Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 07-29-2007, 04:40 PM   #1
rexhio
Member#: 97834
Default Enginuity launch control
my car has been tuned by slowmotion motorsports in columbus,ohio using ecuflash/ecuedit. ive heard that enginuity has come out with a launch control program and am trying to figure out where i can find this at. i have the tactrix cable to put it on myself.
rexhio is offline   Reply With Quote
Old 07-29-2007, 04:55 PM   #2
Hefe_sti_Pma
Member#: 89039
2005 Wrx Sti White
Gadiel Tuning
not yet , they are working on it.
Hefe_sti_Pma is offline   Reply With Quote
Old 07-29-2007, 05:18 PM   #3
WeldingHank
Member#: 98645
2002 WRX Wagon
it is finished, it will be released with the next big Enginuity revamp. (Launch control, per-gear wastegate comp. and ramTune)
WeldingHank is online now   Reply With Quote
Old 07-31-2007, 09:27 PM   #4
wuuusaa
Member#: 92894
2015 Wrx
do u know if there is a time fame on when it might be finished?
Old 08-01-2007, 04:42 AM   #5
LilJohn
Member#: 142934
2004 STi, Evo Killa
World Rally Blue
i know they where doing some beta testing with launch control on the 16 bit ECUs. if you go on their forums and PM one of the Devs and ask nicely they might send you the code.
LilJohn is offline   Reply With Quote
Old 08-01-2007, 09:18 AM   #6
Tea cups
Member#: 103136
We are not going to be passing it around via PM, so please do not ask. We've tested and developed launch control for the 16bit ecus as well as for the 32bit ecus (with FFS). The reason we are going to release it along with real-time tuning is because our version (RamTune) has map switching which will allow you to switch between the real-time tune and the rom (base map) tune on-the-fly (with a specific combination of defogger switch and rpm). So, in order for the launch control to be one of the parameters for map switching and real-time tuning, it has to be integrated with RamTune.
RamTune has been developed and tested on the rom side for the 16bit ecus. The fuctionality and user interface needs to be added to Enginuity, however. We have not started on real-time tuning development on the 32bit ecus yet.
If it starts to appear that RamTune will be a long ways off to being released, then perhaps I'll release launch control and per gear wastegate compensation maps which will work indepedently of real-time tuning. If this is the case, I was thinking that the launch control rpm could be setup to be adjusted as follows (16bit ecu):
1. Rev motor so that launch control limit is engaged.
2. Hit defogger button which disables launch control.
3. When launch control is in disable mode, the "real-time" limit can be set.
4. Rev motor (under the veh. speed where launch control would normally be active) and hit defogger button at the rpm you wish to set the launch control at. Launch control would now be active at the new threshold.
5. You would also be able to change the default rpm for launch control by flashing the change.
The same could be done with the 32bit ecus, but more elegantly since we can monitor more switches such as the cruise control buttons. The only issue we've come across, though, is that with the 32bit ecus and FFS, the ecu tends to end up with negative fine learning correction. When shifting with your foot to the floor (or the transistion between the shift), the ecu mistakenly thinks it is knocking. We'll have to come up with a work around for this before releasing the FFS feature.
Please do not PM devs at Enginuity about testing or to request a copy of the roms. When we need further testing, we will ask for volunteers on the Enginuity site. Thanks!
Tea cups is offline   Reply With Quote
Old 08-01-2007, 10:49 AM   #7
AirDogg2599
Member#: 102150
07 WRX
any ideas on the release date?
AirDogg2599 is offline   Reply With Quote
Old 08-01-2007, 10:57 AM   #8
Tea cups
Member#: 103136
No release date and no estimate at this point.
Old 08-01-2007, 11:29 AM   #9
rkramer
Member#: 118209
2015 WRX Limitec
My personal opinion is release it for the 16 bit ecu's as soon as you can. Just having that feature for some wrx's will bring alot of people over to open source.
Old 08-01-2007, 12:27 PM   #10
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
So says the owner of a car with the 16 bit ecu ...
