Old 07-27-2007, 11:32 AM   #1
chapstien
Member#: 68284
1988 Corolla SR5
0-points
Default Low clutch engagement point after tranny install
I just pulled, had repaired and installed my 5MT. Now the clutch pedal engages half way down rather than near the top like it seems it did before. What is the next step - bleed the hydro system? Check for too much free play?
chapstien is online now   Reply With Quote
Old 07-27-2007, 09:13 PM   #2
EricGleason
Member#: 154934
1998 Impreza L
bright red
Can you tell me how high the pedals rises? I just had my clutch replaced today and it seems like all the action happens an inch from the floor but the clutch comes up about 8" from the floor. I think I need to ask him to fix that.
I think in your situation it's normal, unless your pedal has a very short throw. When my clutch was badly worn all the action was at the top of the stroke too.
EricGleason is offline   Reply With Quote
Old 07-27-2007, 09:52 PM   #3
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
You can adjust the engagement point of your clutch. Follow the linkage from the pedal, across the steering column to the pushrod for the clutch master cylinder... you will see a nut at the near side of that pushrod. Loosen the nut, pull the pin and you can turn the pushrod link to adjust your engagement point. You will likely need to do this when changing a clutch, and often times when the trans is removed and re-installed.
jhargis is offline   Reply With Quote
Old 07-27-2007, 10:03 PM   #4
EricGleason
Member#: 154934
1998 Impreza L
bright red
Can you also adjust the throw of the clutch as easily? Mine comes up as far as the construction of the car will let it, which makes it more than twice as high as the brake pedal.
Old 07-30-2007, 08:58 PM   #5
chapstien
Member#: 68284
1988 Corolla SR5
0-points
You can't (or is it shouldn't) adjust the engagement point - just the free play. The engagement point is sef adjusting. (from changing that prior to searching, then putting it back.)
Old 07-30-2007, 09:00 PM   #6
chapstien
Member#: 68284
1988 Corolla SR5
0-points
The higher the better - WRT free play.
Old 07-30-2007, 10:53 PM   #7
ACTman
Member#: 113222
Uh?? When you change the free play at the pedal you are in fact changing the engagement point. This is normally not required unless you have an aftermarket clutch.
To the author: If the only thing you changed was the trans, then definitely bleed the system again because that is most likely the cause of the problem. If you changed the clutch as well with something aftermarket, that may be reason for the different engagement point.
ACTman is offline   Reply With Quote
Clutch Job - Low Clutch Engagement? MikeNeri Transmission (AT/MT) & Driveline 1 02-04-2007 08:20 PM
Clutch engagement high after install Rickyh Transmission (AT/MT) & Driveline 3 08-03-2006 01:11 AM
Adjusting clutch engagement point? Dougeefresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-01-2001 03:24 AM
clutch engagement point aphex twin Transmission (AT/MT) & Driveline 1 11-27-2001 11:29 AM
Clutch Engagement Point Change Momentary, is this normal? H5N1 Normally Aspirated Powertrain 5 06-08-2001 02:18 PM
