Old 02-12-2002, 11:02 AM   #1
t.rod
Member#: 1447
2000 Impreza
2001 Dodge 2500
Default Getting the fuel lines off the Fuel filter
This weekend I replaced the fuel filter. The fuel lines were so incredibly stuck and I was so determined to replace the filter that I ended up cutting the fuels line off. I figured that I had enough slack in the lines to do it. Anyways I get the lines connected the to the new fuel filter and I can't mount it back because the lines where too short but really for fear of the lines popping off when engine rocks.
Sense I have to do this again I was wondering if you guys have any tips on getting those fuel lines off the Fuel filter?
I've done this before but in the summer.
t.rod is offline   Reply With Quote
Old 02-12-2002, 11:57 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Warm water and twisting . Heating the lines up with some warm or hot water (perhaps a hair dryer) and twisting them before trying to pull them off will help alot. I had the same problem last spring when I tried changing mine out in the nice cold NH winter .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
North Ursalia is offline   Reply With Quote
Old 02-12-2002, 12:03 PM   #3
t.rod
Member#: 1447
2000 Impreza
2001 Dodge 2500
Okay I'll try that. My poor fingers will appreciate it.
Old 02-12-2002, 09:46 PM   #4
ringer
Member#: 4121
2005 impreza obs
grey/grey
i used some needle nose pliers and a lot of patience. those lines can be hell on the finger tips. grab firmly w/pliers and twist. they'll come off.
ringer is offline   Reply With Quote
Old 02-13-2002, 02:53 AM   #5
Suebee2
Member#: 13669
2002 Forester
Sedona Red
Be REAL careful with a hair dryer around fuel lines.
I like the warm water method MUCH better!!!
Gasoline + red hot heating element = Subaru Flambe.
Suebee2 is offline   Reply With Quote
Old 02-13-2002, 01:14 PM   #6
t.rod
Member#: 1447
2000 Impreza
2001 Dodge 2500
I didn't mess with the hair driver I didn't want to take a chance. They came off pretty easy with out any thing. Yesterday was a bit warmer. I got it all connected though. The other day though when when it was colder it was just impossible. The fuel line connected from the fire wall is a little shorter than what I would like. I'll have to redo that one because I couldn't get to it and because the other fuel line was in the way (funcky position) and I really didn't want to spend to much time on it yesterday.
Old 02-16-2002, 04:07 PM   #7
outback2.5HO
Member#: 15135
95 GF WRX
It also helps to use a little grease when putting the hoses back on the filter. When you go to remove the fuel lines they are much easier to get off also.
outback2.5HO is offline   Reply With Quote
where does the vacuum line off the tgv connect to? aug Factory 2.0L Turbo Powertrain 6 01-19-2009 12:28 PM
Help... can't get brake line off the hard line chimchimm5 Brakes, Steering & Suspension 3 10-20-2007 11:43 PM
blew a line off the fuel pump going down the highway today benw Factory 2.0L Turbo Powertrain 7 04-25-2006 06:10 PM
95 impreza. How do you get the brake line off the drivers side strut azn2nr Brakes, Steering & Suspension 5 04-19-2006 04:52 PM
Getting the warning sticker off the visiors DanZ Newbies & FAQs 4 08-12-2002 10:55 AM
Message Board Statistics All times are GMT -4. The time now is 01:29 PM.
