Notices
Old 07-29-2007, 02:45 AM   #1
jbones
Member#: 149667
2006 wrx
goal-build a 500+whp =)
Default wrx vs sti engine
just wanted to know, is the 06 wrx engine the same size as the 06 sti? i know there 2.5l does that mean there truely the same. pistons, rods etc in size?
jbones is offline   Reply With Quote
Old 07-29-2007, 03:17 AM   #2
solarin006
Member#: 109975
WRX....Description...........Part Number
Block set.........................11008930
Cylinder Head L.................11063AB250
Cylinder Head R.................11039AB820
Piston Set........................12006AD210
Piston Ring Set..................12033AB340
Rod Assembly....................12100AA180
Crankshaft........................12200AA330
Exhaust Valve....................13202AA570
Intake Valve......................13201AA371
STi.....Description.............Part Number
Cylinder Head L................11063AB330
Cylinder Head R................11039AB910
Piston Set........................12006AC390
solarin006 is offline   Reply With Quote
Old 07-29-2007, 04:46 AM   #3
Dana Daray
Member#: 136912
2006 Sti
^ well that sums it up.......good looking out.
Dana Daray is offline   Reply With Quote
Old 07-29-2007, 07:57 AM   #4
tundra
Member#: 9290
02 Built 2.5L wrx
I'm really curious if anyone has really quantified the piston differences. We know that the sti pistons were never the greatest, but I wonder how the wrx pistons compare strength wise....
tundra is offline   Reply With Quote
Old 07-29-2007, 08:13 AM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
That's something we will never know.
Old 07-29-2007, 03:11 PM   #6
ARORA_808
Member#: 144073
05 STi
world rally blue
What about the oil pan? I asked this question a few weeks ago and never got an answer.......My reason for asking is I want to go to EL headers, but if it means changing the oil pan.....I'll pass.
ARORA_808 is offline   Reply With Quote
Old 07-29-2007, 04:01 PM   #7
emeterioy
Member#: 135089
07 wrx
swp
when they install my perrin el headers they said that the stock oil pan was on the way of the headers so I had to buy a aftermarket one..
emeterioy is offline   Reply With Quote
Old 07-29-2007, 06:14 PM   #8
NeedBoost21
Member#: 150337
2013 WrX
ISM
yeah, they have to modify the oil cooler assembly. I have the perrin el header, and they had to order the oil cooler assembly from a 2005 sti model. it works and the car sounds great
NeedBoost21 is offline   Reply With Quote
Old 07-30-2007, 12:06 AM   #9
jbones
Member#: 149667
2006 wrx
ya seriously that guy summed it up, i guess since im planning to build my block. i can blow a piston and tell you how much power it took, thats something a friendly person would do =)
Old 07-30-2007, 02:44 AM   #10
BoozeRS05
Member#: 137797
'05 LegacyGT
wagon, 5mt
What are the differences between them & the 05 LGT?
BoozeRS05 is offline   Reply With Quote
Old 07-30-2007, 06:49 AM   #11
dheruer
Member#: 146180
So, if i'm correct..
Getting STi Pistons + cylinder heads, will turn a WRX engine into an STi engine? That's the only difference i could spot from this list? That'd mean an easy extra 30-40 hp, and 750rpm higher redline then?
dheruer is offline   Reply With Quote
Old 07-30-2007, 10:52 AM   #12
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
What's the redline on the 06 WRX's? I thought it was still like 71 or 7200 RPM.
wrxfactor is offline   Reply With Quote
Old 07-30-2007, 10:55 AM   #13
drfrink24
Member#: 36369
2004 WRX STi
Java Black
Don't forget the bigger turbo....
drfrink24 is offline   Reply With Quote
Old 07-30-2007, 11:06 AM   #14
dheruer
Member#: 146180
Got that covered
Old 07-30-2007, 11:06 AM   #15
dheruer
Member#: 146180
bout 6700
Old 07-30-2007, 11:13 AM   #16
Pain++
Member#: 88289
2006 WRX: Stage 2
Urine-soaked Subway Car
Wow, that's some great information. It should be stickied, this question seems to get asked a lot around here...
Pain++ is offline   Reply With Quote
Old 07-30-2007, 11:15 AM   #17
dheruer
Member#: 146180
Will the cylinder head and pistons bolt right on? Or are other modifications needed?
Such as camshafts? or oil? Seems so unreal that the heads and pistons is "all"...
Old 07-31-2007, 03:09 PM   #18
putz
Member#: 154987
06 wrx tr 28k mile
for sale in MN
Do The Part Numbers For The Heads Come As An Assembled Head With Cam Shaft?
putz is offline   Reply With Quote
Old 07-31-2007, 05:20 PM   #19
mRak_Attack
Member#: 139686
2005 STI
Ummm....dont forget the siginificantly weaker 5spd tranny in the WRX
mRak_Attack is offline   Reply With Quote
Old 07-31-2007, 06:55 PM   #20
dheruer
Member#: 146180
Trust me.. I won't forget.
i just paid a total of well over 6000 EURO'S (so over 7500 dollars) to have it changed with PAR gears....
Damn the taxes and workshop costs
08 wrx vs. sti engine Skapunker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 08-21-2009 12:59 PM
AXIS vs STI engines chrismindless Subaru Conversions 2 04-18-2005 09:14 AM
SRT4 vs WRX vs STI vs RS vs RS-T??? OB2 Off-Topic 31 10-03-2004 03:47 PM
EJ22 vs STI engine j_wood33 Newbies & FAQs 41 11-21-2003 10:01 AM
