Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 07-29-2007, 12:50 AM   #1
mogrl840
Member#: 85298
Keep talkin **** you
are makin me famous
Default 04 Sti map and log
Here is a link to my map and log. Mods are all listed on there. Feel free to tell me what you think. Updates will be posted as they are done.
Thanks
http://www.enginuity.org/viewtopic.php?t=2213
mogrl840 is offline   Reply With Quote
Old 07-29-2007, 02:13 AM   #2
Hefe_sti_Pma
Member#: 89039
2005 Wrx Sti White
Gadiel Tuning
does 3.5 in knock correction are litle knocks you should add some fuel or take out some timing
Hefe_sti_Pma is offline   Reply With Quote
Old 07-29-2007, 02:15 AM   #3
Hefe_sti_Pma
Member#: 89039
2005 Wrx Sti White
Gadiel Tuning
did you check with your wideband? what are the range?
Old 07-29-2007, 11:46 AM   #4
mogrl840
Member#: 85298
are makin me famous
the IAM did not raise to 1.00 yet so I am waiting to see what the knock goes to after that.
Old 07-29-2007, 04:22 PM   #5
Hefe_sti_Pma
Member#: 89039
2005 Wrx Sti White
Gadiel Tuning
let me know
Old 07-29-2007, 05:51 PM   #6
mogrl840
Member#: 85298
are makin me famous
alright I will. I am going out tonight and filling up with some good gas and I will see hows she runs.
Old 08-01-2007, 12:45 PM   #7
mogrl840
Member#: 85298
are makin me famous
I changed some of the wgdc and I am still working on getting the boost smooth. after that I will post up the map and logs.
Old 08-01-2007, 12:45 PM   #8
mogrl840
Member#: 85298
are makin me famous
this map is for the EBCS in interrupt only!!! some cars may vary. I had boost spikes and had to lower the wgdc. for others is interrupt you might have to lower the wgdc's some more or even raise them. Always start off low. I get 20psi on this map, before I worked the wgdc's I spiked 23psi so be careful.
04 sti oem 04 sti parts and aftermarket and axles galore!! EROCS04SBRUSTI Engine/Power/Exhaust 66 02-28-2011 10:44 PM
Will 04 sti map work on 07 sti? SWP sube Engine Management & Tuning 1 05-28-2010 08:58 PM
FS (MIAMI) 04 sti ecu and turboxs utec and map sel.. davidsti1 Engine/Power/Exhaust 6 10-09-2009 12:20 PM
Map and log posted - 16bit 20g modded home built and tuned Fongers Open Source Reflashes 4 02-09-2009 04:23 PM
UTEC Help knock problem ( MAP and Log included) AXA Engine Management & Tuning 7 06-06-2004 12:36 AM
