Old 07-26-2007, 12:27 AM   #1
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Question Want to clean up coilovers this weekend...How to clean/relube?
I've got a set of inverted monotube coilovers and the dampers have built up some goo/gunk from use and various road crap that they have picked up over the last 1.5 years.
I'd like to clean that off, and then re-lube them with something that won't harm the upper seals...
I figure assembly lube is safe, possibly axle grease?
Any recommendations?
Thanks,
-- Dave
AcquaCow is offline   Reply With Quote
Old 07-26-2007, 12:53 AM   #2
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
If you are going to pull them apart and lube the inside below the seals I would use either some lithium grease or synthetic bearing grease. Last time I did it I used Mobil 1 lithium (the blue stuff).
boost junkie is offline   Reply With Quote
Old 07-27-2007, 12:26 PM   #3
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Bump?
Old 07-30-2007, 01:07 PM   #4
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
So I put the car on stands and spun down the lower spring perches. These coils were dirty =P The rear's sit at an angle to the body, such that the top of the coilover is further back than the front, kinda like this => / The front edge of the shaft had some nice black gunk on it.
I cleaned them off and re-lubed with the white lithium grease. I also took a brass brush to the threads on the coilover body and re-lubed all of that to try and keep it corrosion free for another year. I spun the spring perch back into place and was good to go.
Didn't change ride height at all, so no need for an alignment.
Went for a test drive and hit some good bumps to get things lubed up. I did a few panic stops, where I'd normally feel the rear of the car stick and then settle once I came to a complete stop...completely cleared up. No more sticky rear dampers!!
-- Dave
Old 08-01-2007, 09:47 AM   #5
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Alright, white lithium grease = teh loose...
It all dried up and started flaking off...now the top seal on the damper binds against the shaft, causing all sorts of noise when I'm driving
It's 2-3X stickier than it was before now...
Gonna have to find something different
-- Dave
Old 08-01-2007, 11:13 AM   #6
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
I wouldn't spray it on everything, but a solid / dry film lubricant may be useful in some areas. They are generally silicone or PTFE based and are supposed to reduce friction and delay corrosion. There are several available as aerosol sprays that dry at room temp.
Scooby921 is offline   Reply With Quote
Old 08-01-2007, 12:19 PM   #7
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Well, I'm sure it's fine on my coilover threads, but it's obviously not right for the damper shaft itself...
I may just use some axle grease...that stuff never dries up.
-- Dave
Who in Burlington, VT wants to help me install some coilovers this weekend? RChampion New England Impreza Club Forum -- NESIC 5 04-17-2006 08:01 AM
Need to sell the car by this weekend! 2005 STi CLEAN LOW MILES!!! Wichard20 Private Vehicle 'For Sale' Classifieds 0 08-31-2005 09:48 AM
Want to install my UP/DP this weekend... SloNoMo North West Impreza Club Forum -- NWIC 6 10-16-2004 04:33 AM
Does anybody want to come over to watch the rally this weekend? wilddave1 South East Region Forum 10 08-06-2002 08:27 AM