Not that I am disagreeing
brettm is offline   Reply With Quote
Old 08-01-2007, 12:40 PM   #11
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
it would be cool to have now, but id rather wait and know that its all working correctly.
t4nk is offline   Reply With Quote
Old 08-01-2007, 01:22 PM   #12
rkramer
Member#: 118209
2015 WRX Limitec
nope, that had nothing to do with it at all... nope....
Old 08-01-2007, 06:45 PM   #13
wuuusaa
Member#: 92894
2015 Wrx
i'm a little confused on 16 bit and 32 ecu's, are the wrx ecu 16 bits and sti are 32 bits?
can some one please clarify, thanks
Old 08-01-2007, 06:59 PM   #14
t4nk
Member#: 129905
2005 WRB WRX
16bit are the non drive by wire vehicles (02-05WRX)
32 bit are drive by wire (04+sti, 06+WRX, LGT, FXT, Baja Turbo)
Old 08-01-2007, 07:04 PM   #15
LastResort
Member#: 99289
I'm curious as to how launch control works with non DBW ECU's. Does it just pull ignition/injection to keep the RPM's at a steady state?
LastResort is offline   Reply With Quote
Old 08-01-2007, 07:10 PM   #16
wuuusaa
Member#: 92894
2015 Wrx
thanks for the info
Old 08-01-2007, 07:55 PM   #17
Tea cups
Member#: 103136
The same way it works with the 32bit ecus - using the normal rev limit fuel cut logic. Since we can't monitor the clutch signal with the 16bit ecus, when vehicle speed is below a certain threshold (adjustable), the launch control limiter is used. When above that speed, the normal rev limit is used. For 32bit ecus, whether launch control/FFS fuel cut is active or not is controlled by whether the clutch pedal is in or not with a vehicle speed threshold for determining the switchover from launch control to FFS (additionally, it would be easy to add an additional threshold for FFS based on throttle position to avoid the fuel cut during normal driving).
Old 08-01-2007, 09:03 PM   #18
LastResort
Member#: 99289
I had assumed that you would limit the throttle opening on the DBW cars. Thanks for the feedback.
Old 08-01-2007, 09:30 PM   #19
t4nk
Member#: 129905
2005 WRB WRX
why do that when you can use the same programming as the stock rev limiter? What you are assuming would take a lot of extra programming, if its even possible. Why waste the time when u can do it a lot easier, and acheive the same OR better results?
Old 08-01-2007, 09:32 PM   #20
LastResort
Member#: 99289
Dunno. That's why I asked the question.
Old 08-30-2007, 02:41 PM   #21
Espen
Member#: 57582
2003 WRX
WRC Blue
Default OpenEcu map-switch ?
A bit off topic but..
Is there a way of fooling the ECU to believe it has AT transmission and not MT ? And vice versa..
The reason I'm asking, is that this would open the possibility of switching between 2 maps.
Espen is offline   Reply With Quote
Old 08-30-2007, 04:53 PM   #22
bjonesy
Member#: 150820
any release date set? I'm thinking about the accessport just for the launch control
bjonesy is offline   Reply With Quote
Old 08-30-2007, 05:08 PM   #23
t4nk
Member#: 129905
2005 WRB WRX
all updates are normally posted on the enginuity website..
Old 09-08-2007, 10:47 AM   #24
ITP
Member#: 131227
Just curious! What kind of power did you make on they're Dynapac?
ITP is offline   Reply With Quote
Old 09-08-2007, 05:32 PM   #25
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Nice the per-gear will be able to clean up them 5th gear pulls
What is ramTune.
Not-EWRX is offline   Reply With Quote
enginuity or something = now with launch control?? adWRXi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 11-25-2007 08:56 AM
enginuity launch control 04blksti Commercial ECU Reflashes 1 08-17-2007 09:47 PM
Can Cruise control co-exist with launch control with the 2002 wrx Hydra? jigga Other Engine Management 5 04-17-2007 08:16 PM
UTEC Launch control rev limiter? Typhoon Engine Management & Tuning 6 01-28-2003 09:08 PM
Launch control and flat shift...what do you think? Onederer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 10-23-2002 06:40 PM
