Welcome to the North American Subaru Impreza Owners Club Sunday July 13, 2014
Old 01-03-2002, 09:35 PM   #1
minx
Member#: 13279
1999 Impreza 2.5 RS
Silverthorn Metallic
Exclamation Help! CEL On after Spark Plug change
There was a crack in my #4 plug and this was causing a spark from #4 to the neares bolt. This of course caused an RPM dump. The CEL came on blinking, then off, then on steady. Still on.
SO I got replacement plugs from dealership and replaced them. CEL still on. Help!
What do I need to do? Besides taking to dealership??
How do I reset the computer? Do you know what is up?
I'm desperate.
Reminder I have MY99 RS.
MINX
minx is offline   Reply With Quote
Old 01-04-2002, 01:24 AM   #2
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
If you search on ECU Reset you'll find a lot of info.
basically, unhook the battery and leave it for 30 minutes or so, then hook it up, start the car without touching the gas, and let it idle for a while, then shut it off, then go for a drive. That's just off the top of my head though, I haven't done one for months. You might want to verify it first.
CosmoTheCat is offline   Reply With Quote
Old 01-04-2002, 10:58 AM   #3
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
The CEL won't go away until you clear the code, or ECU decides that the code isn't necessary any more.
Unhook the ground terminal of the battery for at least 1/2 hour, and let the ECU reset itself. If you have a OBD-II scanner available, it takes less than 2 seconds to clear the ECU.
If you replaced the plugs with new ones, and reset the ECU, then CEL should disappear.
tmat3 is offline   Reply With Quote
Old 01-07-2002, 11:05 AM   #4
minx
Member#: 13279
1999 Impreza 2.5 RS
You rock! I'll give it a whirl tonight.
Thanks again, both a ya's. ;-)
Brandee
Old 01-07-2002, 10:49 PM   #5
DARTH SkyyWALLker
Member#: 13986
1999 2.5 RS
black mica pearl
You didn't mention whether or not you checked the plug wires, so I'll assume that you didn't. If so...
Take it off, and check the inside. If the metal ring is broken or sooty, it's the wire.
If it is, and it's your #4 wire, then you'll have to turn around, stick your hand in there (at the fat end of the plug, I forget what it's called) and yank as hard as you can, 'cause 'yer gonna haz ta 'wrastle it out of there (if it's fried to the inside of the engine).
Not fun, but I had to do it twice. I replaced my plug wire set completely after 2 1/2 years.
DARTH SkyyWALLker is offline   Reply With Quote
Old 01-08-2002, 05:33 AM   #6
DARTH SkyyWALLker
Member#: 13986
1999 2.5 RS
black mica pearl
Boost issue after spark plug change ajp11 Factory 2.5L Turbo Powertrain 4 11-30-2008 08:18 PM
Crappy Gas Mileage After Spark Plug Change Dutchman1101 Factory 2.0L Turbo Powertrain 6 10-14-2008 07:06 PM
Misfiring after spark plug change Nuke209 Factory 2.5L Turbo Powertrain 19 04-29-2007 06:12 PM
Oil temps after Spark-plug change AmolaitoPR Factory 2.5L Turbo Powertrain 5 07-08-2006 11:27 PM
Starting problems after spark plug change ggergg Normally Aspirated Powertrain 7 09-03-2004 08:25 AM
