Old 07-25-2007, 06:48 PM   #1
suberdave
Member#: 101865
88 GL-10 STi
Default Reading Spark Plugs
well im not sure where this post should go. but these came out of my early 96 EJ20G. i know a good plug should be kinda brownish, but these plugs are more of a red.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 07-25-2007, 07:42 PM   #2
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
are you using octane booster? looks like heavy amounts by that plug
Hurley 2.5 WRS is offline   Reply With Quote
Old 07-25-2007, 08:23 PM   #3
suberdave
Member#: 101865
88 GL-10 STi
yeah i run octane booster. looks like that may be the cause of my problem... should it worrie me that this one is worse than all the rest? they are all red but this one is just a little worse...
-=Suberdave=-
www.suberdave.com
Old 07-26-2007, 02:18 AM   #4
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
i wouldnt worry about it too much
what cylinder is it from
Old 07-26-2007, 09:43 AM   #5
suberdave
Member#: 101865
88 GL-10 STi
this one is cyl #4. in order from best to worse it was 3-1-2-4 so both left side plugs were worse than the right side plugs...
-=Suberdave=-
www.suberdave.com
Old 07-27-2007, 12:07 AM   #6
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
probably due to the fuel rails being in series (stock retarded setup) leaning out the left side.
i wouldnt worry, dosnt look like any detonation or preignition.
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 708 06-22-2016 10:58 AM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
NEED: Plug/Clip that plugs into WRX spark plug coil BeBop86 Private 'Wanted' Classifieds 16 07-16-2008 03:05 AM
Read the manifesto, but looking for more direct information about spark plugs Skin Irritant Newbies & FAQs 7 09-17-2007 05:26 PM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
