD
Frame Weight: 9.5 lbs (without rear shock)
Complete Bike Weight Range: 38-40 lbs (Depending on Rear Shock and Fork current test prototype bike is 39 lbs.)
Tapered headtube 1 1/8" to 1.5"
Compatible with up to 8" dual crown forks
12 x 150mm thru axle Dropouts Standard
83mm bottom bracket spacing
Accepts up to 8" Rear Disc Brake Rotors
Easily fits up to 2.8" rear tire
1 year defect warranty, Lifetime crash replacement
BUILD SPECS:
Shock Specs: 9.5" eye-to-eye x 3" stroke, Rear Pin 22.2mm x 8mm, Forward Pin 22.2mm x 8mm
Bottom Bracket: Euro 83mm shell
Headset: 1.5" Lower (deep cup compatible) / 1-1/8" Cane Creek Integrated Compatible (drop in bearing)
Seatpost: 31.6mm
Seat Clamp: 34.9mm
Rear Dropout Spacing: 150mm x 12mm
Disc Brake Mount: International Standard
ISCG 05 Mounting Tabs
Old 04-28-2009, 07:31 PM   #454
DHGurs
Member#: 187414
90 3 25i/06 Burban/
10 STi SE/13 Legacy 2.5
Originally Posted by rally_it_07wrx View Post
Anyone want to get a "buddy season pass" to Highland with me? It's $299 compared to the normal $309.
PM me. Prices go up May 9th!
Too late! Already got mine. You should be able to find someone else who wants one. Just get 'em before May 9th so you can go up there for opening day on the 9th.
They have a few other good deals this year too:
-For $89 you get a three day pass which saves you about $20 (they are now $36 for a lift pass)
-For $100 you get a day pass, rental armour & helmet, rental Trek Remedy 9, and an hour of instruction (if you choose)
DHGurs is offline   Reply With Quote
Old 04-29-2009, 11:49 AM   #455
RSblood
Member#: 87778
2015 Ford Focus ST
Race Red
I will probably end up getting a season pass this summer. Only thing is, I will probably only ride sundays, maybe saturdays, and whatever random days I have off from work.
I should probably think about the three day pass then...
RSblood is offline   Reply With Quote
Old 04-29-2009, 03:07 PM   #456
prophet413
Member#: 53054
Codes have just been ordered!!! I cant wait to fly OTB!!!
Tasty. couldn't get myself to spend the extra $40 to get the white ones though
Old 04-29-2009, 03:19 PM   #457
DHGurs
Member#: 187414
90 3 25i/06 Burban/
SNIP
MMM. Best DH/FR brakes ever. What did you end up paying? That will be a nice addition to the Perp.
Old 04-29-2009, 03:57 PM   #458
prophet413
Member#: 53054
http://www.pricepoint.com/detail.htm?stylepkey=16925
$169.95 per
after my birthday loot (including a $100 redsox scratch ticket winner) out of pocket including shipping..........wait for it....................................
$99.00
i get a kick out of knowing tha i will have brakes that are worth half as much as my bike
Old 04-29-2009, 06:28 PM   #459
Bampalo
Member#: 157665
2005 Sti
The bleed cap on my hayes nines came off in the middle of the TNT line at vietnam, pissing fluid everywhere. And I can't find a big plastic syringe anywhere to use to bleed the brakes.
Bampalo is offline   Reply With Quote
Old 04-29-2009, 08:34 PM   #460
prophet413
Member#: 53054
http://www.pricepoint.com/detail/127...-Bleed-Kit.htm
Old 04-29-2009, 08:38 PM   #461
RSblood
Member#: 87778
2015 Ford Focus ST
Race Red
Any riding going on this weekend?
I've had the urge to go riding all week, but with classes running till 5pm and staying after to do work, just haven't had the time.
