Old 07-28-2007, 06:12 AM   #1
JohnEB
Member#: 155200
2006 GT35R Evo IX
Question ECU Adding Timing at random?
Fella's
I am trying to help a good friend out with a problem with what appears to be the ecu or possibly not. Car is a 05 STI on the stock turbo.
Recently we added a perrin fmic,perrin boost tube (which relocated the mas) ,hks evc 6, innovate xd-16 wideband, aps 3.5" tbe w/ test pipe.
Prior to the boost tube with and evc 6 we had road tuned the car with just a tatrix cable and ecu flash and the car was running perfect and very strong with no knock and afr's in the 11.2 range at wot. After we added the boost tube, evc 6, and a innovate xd-16 wideband the car while trying to road tune would run great and at random add upwards of 48* of timing which was making knock audible. No matter how much timing was pulled the ecu would do this over and over then at random stop and run fine. The car while doing this idles fine and hits the target boost. If you have any idea's on what might be causing this your input would be greatly apreciated so we can get this car back on the road.
JohnEB is offline   Reply With Quote
Old 07-28-2007, 04:50 PM   #2
JohnEB
Member#: 155200
2006 GT35R Evo IX
Bump... Noone has anything?
Old 07-28-2007, 06:36 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Do you have any logs you could show us? I'd like to see a log with RPM, IAM, TPS, MAF Flow and Voltage, Timing and KC, and Manifold pressure.
Old 07-29-2007, 09:17 AM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
please elaborate at random?..on/off gas..light load..heavy load..
Old 07-29-2007, 04:50 PM   #5
JohnEB
Member#: 155200
2006 GT35R Evo IX
Pretty much whenever... on or off throttle and under light and heavy load.
Loud 'thud' at random times AshyLarry Brakes, Steering & Suspension 9 01-09-2008 12:49 PM
link to problem ECU pulling lots of timing at tip in to 1800 rpm OvrClkdPmp AccessPort 0 04-01-2006 09:16 PM
Brake light comes on at random times 2003Baja Brakes, Steering & Suspension 6 05-19-2005 11:50 AM
If your horn honks at random times when you're turning... beachbum Off-Topic 13 04-06-2005 05:37 PM
UPDATE: 2nd time at the track Cobb Stage 2. 1st time was 14.0 at 96mph elhalisf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 11-15-2004 09:10 PM
