Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 02-08-2002, 01:55 AM   #26
zemmo
Member#: 5416
2002 Wrx wagon
I think I'd be trading improved performance at low temperatures for somewhat less hi-temp protection. The owner's manual says that 80W is good to 85 degrees F, and that's all we ever get. On the other hand, when it's really cold I expect the bearings will get lubricated better, and the synchros work more quickly. It's pretty pathetic how the shift-lever feels like it's moving thru molasses when it's cold, can't be doing the trans any good.
zemmo is offline   Reply With Quote
Old 02-08-2002, 11:14 AM   #27
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Looking at the owner's manual, 75W90 has the widest temp coverage.
I think any gains you'll get are minimal/immeasureable.
ANZAC_1915 is offline   Reply With Quote
Old 02-08-2002, 01:44 PM   #28
zemmo
Member#: 5416
2002 Wrx wagon
Of course the 75W90 has the widest coverage. But I don't need the upper end, the 75W80 fits my particular demands the most closely.
I don't expect any gigantic gains, although I expect they might very well be measurable, and perhaps even discernible. It's just fun, trying to get the best product for a particular application. And I haven't been crazy about the way the synchros work with the products I've tried so far...
Old 02-09-2002, 07:06 PM   #29
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
I have just one question, why choose 75w90 over 75w90ns for the rear differential? I'm thinking I'll just go 75w90ns all around, unless anyone can give me a reason not too.
Thanks,
Matt
jhonas is offline   Reply With Quote
Old 02-09-2002, 09:55 PM   #30
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The 75W90 contains added friction modifiers which are beneficial for gears and bearings but also make the fluid too slippery for proper synchro operation.
You can use either the 75W90 or NS in the diff with no problem, both are GL-5 spec.
Old 02-09-2002, 11:25 PM   #31
zemmo
Member#: 5416
2002 Wrx wagon
If you look at the .pdf tech sheet on the Redline site you'll notice that the NS is quite a bit lower in viscosity at low temps. The friction modifiers apparently increase the viscosity somewhat. But if that's not a consideration, the slippier 75W90 would theoretically offer better protection. Splitting hairs, for sure, either one should be great.
Old 02-11-2002, 10:01 PM   #32
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I think Redline mentions the 75W90 offers more protection for hypoid bevel type ring & pinions than the NS. Agreed it is splitting hairs.
Old 02-17-2002, 04:11 AM   #33
TaiChih
Member#: 3467
1998 Dinan3
Bleck
I mixed mine with 2 quarts MT-90 and 1.7 qts of super lightweight shockproof gear oil.
TaiChih is offline   Reply With Quote
Question about how much MT oil to add to my 04 FXT stockdad Transmission (AT/MT) & Driveline 4 09-20-2007 04:31 PM
MT-90 - OEM MT oil mix experiment- good makofoto Transmission (AT/MT) & Driveline 4 10-20-2003 02:29 AM
draggin MT oil ... I'm using MT-90 makofoto Proven Power Bragging 2 06-05-2003 08:26 PM
Where to buy Redline MT-90 MT oil ... in Glendale, LA, Valley area makofoto Southern California Impreza Club Forum -- SCIC 3 04-28-2003 10:39 PM
Changing MT oil, and Rear Diff. Oil in a MY00 RS?? joostin420 Technical Forum Archive 2 10-06-2000 08:46 PM