Old 04-30-2009, 09:43 AM   #462
Bampalo
Member#: 157665
2005 Sti
I've got that, but the squeeze bottle is ****. Syringe is easier to apply increasing pressure
My roommate and I will be at vietnam probably on saturday matt. Don't know if i'll have my big bike, probably bring my 69er again.
Old 04-30-2009, 11:15 AM   #463
DHGurs
Member#: 187414
90 3 25i/06 Burban/
How do you like the 69er? It's a Trek I assume. Is it the white 27 speed?
Old 04-30-2009, 12:12 PM   #464
eb_rat_7
Member#: 106910
2012 WRX SWP HATCH
C6 ZO6 track toy
i would offer up mine, but i dont live very close to you. i have the bleed kit with dual syringes for the avid brakes (have juicy 7s). if you are up in the leominster area feel free to shoot me a pm and i'll let you borrow them.
eb_rat_7 is offline   Reply With Quote
Old 04-30-2009, 02:06 PM   #465
Bampalo
Member#: 157665
2005 Sti
Yeah thats the one. I really like it, its super easy to pedal and real light. First experience with a 29 inch wheel, and I dig it. Being able to go uphill is pretty neat! haha.
Old 04-30-2009, 04:59 PM   #466
BlueScooby08
Member#: 181645
2008 WRX
WR Blue
isn't it suppost to rain on Saturday?
Old 04-30-2009, 06:52 PM   #467
RSblood
Member#: 87778
2015 Ford Focus ST
Race Red
I think I might just sell my current bike and get something a bit more beefy...
Old 04-30-2009, 06:56 PM   #468
Bampalo
Member#: 157665
2005 Sti
crap does look like rain. Oh well, should still be warm enough.
Old 05-01-2009, 01:46 PM   #469
prophet413
Member#: 53054
Out For Delivery
Story of my life.
Old 05-01-2009, 06:03 PM   #470
RSblood
Member#: 87778
2015 Ford Focus ST
Race Red
Went out riding today in the High Rock woods of Needham, first time out there.... Got lost a few times, but some really good technical sections made it fun.
Old 05-01-2009, 08:10 PM   #471
prophet413
Member#: 53054
The Codes have arrived. Holy Hell!!! these things are way more meaty then i had expected!!
Old 05-02-2009, 09:47 AM   #472
BlueScooby08
Member#: 181645
2008 WRX
WR Blue
bampalo, you lucked out with no rain today
Old 05-02-2009, 01:07 PM   #473
eb_rat_7
Member#: 106910
2012 WRX SWP HATCH
C6 ZO6 track toy
yeah it was a perfect day for riding. just got back from whittman river. that place reminded me how much i suck at riding
Old 05-02-2009, 01:17 PM   #474
BlueScooby08
Member#: 181645
2008 WRX
WR Blue
I'd love to go riding but I still need a larger spring for my rear shock. I wanna head out to Lynn woods or some place else with some nice drops and rolls.
Old 05-02-2009, 10:47 PM   #475
Bampalo
Member#: 157665
2005 Sti
yeah it was great today. But unfortunately i sucked my chain up into the frame and bent some links. Bashing them with big rocks to straighten them out worked well enough to get home and pick up some new links.
Off to Lynn tommorow!
Mountainbikers, odd request. HamFist Rocky Mountains Impreza Club Forum -- RMIC 0 02-08-2005 04:15 PM
Attn: Downhill Mountainbikers items FS mtnbikeracer Private 'For Sale' Classifieds 11 01-24-2005 01:30 AM
Mountainbikes for Sale--Jacksonville, Fl. wrx2.0 555 Private 'For Sale' Classifieds 38 02-25-2004 07:29 AM
Mountainbike Ride This Saturday at Hall Ranch. Tangmere Rocky Mountains Impreza Club Forum -- RMIC 13 10-20-2001 03:15 AM
Mountainbiking marco_wrx Bay Area Impreza Club Forum -- BAIC 17 09-17-2001 12:31 PM
